Question about Frigidaire 24 in. PLD3465REC Stainless Steel Built-in Dishwasher
The wash pump is leaking, not at the larger joining o-ring seal, but through the vents in the bottom of the motor just past the blade/rotor. Is there a small o-ring inside that is on the shaft that may be leaking? Is there a schematic breakdown of this motor somewhere? I already ordered a new one, and will "play" with the old one to see if I can fix it, just looking for some direction.
  • 5,603 Answers
The shaft seal has failed. Often the top ball bearing becomes noisy after having the water leak through it. The seal is probably a lip seal rather than an O ring.
Posted on Sep 11, 2009
1991 yamaha outboard motor leaking water from bottom
Under The Water Pump Is A Seal Plate Which Has Two Shaft Seals And An Outer O Ring Seal This Is Probably Where Your Problem Lies.
Mar 16, 2013 | Boating
Our fisher and paykel dishdrawer won't wash. It comes up with F1 and flashing light on control panel.
the dynamo dishwashing stuff has caused foaming which reached the base of the dishdrawer unit causing the flood switch to trip. This gives F1 error.
Not sure how much foaming has occured.
Best to turn off power and take power cable out from socket. then empty the drawer using towels. pull out the bottom drawer and wait a day or so to let the foam disappear from the bottom of dishwasher (under the bottom drawer). Connect the power and see if F1 had gone. If not, you need more work. Post a comment based on the above suggestion and I will guide you further if required. Always use Finish dishwasher power only (recommended quantity) as the drawers are small and don't need much detergent.
Dec 27, 2012 | Fisher Paykel Dishwashers
2003 honda shadow 750 ace water pump gasket leaking. Can I replace the gasket only?
There is a round o-ring that seals the water pump to the motor (oil seal). Then there is a shaped cover o-ring that seals anti-freeze into the pump. The cover o-ring is also replaceable. If your pump has coolant leaking it is probably coming from a small weep hole in the bottom of the pump. Check where the leak is carefully, my guess is that the water pump seal is bad and you actually need to replace the water pump assembly. To see a break down of the pump look here.
http://www.bikebandit.com/houseofmotorcycles/2002-honda-vt750cda-shadow-ace-deluxe-black/o/m2894#sch94027
Mar 17, 2011 | 2002 Honda VT 750 CD Shadow A.C.E. Deluxe
Wont build pressure past 60 psi
If you have oil-less type of compressor you may be leaking pressure past cylinder/piston ring or just air leak. Easy to check. Spray soapy water on all connections, first with pressure in tank and motor shut off, then once again with motor running/pumping. Repair as needed. If no leaks remove cover to motor and move piston to top of cylinder and examine condition. If you see scratches neer top of cylinder, then pressure is leaking past vinyl ring. If cylinder looks shiny and smooth and piston vinyl seal looks intact, suspect problem with reed valves or head gaskets. Parts are avilable at sears parts on the web. Good holidays expensive.
Dec 14, 2010 | Craftsman 1 Hp, 4 Gal. Air Compressor
I replaced the motor on my super 2 pump with a new shaft seal. Put it all back together including electrical and now it's leaking from the bottom. I retightened the screws to make sure they weren't loose...
Most likely leaking from either the shaft seal, or the valute seal (big seal plate o-ring). When you replaced the motor you should have also replaced the shaft seal. If not go back and do that whether it's leaking or not. If you get your head down and look at the bottom of the pump while it's running you should be able to see the water coming from the joint between the seal plate, and the seal plate housing, or just behind that from the bottom of the motor probably from the vent holes in the motor housing. If it's coming from the motor then the shaft seal is leaking, and the water is traveling along the shaft and out the bottom of the motor. This will eventually get into the motor and seize up the bearings. If it's coming from the valute seal, then you need to either replace or re-seat the seal. As a general rule you should always replace the shaft seal, and diffuser and seal plate o-rings when you replace the motor or split the seal. I'm not as familiar with the 2 speed hayward super 2, but the standard super 2's have a small ribbon seal, often called a rubber band. They are infamous for going bad especially after pulling the pump apart.
