Question about Acer Aspire One PC Notebook
Aspire one sytem32 drivers ntfs.sys missing or corrupted
Here goes in detail PLEASE try not to get confused..lol 2 days ago I downloaded SPYBOT SEARCH AND DESTROY off CNET.COM ..I set it up and ran the scan and immunized it didnt show any infection ect.. durring set up it did say something about may delete some stuff but it gave you the option about recovery... blah blah blah well I have cut off my comp and restarted many times in past 2 days ..Except last night after I downloaded that MSN messenger ...... when I cut my comp on it started up normally went to my logg in Blue screen were you hit the little block screen name to continue...Well I couldnt cause my block was missing ..Said wtf so I was like maybe a glitch so I decided to restart ..Well it said ..."Someone else it currently logged in and or being used by another person restarting might cause the loss of info"" SOMETHING TO THAT AFFECT ..Well I restarted and started up like it usually does with the ASPIRE black screen were it has the hit F12 or F2 to perform certain functions in white down at bottom then it skips to the plain black screen were it does this llllllllllllllllllllllllllllllllllllllll in white accross the bottom like its booting up .. then screen goes black for a few min then this message appears.............The aspire one doesnt have a cd rom and im unsure how to fix it and the steps I explain above about the screens just repeats and says the samething over and over please help Windows could not stat because the following file is missing or corrupt......System32\Drivers\Ntfs.sys You can attempt to repair this file by starting Windows Setup using the original Setup CD ROM. Select ' r ' at the first screen to start repair
    Problem Solver:
  • 8 Answers
Try this site. It may give you some options. Good luck.
http://www.geekstogo.com/forum/system32driversNtfs-sys-t53329.html
Posted on Sep 11, 2009
  • 32 Answers
It sounds like your system files are missing or damages. Its unlikely it has to do with using spybot, but always possible. The first thing to try is see if you can do a system restore in safemode. Push F8 right before the windows splash screen comes up, you can press it several times to make sure it registers at the righ time.
When it gives you the boot options choose safe mode, and see if it logs in. If so go to programs, accessories, and choose system restore.
If that doesnt work you will need to do a windows repair, which will require a cdrom drive. Sometimes you can just copy the ntfs.sys file from another computer or the windows cd and it will work, but other times if windows is missing that file, it is missing others as well.
Posted on Sep 12, 2009
2 Suggested Answers
parrotheadpc
  • 2600 Answers
SOURCE: sysytem32 driverntfs missing or corrupted
If you have Vista, reboot the laptop with the vista disc in the drive. When the computer starts and you see the Acer splash screen you may have to hit F12 to get to the one time boot option and choose the cd/dvd drive...this will force the laptop to boot off the disc and not the hard drive. When the disc loads you will see a message that says "To boot off cd hit any key" touch a key and let windows boot. Once it boots it will ask you what you want to do. you first click on the next tab when it shows you the language screen, then you want to choose repair and it will tie in to the current Windows installation. When it does, click ok or next and windows will try to "heal" itself so it will boot up correctly. Once it finishes its repair, it will give you more choices. Choose to exit out and reboot the machine without the disc in and see if you boot correctly. If you do not repeat the process as before but when you are given a drop down menu of choices, this time pick restore. Look for a restore point that was before you downloaded and installed SpyBot....choose that restore point and let it do its thing....if you are successful....stay away from SpyBot.....iy is nothing but trouble.
System32 drivers ntfs sys
To resolve this problem, replace the missing or corrupted Ntfs.sys file:
  1. Use the Windows XP startup disks or the Windows XP CD to restart your computer.
  2. When the "Welcome to Setup" screen appears, press R to select the To repair a Windows XP installation using Recovery Console, press R option.
  3. Type the number of the Windows installation that you want to access from the Recovery Console, and then press ENTER.
  4. Type the administrator password when you are prompted, and then press ENTER. If no administrator password exists, just press ENTER.
  5. At the command prompt, type the following commands (press ENTER after each command):
  6. --->cd \windows\system32\drivers
    --->ren ntfs.sys ntfs.old
    Note This step renames the corrupted Ntfs.sys file to Ntfs.old. If the Ntfs.sys file is not found, the file is missing.
  7. At the command prompt, type the following command, and then press ENTER:copy cd:\i386\ntfs.sys drive:\windows\system32\drivers
    Where cd is the drive letter for the CD-ROM drive that contains the Windows XP CD, and drive is the drive where you installed Windows XP.
