Question about Toshiba 61HX70 61" Rear Projection Television
No picture is it the bulb and is this hard to change?
    President:
  • Toshiba Master
  • 1,779 Answers
You DO NOT have just a bulb in your set. You have the older style Projection TV with three picture tubes. It's a good possibility that you have a convergence issue that has blanked the raster and therefore you will not see a picture until the error is corrected. Have it looked at by a qualified technician.
Posted on Sep 11, 2009
Change the bulb on NCE v260X and I still have white snow flake when I turn it on
Have you adjusted the contrast and Keystone. A new bulb should be plenty bright. Maybe clean the lens. There is in some types of Projectors a color wheel inside this can become dusty. But not often if you keep the filters in place and clean them. This could cause a snowy picture as well. Hard to say without actually seeing the picture to say what the issue could be. But these are some of the stronger possiabilities.
Sep 30, 2014 | NEC NP-V260 DLP Projector
Projection TV no picture
Hard to see picture. 3 possible solutions (1) the lamps are out of
alignment (2) the settings on your picture needs to be changed in your menu or (3) the bulbs need to be replaced.
If its the bulbs and your tv is under warranty great if not it is cheaper to buy a new projection. The bulbs are about $200-250 a piece and there are 3 in most units sometimes 4
Sep 30, 2012 | Televison & Video
Picture went off while watching toshiba projection tv.
The projection TVs use a bulb that will get progressively dimmer (hardly noticible) and then one day just burn out. You need to get the model # of the TV and source a replacement bulb and change it.
Hope this helps,
Thanks!
Jan 20, 2010 | RCA Televison & Video
Projection television picture trouble
picture tubes are fine. just need to change out coolant
Oct 26, 2009 | Philips Magnavox 51MP392H Rear Projection...
How do i change the bulb
if they are lcd, or dlp projection tv's then there will be an access door on the side, front or back that is easy to access and would require only a philips or standard screwdriver to replace. if they are a tube type rear projection tv, then they don't have bulbs, they have picture tubes, in which case you could not change them yourself, but you would not need to, because picture tubes hardly ever go bad.
Sep 07, 2009 | Televison & Video
Dark picture on wega lcd
Yes, if this TV has a bulb it is likely to be the bulb.
I am not familiar with this exact model, but other LCD Projection TV will show dim picture after some time. Expected life of the lamps is about 2yrs. After 2yrs the picture will become dim. After 5yrs I am suprised it is even working.
Dirt doesn't cause this problem unless your are a smoker or have the unit "literally" outside. DO NOT try to clean it or let someone tell you to do it because it will cause more problems than it fixes.
May 07, 2009 | Sony Grand WEGA KF-42SX300 42" LCD TV
Change turn signal bulb 02 S60
ok this is what you do,unplug the two vaccum hoses at the back of the air filter box, pull up the air filter box,dont worry it wont break,give it a quick tug upwards on the four corners,now you can get enough room to change the directionals.NOTE: changing bulbs would not solve your problem because after a couple of weeks or so you will get that turn signal warning again,your best bet is to change the turn signal socket (its about $15.00) at the dealer.,you get the new socket and bulb all in one,do both sides if you can afford it because after a couple months the other side also goes.
Sep 14, 2008 | 2002 Volvo S60
Hampton Bay CF No Model #!!!!
I had this exact same problem at an apartment i lived in awhile back. Unfortunately, there IS no was to change speed or direction. It is a one-speed, one-way fan. Sorry for the bad news.
May 31, 2008 | Hampton Bay 04345 Cruiser Ceiling Fan
Is my bulb going bad!!!!
Without seeing your Tv it is hard to say what is really going on.
The cloudy picture sounds like one of your "bulbs" needs to have it's fluid changed, not "bulb" replacement.
Rain bowing normally means convergence adjustment or circuit repair is needed.
May 25, 2008 | RCA P52926 52" Rear Projection Television
DLP TV Blown Bulb: LG RE44SZ21RD
what kind of tv do you have I need that info so I can help you
Apr 10, 2008 | Televison & Video
Toshiba 61HX70 61" Rear Projection Television Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
