Question about Refrigerators
Motor running but does not get cold - Refrigerators
  • 115 Answers
The compresor has to be changed,if my info was of any help to you then please leave a comment ,vote,note.thankyou
Posted on Sep 11, 2009
  • 199 Answers
There is a leak in the coolant cycle system or the seals are shot. Replacing the compressor and coolant will fix the problem if there are not micro leaks in the heat exchanger (tubes with grating) but it may be better to just get a new frige, depending on the model. Expensive ones are worth it, cheapies are not. You make the call when the cost of your parts and refilling are discovered. Remember all it takes is a leak one molecule wide, and the new refrigerants are now smaller, they leak through most rubber tubes but won't through metal.
Freezer and refrigerator not getting cold but motor running
What is the make and model of your fridge?
Mar 31, 2014 | Refrigerators
MY FRIGE STOPPED WORKING
HI.THIS needs elaboration.on a general note i am assuming its running but not getting cold.1-check con/unit and should hotish.lack of refrigerant if it is cold and motor running.2-cond/uni cold and motor v/hot and not runnig.suspect motor.con/unit cold motor cold.suspect thermostat the motor.good luck hope it helps.Ali
Jun 18, 2012 | Haier Refrigerators
Hello, our fridge has stopped working, the fan and motor are still running but the unit wont get cold anymore.I think it might be a freon problem but I cant be sure. The motor and fan are running constant
Your right! A freon leakage system problem cause no cold anymore.
But a temp control must be check.
A defective temp control will also cause no cold of the freezer.
The same also if compressor motor is defective even though it is running.
Call a service technician to verify the trouble of your fridge.
I hope I give you idea regarding your fridge problem.
Jun 28, 2011 | Whirlpool ET1MHKXM Top Freezer...
Compressor runs slow when cold
hi there, if there is a steak running of compressor check the the lubrication oil or change oil if neccessary.also check the motor condition by loosening the belt from pulley and run alone the motor if still tripping off,replace bearing of the motor.have a nice day and fix my rate thanks a lot
Apr 17, 2010 | Campbell Hausfeld 26 - Gallon Air...
Motor does not stop running. Freezer too cold.
change the temp controller / aka>>thermostat is stuck closed!
Jan 15, 2010 | Refrigerators
Refrigerator is not getting cold although the freezer appears to be working fine
can you hear the evaporator fan motor running in the freezer? this fan motor pushes the cold air from the freezer to the food section to keep it cold. you may have to replace the evap. fan motor. also, check for any kind of ice build up around the evap fan motor.
Oct 11, 2009 | Amana ABB1927DE Bottom Freezer...
My uline refrigerator won't get cold at all. Was
If the refrigeration motor is running and it is not getting cold then it probably is low on freon the gas that is used for refrigeration. Also if the motor only runs for a few minutes then stops it is possible that the cold control is bad, This is a common problem in refrigerators and can be fixed by replacing the control. First you must determine that the motor is in fact running. If the motor is running the motor should feel warm to the touch after 10 to 20 minutes of operation, and you should feel some cooling in the refrigerator on the cooling or evaporator coil. If the motor is running and getting warm or hot and you feel no or very little cooling then it is in fact ether low on freon or a component in the refrigeration system is malfunctioning. Freon can only be replaced by a certified technician.
Oct 07, 2009 | U-Line ?chelon 2175RB-00
Ice maker stopped working, plus fridge not cold, but freezer o.k.
I would check that fan motor in the freezer section is running. it distributes cold air from freezer into refrig section also if this motor is running the top portion of freezer will not get cold enough to allow ice production. the motor is easy to repl and is mod# specific you should be able to buy one online.
Jan 21, 2009 | Kenmore 64802 Top Freezer Refrigerator
Fridge & wont get cold wont get cold, fans is on motor gets hot
check to see if compressor is running if not replace relay also make sure ur condenser motor is running
Jan 19, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Fridge not cold .
if there is frost building up in the frezzer on the back wall you have a defrost problem,is the frig. motor clicking on and off or just running all the time?if it runs all the time you need to unplug it so you don't burn thr comp. out,let me know what you find-mike
Nov 12, 2008 | Hoover Refrigerators
Refrigerators Logo
75 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
