Question about Soyo DYLM1986 Monitor
Turns on and off rapidly - Soyo DYLM1986 Monitor
  • 601 Answers
Double check all cables and connections, make sure they're tight.
Could be the power supply, video card, or the monitor may need replacing.
Hope this helps
Thanks
Posted on Sep 11, 2009
I have sourced out all fuses and bulbs, yet continue to have a rapid right turn signal. I don't know where else to look. help?
replace the right rear bulb. the quick flashing indicates a bad bulb. it could be a wiring problem to the rear for the signal light that you will have to check out starting at the socket and working forward.
Mar 29, 2015 | 2005 Chevrolet Uplander
My right turn signal flashes rapidly, and after turning it suppose to turn off itself but i have to turn off the signal manually. the left sometimes turn off itself.. how can i fix this? 98 buick century
when signal is rapid it useually means that a light is out. About your signal not turning it self off.
That is a defective indicator switch which useually means removal of steering wheel.
Apr 03, 2013 | 1998 Buick Century
The "turn signal alert" (signal clicks rapidly,
find which turn signal lamp is out and replace
Nov 14, 2010 | 2001 Chevrolet Tahoe
My son's acer 5738 laptop has a rapid beeping noise when turned on and the keyboard is locked? Can you recommend something? thx
Rapid beeping sometimes indicates a stuck key on the keyboard. check all the keys to see if something is jammed, or if a certain key is not as responsive as the others.
I the keys are not stuck or jammed, and if you are brave enough, remove the bottom pannel and see if you are able to remove the ram. Turn the system on without any ram installed and see if the rapid beeping still occurs.
If the rapid beeping stops with the ram removed, you may need to purchase a replacement.
Jan 17, 2010 | Computers & Internet
Traction systen warning message.The right turn signal also blinks rapidly if turned on,both dashboard grenn turn signal lights also intermittently come together venture 2001.
traction system warning message.The right turn signal also blinks rapidly if turned on,both dashboard turn signal lights also on come together venture 2001.This happens when it is cold raining and the automatic head lights are on and the brake pedal is depressed.
Oct 09, 2009 | 2001 Chevrolet Venture
98 nissan altima front left blinker does not work when headlights are on, works when headlights are off but blinks rapidly ,left rear blinker works when headlights are on or off but blinks rapidly also
the rapid blink is because there is a bulb outage some where, Pull Over turn on left Blinker Get out of your car look at the front left blinker hen walk to the rear of your car and look at the left rear Blinker light then do the same for the right side blinkers if all are working rapidly your left right switch is bad
Jul 09, 2009 | Nissan Altima Cars & Trucks
Left turn signal beeps very fast and signal light not working, now is working fine and so is signal light
When your turn signal goes out it tends to blink VERY rapidly before burning out, It's a nice way to let you know before hand that you need to replace the bulb soon.
Apr 27, 2009 | 2005 Hyundai Elantra
Rear lights work when turned on. No brake lights or rear turn signals. Front turn signals flash more rapidly. Replaced both rear bulbs with no change
if you're getting a more rapid flash in the front you have a possible blown relay to the back. Check fuses first and see if those are out.
Mar 23, 2009 | 1996 Chevrolet K1500
Rapid turn signal
the back light is blown. change it.
Mar 12, 2009 | 2006 Hummer H3
Turn signals flashing rapidly
This fast flash is caused by a burnt out bulb in the front or rear.
Nov 05, 2008 | 1998 Oldsmobile Intrigue
Soyo DYLM1986 Monitor Logo
65 people viewed this question
Top Soyo Computers & Internet Experts
Roy May
Matson Kurian
Matson Kurian
Are you a Soyo Computer and Internet Expert? Answer questions, earn points and help others