Sep 18, 2010 | Hayward 1 Hp 2 Speed Super Pump Inground...
Pump is leekin water
there are a couple of places where the pump may leak. The discharge fitting, the seal plate o-ring, or the shaft seal. If the shaft seal is leaking, water will be dripping from the bottom of the pump where the motor mates to the seal plate.
Sep 16, 2010 | Sta Rite 1 HP Sta-Rite Pump: 1.5" in/out,...
Leaking where the motor drive and plastic pump join together.
Hi just read your posting.I have had this same problem at a customers house last week.Now the reason the pump doesn't come off is because the motor shaft that turns the pump is corroded, therefore it is jamming the pump on.The only way to get it off is to tap it off with a hammer.Once the pump is removed, clean the motor shaft with sandpaper and refit a new pump.Unfortunately you cant replace the seal on the pump because it is a molded unit.Hope this helps and please reply for further help if needed.
Jun 08, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer is leaking, but I dont know why
Hello, the most likely cause is the pump. Whirlpools are direct drive machines which means they do not have a belt2.gif. The pump is hooked up directly to the motor. To confirm this is the pump tip the machine back so that you can access it underneath. Make sure you wedge something underneath so it does not fall on you. Next take a look where the pump joins onto the motor shaft, this is where you will find the leak. This pump is a sealed unit so you will have to replace the whole pump. You can do this by removing the inlet and outlet pipes. Next with a screwdriver release the 2 clips holding the pump and remove the pump.....reassemble with new pump in reverse order. Good Luck!! If you have any further question's please feel free to comment. Mike
Oct 01, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing machine is leaking water
hi there,
possible leaks can came from mehcanical shaft seal,of agitator shaft and pulley.if worn out
water leak on bottom of machine.
also on water pump inside machine,there is
also mechanical shaft seal within pulley and shaft of impeller blade.worn out also can cause leak at bottom.
maybe on inlet valve of hot and cold water
improper mounting or loosen lock cap on valve
leak can appear.
replacement of shaft seal are lots of work to do in pulling this out,but can be repair depend now on you.how you do it,this should be done by washing machine technician.have a nice day.don;t forget to rate me.thanks a lot
Apr 29, 2009 | Washing Machines
Leaking hot tub motor
hi! there,
well occassionaly leak on pumps this is due to the mechanical shaft seal has been worn out.If you can do fix your self
try to prepare tools to be used mostly set of socket wrench,set of open and closed wrench,pipe wrench one pair,screw driver flat and cross,switch off circuit breaker of pump motor,disconnect elctrical wiring of pump motor,disconnect pump pipe fitting usually on union service fiiting, if pump is free from fitting loosen bolt on pump motor base,pull out pump motor place on a particular working table,have a prepare box to place all bolt to be disconnected on pumps,we have to pull out motor from pumps housing assemblyd217218.jpg
have you seen hydro pump,the motor assembly was couple to pums assembly.thereare 4 long bolts connected holding motor to pump assembly at the back of motor loosen this to disengage
motor and pump assembly,try to put mark on motor back cover
for reference in putting back.if motor is disengage on pump assembly, of course the rotor of motor still connected on pump assembly.
the shaft seal is connected to the rotor shaft inside pumps assembly,there are 4 bolts holding pump casing front cover loosening this will appear the centrifugal blade connected to rotor shafting holiding by a big nut at tip of rotor shaft.loosen this by socket wrench try to find the size,then pull centrifugal blade with
the shaft seal,buy this one with same specification exact value of shaft seal,if there is mistake buying seal either leak again or to tight.shaft549ea12.jpgso this type is just sample to have idea,afterr you purchased put it back and reassemble the pump motor.thi is easy one, have a nice day don't forget to rate me. thank's
Apr 11, 2009 | Home
Frigidaire 24 in. PLD3465REC Stainless Steel Built-in Dishwasher Logo
159 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
