Question about Opella 2-3/8" Push-Push Drain Assembly OPELLA 90135.110
I have a new push push drain from mac faucets, and it leaks. I have reversed the rubber gasket that goes under the sink (held on by the brass threaded ring assume that I don't use plumbers putty under the top ring, as it has a nice small rubber gasket.
  • 530 Answers
The order of installation starting from the top side is the flanged drain then a bead of plumber's putty, and don't skimp on the putty. On the bottom side, first the rubber gasket then the metal washer, finally the locking ring. You must use the plumber's putty between the sink\tub surface and the flange. My mom thought the same thing. She return her drain twice before she asked me why it was leaking:)
Hope this helps.
Posted on Sep 11, 2009
Blanco Supreme 533-U sink drain leaking at seal
The sink basket/strainer that fits into the large hole of the sink should have either a bead of silicone sealant applied to the sealing lip of the assembly or a ring of plumbers putty. Silicone will work very well if the mating flanges are clean and dry.
With the baket in place, the rubber seal goes between the large nut and the sink. A bead of silicon on this is optional on the sink side of that rubber seal. and the nut tightened down snug , forcing some of the silicone out fro beneath the mating flange and rubber seal. Tight enough so the basket is not free to move. Be it plastic or brass/metal, that order is the same, only a plastic nut is not tightened as tightly as a metal nut would be.
On the bottom of the drain basket assembly there is a nut, to retain a plastic or brass tail piece. The plastic tail piece will have a polyetheylene "flanged washer" for a seal to the bottom of the sink basket. If it is a brass tailpiece, a rubber seal and metal nut is used with "pipe dope"/thread sealing compound used on the threads of the metal nut. With the plastic nut, you can apply a few wraps of teflon tape to the threads of the drain basket, but is not required in most cases as the poly flanged washer will form the seal. The plastic nuts should not be tightened any more than hand tight.
beneath that, the rest of the drain assembly attaches. If plastic- no more than hand tight. if metal, only about 1/4 turn past hand tight. Metal nuts and parts should use rubber gaskets/seals and the plastic parts should only use the poly tapered/lip seals.
Jan 15, 2012 | Plumbing
How to remove "cover" on faucet for drain
under the sink there is a rod that screws into the back of the drain pipe right under the bowl of the sink unscrew the nut holding the rod in and the drain plunger will pull up
Sep 24, 2011 | Moen 1 Handle LavatoryWith Drain Assembly...
I can't get the faucet to not move from side to side after it is tightened donw on the granite vanity top. The base is tight and does not move, but the faucet part still moves a little. How can this be...
The faucet should have come with a rubber gasket which goes between the faucet body and the granite top. Make sure it's properly aligned and has not slipped out of place. Be carefull when tightening the faucet to the granite, since granite is easily cracked.
Aug 10, 2010 | Moen 6102AZ Kingsley Single Handle...
How do I install the Moen 10790 Lavatory Faucet drain assembly brass Chrome
This in link below had a detailed instruction on how to install your drain.
http://www.ehow.com/how_2342611_install-sink-pop-up-drain.html
This link below has a parts view of how it goes together. If you will look the waste seat will be the peice that will go in your sink up top and everything esle underneath.
http://www.plumbersurplus.com/pdf/02535.pdf
Jun 20, 2010 | Moen 10790 Lavatory Faucet drain assembly,...
My daughter pushed down on the plug & now it doesnt pop up!! lever at back doesnt work as the suction is so good!
drain assembly can be taken apart from under the lav. first loosen the stopper lever assembly. then proceed to loosening up the slip-nut on piping nearest to the drain. The drain is held to bottom of sink by a nut tightened to a thick rubber washer. Remove nut and remove drain. Dislodge stopper. Replace drain with fresh plumbers putty, underneath lip of drain where it makes contact with inside of lav. Reassemble drain piping and lever.
Mar 16, 2010 | NRS Cascade Brix single hole lavatory...
I have never done it before, so I need step by step directions in removing an old blanco single handle faucet and now putting in the new one
Turn your water supply off to the existing faucet.
With a crescent wrench and plyers remove the supply tubes from the shut off valves.
Unthread the sprayer hose that is attached to the brass connector under neath your faucet in the cabinet.
Unthread the lock nut and fastening plate which is on the same brass fitting as your spray hose.
Remove faucet from the sink.
Reinstall the new faucet in the reverse order.
Feb 25, 2010 | Blanco Classic Single Handle Faucet with...
Opella 2-3/8" Push-Push Drain Assembly OPELLA 90135.110 Logo
150 people viewed this question
Top Opella Plumbing Experts
Donni Steen
Tom Chichester
Are you an Opella Plumbing Expert? Answer questions, earn points and help others