  8. Remove the Windows XP CD from your CD-ROM drive, type quit at a command prompt, and then press ENTER to quit the Recovery Console.
  9. Restart the computer.
May 17, 2014 | eMachines Computers & Internet
Windows did not start ,drivers missing
  5. At the command prompt, type the following commands (press ENTER after each command): cd \windows\system32\drivers
    ren ntfs.sys ntfs.oldNote This step renames the corrupted Ntfs.sys file to Ntfs.old. If the Ntfs.sys file is not found, the file is missing.
  6. At the command prompt, type the following command, and then press ENTER: copy cd:\i386\ntfs.sys drive:\windows\system32\driversWhere cd is the drive letter for the CD-ROM drive that contains the Windows XP CD, and drive is the drive where you installed Windows XP.
  7. Remove the Windows XP CD from your CD-ROM drive, type quit at a command prompt, and then press ENTER to quit the Recovery Console.
  8. Restart the computer
Mar 03, 2011 | Computers & Internet
Ntfs is missing
  1. Use the Windows Vista startup disks or the Windows Vista CD to restart your computer.
  2. When the "Welcome to Setup" screen appears, press R to select the To repair a Windows Vista installation using Recovery Console, press R option.
  6. At the command prompt, type the following command, and then press ENTER: copy cd:\i386\ntfs.sys drive:\windows\system32\driversWhere cd is the drive letter for the CD-ROM drive that contains the Windows Vista CD, and drive is the drive where you installed Windows Vista .
  7. Remove the Windows Vista CD from your CD-ROM drive, type quit at a command prompt, and then press ENTER to quit the Recovery Console.
  8. Restart the computer.
  9. rate me 4 thumbs up please
Jan 10, 2011 | Microsoft Windows Vista Home Premium with...
Acer Desktop Veritron M460 will not load Windows XP or Vista!
This problem may occur if the Ntfs.sys file is missing or becomes corrupted when you convert your hard disk to NTFS To resolve this problem, replace the missing or corrupted Ntfs.sys file:
  6. At the command prompt, type the following command, and then press ENTER: copy cd:\i386\ntfs.sys drive:\windows\system32\driversWhere cd is the drive letter for the CD-ROM drive that contains the Windows XP CD, anddrive is the drive where you installed Windows XP.
  8. Restart the computer.I hope this helps.The other thing I can think of is maybe your harddrive needs a raid driver.If this is a sata drive and an old version of you os,the sata driver may not be already on the disk and you will have to insert one.Let me know if the first solution works,if not we can try the raid driver.
Apr 08, 2010 | Acer Veriton M460 Micro Tower Core 2 DUO...
I get the blue screen of death whenever I try to use my VC500 One-touch Capture Card. An hour ago, the card was working fine, but 10 minutes ago my whole computer started to get really slow once I...
The first thing I would try to do, is to download the latest drivers from the website and see if that helps.
if the computer is going really slow, you might also have spyware or virus, you may want to check for that.
you can download spybot search and destroy at www.safer-networking.org
or spybot at www.lavasoft.com
they are both free
you can also d/l antivirus software at www.eset.com good for 30 days
thanks
Feb 05, 2010 | Diamond Multimedia ( VC500) Video Capture
Sysytem32 driverntfs missing or corrupted
Sep 11, 2009 | Acer Aspire One Netbook 8.9" Notebook
I am having trouble running setup on my desktop
Aug 28, 2009 | Computers & Internet
It can run at booting time my computer not working
Yepp, you can repair it, yous boot up from you windows disk and you will coma to a spot when you will be asked to install or repaire you OS, select repair and windows will install that corrupt or missing file
Nic
Feb 10, 2009 | Microsoft Windows XP Professional
Hard drive backup
This seems to be a good article on ASR backup and how to eliminate your error message.
See Link
Dec 16, 2007 | Dell Latitude D600 Notebook
System32.ntfs is missing and corrupt
Boot into recovery console, and at the c:\windows prompt type: cd system32 cd drivers ren ntfs.sys ntfs.old If the ntfs.sys file is there and corrupt this will rename it. If it is not there, then it was missing. At the prompt type: copy e:\i386\ntfs.sys c:\windows\system32\drivers\ntfs.sys good luck
Mar 19, 2006 | Apple Power Supply 344 Watt PowerMac G4...
Acer Aspire One  PC Notebook Logo
794 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
