Question about LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard Drive
My LaCie 500GB Quadra spins and clicks. Have tried (Mac) DiskWarrior and Disk Utility, but the drive ignores them and spins, clicks, and the blue light flashes
  • 3,153 Answers
If you can hear clicking then I am afraid there is a serious problem with the hard drive.
The noise you can hear is usually known as "the click of death" when referring to hard drives.
Make sure you use ONLY the cable that came with it or a SHORTER one.
Dont connect via a USB hub
Make sure you only user the power supply that CAME WITH IT.
Most common causes are that the drive unit was dropped or mishandled or just plain old age
There is no known cure unless the data is mission critical
In which case you could sent it to a data recovery specialist but this is usually VERY expensive.
If you are advised to place it in a freezer or anything similar then that is up to you
but my advise would be to run from the person who may give this advise.
This is very old fashioned advice and meant for very old types of drives that used to get very hot.
If it a drive that was / is from an external enclosure then you could still use the enclosure and just place a new hard drive in there.
Another way to test it it to remove it from the enclosure and connect it directly to a PC with a suitable interface eg. SATA or IDE.
Posted on Sep 11, 2009
Testimonial: "Thanks for the quick reply. "
My HD is not that old to have the clicks of death tho I am afraid it is clicking!!! :( when or how can I at the least get my money back!!??
Posted on Dec 29, 2009
I had the same problem with my Lacie Quadra 750Gb. first it made a scraping noise before startup (disk was still recognized by my mac), then it made cliks while spinning and did not appear anymore on my desktop.
tried all ports but that did not work. But what did work:
I took out the Harddisk from the Lacie case (it is a Seagate Baracuda SATA), and put it in the empty internal HD slot of my Powermac G5. It appeared under the original name on my sektop, and I copied the data to the new Lacie I bought immediately....
The disk doesn't seem to make strange noises when placed in the G5 internal slot.
I will check the disk with DiskWarrior the coming days,
but somewhere on the forum I read it might be the power supply.
Paul
Posted on Sep 26, 2009
4big Quadra drive not appearing in disk utility or LaCie desktop manager
Could be defective. Try swapping power cord and usb cable with know good ones. You could also plug it into a different (known working) usb port.
Good Luck
Nov 28, 2013 | LaCie 4TB Biggest Quadra U SATA II Hard...
Lacie 500gb quadra external drive won't boot using USB cables.
Microsoft has had some issues in regard to external devices (especially after running some updates). There is a registry patch for this situation. Click below to install the patch. It should fix your external drive problem. All the best!
Greg
http://support.microsoft.com/kb/925196#fixit4me
May 19, 2009 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
LaCie 500GB external will not show up on mac desktop. Blue light on, whirrs as if working but no icon on desktop (not mounted)
Did you format the drive using Disk Utility? Open "disk utility" from the dock icon or applications/utilities folder. Click the drive name on the left side of the disk utility window. click the "partition" tab in the window, next click the "options" tab and select GUID Partition scheme, or any Mac compatible scheme, read each explanation of the schemes. Name and resize your partitions, click apply. This is how it works running Leopard, not positive if the same applies to Tiger. I hope this helps you
Dec 14, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
Does not mount, Fan not spinning. 500gb D2 quadra
take the drive out and put it in a external case and see if that helps. if not the drive is dead.
Dec 13, 2008 | LaCie d2 Extreme (300793U) 500 GB Hard...
How to format the LaCie 500GB d2 Quadra for Windows XP??
This way it should work...
Connect your drive to the computer...
Go to: Start > Control Panel > Administrative Tools > Computer management.
A new window will appear...
Select Storage > Disk management on the left of the window.
Now you will see the different drives that are connected or part of your system.
One of the drives listed there is your LaCie, i think you'll recognize it by name...
Right-click on it, and select 'format'
In the new window, select the new volume label (as you like it), the file system (use NTFS), and set allocation unit size to default.
Make sure 'Perform a quick format' is not checked...
Then click OK. Your drive will be formatted now... Don't interrupt the process
Mar 31, 2008 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
LaCie d2 Quadra drive... not showing up on PC after working on a MAC
You need to make sure the drive is formatted for the PC. The Mac will read and write to a FAT32 partition, but the PC cannot see a Mac formatted drive as you have seen.
The only problem is that there is a 32Gb limit per partition for FAT32 drives.
It's not ideal but it's the best you can do easily.
Jan 13, 2008 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Don't get it
I notice that you had issues initially installing the drive. Is it possible hat your actions as noted in the link corrupted the HFS+ formatting that was shipped on the drive?
Review this link
If as you noted THIS WAS THE FIRST TIME YOU USED THE DRIVE, you have no data on the drive to loose or recover.
Especially if you believe your actions may have corrupted the formatting of the drive, reformatting may be the appropriate response and could yield a working drive eliminating many return headaches. However if this does not seam reasonable contact with LaCie as to why the drive did not work directly out of the box may be appropriate. (I did confirm in the drive specs that the drive should have been formatted correctly for an apple computer -- windows users need to reformat the drive before they can use it )
I hope this helps
Dec 14, 2007 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Can't accept Quadra 500 on my owerMac G5 Quad
Scrap LAcie!! Sounds like in this case, it may have been jostled around during shipping. None the less, Lacie drives are nothing more than bricks waiting to fail. Go Western Digital, but if oyu can, zip straight for Seagates!!!! Professional grade!! ALways check the cables, the ones that come with them are bottom bin cables, made by little singapore children with no fingers..... Invest in a good cables...a drive is only as good as the weakest datalink.
Cash on the warranty!!!
Keep me posted.
Dec 13, 2007 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard Drive Logo
1,013 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
