Question about HP Officejet 7210 All-In-One InkJet Printer
Printer not working
The printer keeps saying Remove and check right cartridge. I have done that several times and even purchased a new cartridge and nothing happens.
  • Anonymous Dec 17, 2007
    I change black cartiage but it keeps saying inster black cartage in right stall
  • 3 Answers
We also had the same problem. We remove the black cartridge, placed a small machine screw or bolt where the head would hold the spring in place. Make sure the head is flat enough so that it will not push the cartridge to the left and cause it to print erratic. You might need small hands to screw on the nut for your bolt. I now prints and faxes, just the LED panel still says to check the right cartridge.
We can live with that!!
Posted on Jan 23, 2008
Did you get this fixed?
Posted on Dec 20, 2007
My hp all-in-one printer keeps saying , remove and check color cartridge we've done this and even purchased a new cartridge and still the same message appears. Whats wrong! Do I need a new...
I would check the area that the cartridge and printer connect together (where they make the electronic communication) have a look if there is anything stopping the 2 from connecting correctly. Also, getting your hoover in there and giving it a good old clean can often solve a lot of problems too.
Jan 27, 2011 | HP OfficeJet 6210 All-In-One InkJet...
Remove and check cartridge on right. I have removed it several times but still comes up with message and will not work
All I did was replace my black ink cartridge with a new one and it works. You think it would say replace ink cartridge instead of remove and check cartridge on right. Good Luck.
Aug 14, 2010 | HP OfficeJet 7310 All-In-One InkJet...
Error message says "Remove and check cartridge on right" Its a new cartridge I've been using for a few weeks and it has been working fine. I have removed cartridge several times and even cleaned contacts....
The electronics on the cartridge have gone bad. Sometimes cartridges short. Take the cartridge back to where you bought it (they should give you credit for any remaining ink) and buy a new cartridge.
Aug 10, 2010 | HP Photosmart C4180 All-In-One InkJet...
Message says: remove and check right cartridge.
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink or toner cartridge?
Please consider the following:
If you are using a refilled or third party cartridges that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks or toner causing problems with print quality or damaging the physical printhead or photo conductors.
If you are using factory new ink or toner cartridges, then please call the manufacturer’s Technical Support for assistance with the warranty on the cartridges
Don
Feb 19, 2010 | HP OfficeJet 4215 All-In-One InkJet...
New tri-color cartridge has a problem. I can't see what.
I have an HP Photsmart C4100 printer. I purchased remanufactured ink cartridges (both black and tri-colored) from Vivasmart. The black one works fine, but when I installed the tri-color, I got an error message that says "Print cartridge problem" The following print cartridge has a problem:
Tri-color.
And I can't print. The screen on my printer says "Remove and check color cartridge." I have done this several times and it still won't print. I have turned off the power, removed the cartridges, and unplugged the unit, but it still didn't help. Any suggestions?
Jul 21, 2009 | HP PSC 1510 All-In-One InkJet Printer
My hp 7410 printer says ''remove and check cartridge on right'' I did this several times and even bought a new one'' I does not work. I tried cleaning it, it does not work. I have always used HP cartridges...
My hp 7410 printer says ''remove and check cartridge on right'' I did this several times and even bought a new one'' I does not work. I tried cleaning it, it does not work. I have always used HP cartridges for the printer which is over a year old. How can I fix this problem?
Jul 11, 2009 | HP Office Equipment & Supplies
Remove and Check Cartridge
One of the cartidges you have purchased is faulty.
you can reinstall the empties one at a time as a process of elimination to determine which new cartridge is the problem
Jun 06, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Toner/drum problems
This seems to happen some of the time. Brother has an FAQ for this:
1. Verify the toner cartridge is installed correctly by following the
steps listed below:
a. Open the front cover.
b. Lift the drum unit slightly and pull it out. Place the drum unit on
adrop cloth or large piece of disposable paper to avoid spilling and
scattering the toner.
c. Remove the toner cartridge from the drum by holding down the lock
lever (blue tab) on the left side of the drum unit and lift the toner
out.
*Handle the toner cartridge carefully. If toner scatters on your hands
or clothes, immediately wash it off with cold water.
d. Gently rock the toner cartridge from side to side five or six times
to distribute the toner evenly inside the cartridge.
e. Place the toner cartridge into the drum (be sure it clicks into
place).
f. Clean the primary corona wire inside the drum unit by gently sliding
the blue tab on the top of the cartridge from right to left several
times. Return the blue tab to the home position before reinstalling the
drum unit assembly.
g. Reseat the drum unit into the machine.
h. Close the front cover.
2. If the message "Toner Life End" continues to appear on the display,
contact Brother Customer Service at 1-877-Brother (276-8437) Monday
through Friday, 9:00am - 7:00pm EST, excluding holidays.
May 12, 2008 | Brother MFC 7420 All-In-One Laser Printer
Printer problem
hi,
have you tries inserting new set of ink cartridge???
try this...
> unplug the power chord.
> remove the rear access door.
> check for any jammed paper. if so remove it.
> clean the rollers using a lint free cloth.
> close the rear access door.
> keep pressing the on button for 20 seconds
> try to copy
if no go
> unplug the power chord while it is turned on
> remove the cartridges
> press and hold the ok and cancel button at the same time.
> while holding them insert the power chord, and wait for few seconds and then release your hands.
> when it asks for the ink cartridge, insert them ad check.
if no go, contact me
thanks and regards
agnel
Mar 17, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP Officejet 7210 All-In-One InkJet Printer Logo
114 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
