Question about Linksys Wireless-G WRT54G Router
How set up the Linksys WRT 54 g router with primus communication
  • 2,260 Answers
Are you trying to set up router ?
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
Posted on Mar 14, 2010
  • 39 Answers
login to admin page, go to WAN connection setting.
before that , please be ready your primus username and password.
after that save the changes.
Posted on Sep 11, 2009
Client Mode or 2nd Wireless Router with new Subnet Mask?
The original firmware does not have this option, but you can get a custom firmware at http://www.dd-wrt.com/
DD-WRT is not supported by linksys, so a little caution there as this could ruin your router if it is not installed properly. Fortuately they have plenty of documentation on installation and troubleshooting if needed.
Also found this on how to setup Client Mode through DD-WRT - http://www.dd-wrt.com/wiki/index.php/Client_Mode_Wireless
May 20, 2012 | Linksys WRT54G Wireless-G Broadband Router...
Router does not show wireless light. I have reset it but can't access it with the setup wizard. Any suggestions?
* NOTE: If you tried to set-up the WRT-150N Router previously, but failed, with the Router ON, press the "Reset" button on the back panel and hold it down for 10 seconds, then release. This will reset the Router to factory settings and erase all previous data.
then do this :
1. Hook up the Linksys WRT-150N Router to the Modem via a LAN cable.
2. Hook up the Linksys WRT-150N Router to your computer via a LAN cable with the LAN cable in Port #1 on the Linksys WRT-150N Router.
3. Type http://192.168.1.1 in the address bar of your web browser.
4. Log-on to the Linksys WRT-150N Router with these log-on credentials:
Username: linksys (lower-case)
Password: admin (lower-case)
5. Click on the "Clone PC MAC Address" tab.
6. Click the "Clone PC MAC Address" button.
7. Click "Save", click "Continue".
8. Click the "Wireless Security" tab.
9. Choose "WPA2 Personal - TKIP/AES" for encrypted security.
10. Enter encryption password (passphrase).
11. Click "Save", click "Continue".
12. Exit the web browser.
13. Disconnect the LAN cable from the computer and Port #1 on the Linksys WRT-150N Router.
In about 5 seconds, your wireless connection should be up and running.
Sep 15, 2010 | Linksys Wireless-N WRT150N Router
Hello, I have a Linksys Router model No. WRT 160N and have problems with the wireless signal. Doesn't appear the wireless symbol ON and I have connected already the modem cable. The modem is OK cuz I can...
* NOTE: If you tried to set-up the WRT-160N Router previously, but failed, with the Router ON, press the "Reset" button on the back panel and hold it down for 10 seconds, then release. This will reset the Router to factory settings and erase all previous data.
Then do this
1. Hook up the Linksys WRT-160N Router to the modem(cable, DSL or satelitte)
2. Hook up the Linksys WRT-160N Router to your computer via a LAN cable with the LAN cable in Port #1 on the Linksys WRT-160N Router.
4. Log-on to the Linksys WRT-160N Router with these log-on credentials:
13. Disconnect the LAN cable from the computer and Port #1 on the Linksys WRT-160N Router.
Sep 15, 2010 | Linksys WRT160N Wireless Router
Linksys wrt 120n connected but can't browse
Check your computer's browser settings, make sure it's getting valid IP address, try pinging a website and check your IP settings under network connections.
Disable any third party firewall software you have installed.
Hope this helps!
Jul 20, 2010 | Linksys WRT120N Router
Need to reset to factory default a linksys wrt 54
Push and hold the reset button in for like 1-2 minutes then release it, it should reset the settings to default
Oct 15, 2009 | Linksys WRT54GX2 Wireless-G Broadband...
BRIDGING MODEM AND ROUTER
Your firmware may not support bridge mode, try installing dd-wrt from http://dd-wrt.com/dd-wrtv3/index.php
Aug 19, 2009 | Linksys Wireless-G WRT54G Router
My linksys wireless-g router hangs up all the time and I m ust power on and off to get it to reconnect
I even have experienced such kind of problem. To fix this problem all you have to do is to download a new firmware, which is an opensource firmware from DD-WRT it has much more features than the ordinary firmware and its much more stable.
Then after upgrading just make sure that you put the option for Keep Alive enabled and try and restart the router like once per day so that it does not clog up.
That will solve your problem. The DD-WRT website is www.dd-wrt.com
Have a good day.
May 12, 2009 | Linksys Wireless-G WRT54G Router
Router only allowing 10mbps
The best and simple method to do is to do a hard reset of the router so that the factory default settings are put back.
If after that it still doesnt work check the QOS may be the port is set to use upto 10mbps only.
If not that then just upgrade to a firmware like tomato or dd-wrt they are very nice firmwares i personally use dd-wrt and its the best.
Feb 19, 2009 | Linksys Wireless-G WRT54GS Router...
I have problems with installing Linksys wrt 54 gl wireless router
i will need more information to help you with this. but since this is a new router, you definitely have a modem, chances are you'll have to bridge the modem first for you to be able to use your linksys router
default username is blank
default password is admin
check with your ISP if your connection type is DHCP or PPPoE
if it's PPPoE, you'll need to configure your router, you need to put in your username and password for your ISP inside your router's GUI or main interface page
Jan 28, 2009 | Zyxel Prestige P-330W Wireless Router...
3rd party firmware broke my router!
did you check whether you have downloaded the correct firmware for your linksys???
Dec 02, 2007 | Linksys Wireless-N WRT150N Router
Linksys Wireless-G WRT54G Router Logo
416 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
