Question about Sony VIAO P4 PCV-RS712 3.0GHz 512MB 200GB DVD RW DVD BRAND PC Desktop
Screen when i boot the computer the screen goes bkack
  • Sony Master
  • 32,281 Answers
I assume your computer boots up, the hard disk spins and the hard disk LED light flashes.
If so then you may have a defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
Posted on Sep 11, 2009
Acer Aspire 4720z will not boot at all bkack screen no sounds
Isolate possible problems one by one.
1. Check power adaptor if LED is on. If on, it "might" be working. The wire from the power adaptor might be problematic but we have no way of checking this unless you disassemble the power adaptor and test it for continuity.
2. If power adaptor is ok, take out the battery and connect power adaptor to unit. Turn on laptop. Indicator LED on the unit near the infrared port on the front of the unit should light up.
3. If power is not the problem, unplug unit.
4. Open back panel and try cleaning the memory modules. Take them out and rub rubber eraser on the modules' connectors.
5. If it still doesn't boot up, bring to qualified service personnel. The motherboard may be problematic.
Jun 26, 2014 | Acer Aspire 4720 Notebook
My computer screen goes black whe i turn it on
It would be helpful if you posted the Make, Model and the OS you are using. Does it boot? Can you boot to Safe Mode? Have you checked ALL cables? Do you get anything on the screen? Fans spin? LED's Blink at boot? Sound? Need more info.
Mar 13, 2013 | Computers & Internet
I am using a lenovo all in one ideacentre computer. The screen goes black for a few seconds then comes back
The screen goes black then comes back. When it comes back are you able to use the computer without any problems? When does this happen? Most times during the boot process the screen will fade in and out.
If this is not happening when you boot the system it's possible that your lcd screen might be going bad so keep an eye on it.
May 31, 2012 | Computers & Internet
I cannot get my computer to boot. It just goes to a black screen after the acer logo and then the Microsoft loading screen comes up and then goes back to the black screen and that's it. I tried system...
This is a hard drive issue, remove hardware and reseat it back into place, sometimes this will work and run fine. But it is more than likely your hard drive will need to be replaced.
Mar 06, 2012 | Acer Computers & Internet
Can't boot computer. Goes to
you need to boot from windows XP OR wimdows vista depent what operative system you have.
Aug 15, 2009 | Acer Aspire 5100 Notebook
Computer keeps returning to "safe mode" options screen
If you choose Start Normal and it boots into safe mode again then you should get professional help if you value any of the files on your computer and don't want to loose any data.
Jun 01, 2009 | Sony VAIO VGC-V617G PC Desktop
Inspiron B130 won't boot
plz try to boot through safe mode, if you can then log in normally.
if you cant boot from safe mode then you have to reload or repair your os.
Dec 23, 2008 | Dell Inspiron B130 Notebook
My computer boots up but the screen goes black
its yuor grafic card its not good you need a new card.*** pedro aguiar lisboa portugual some probleme sen-me a mail for enderess pedro_aguiar1040@hotmail.com
Dec 17, 2008 | E-Machines eMachines Desktop PC
Blank screen with intermittent operation
you have bad capacitors in the power board inside the monitor replace these and the monitor will work fine
Dec 09, 2008 | ViewSonic Optiquest Q9b 19" Flat Panel LCD...
Computers & Internet Logo
105 people viewed this question
Top Sony Computers & Internet Experts
Martin Murray
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
