I have an emachine 750 withintel pentium4 1.7ghz skuNo;583142 s/nque24 201 01812 fitted pc2100ddr...
(More)
I have an emachine 750 withintel pentium4 1.7ghz skuNo;583142 s/nque24 201 01812 fitted pc2100ddr memory. I would like to obtain a maual for this model. can you please help?
My PC won't start on its own when cold. When I press the ''ON'' button, the power supply will turn...
(More)
My PC won't start on its own when cold. When I press the ''ON'' button, the power supply will turn on, the fans and hard drives will turn over, and the hard drive light will light for about one second. Then everything goes dead, as if I turned the power supply switch off, except the power light stays on. I have found that blowing hot air from a hair dryer into the back of the power supply for about 10 seconds before pressing the ''ON'' button is all that's necessary for a normal start, but I'm tired of having to do this. I operate the computer in a room that is non-humid, and about 67 degrees F. I'm on my second power supply, which is an Antec Neo HE550 (550 Watts). With the previous power supply, the PC behaved in the same way, only it didn't take a hair dryer to start. With the old power supply, it only took a two or three presses of the ''ON'' button before the PC finally started. My motherboard is an Intel D865PERL, and I'm operating with Windows XP, two hard drives, one floppy drive and one DVD ROM drive. I have a volt meter and have measured the 5 and 12 Volt levels on the power supply. They are right on the money. Is there a temperature sensor somewhere in the power supply or on the motherboard that shuts everything down when it senses the air is ''too cold'' for the PC to operate?
the topmost screw of my PC cabinet is jammed in its place and is not turning. the screwdriver is...
(More)
the topmost screw of my PC cabinet is jammed in its place and is not turning. the screwdriver is just slipping over it no matter how much pressure i apply+
I have owned the Hp Pavilion A808 for many years, with an Acer AL1711 monitor. Last night I rebooted...
(More)
I have owned the Hp Pavilion A808 for many years, with an Acer AL1711 monitor. Last night I rebooted the machine and when trying to log in the wireless mouse and keyboard do not work, I change the batteries and resync several times - nothing. This morning I try to reboot and this time the monitor shows only the splash screen ''Acer'' then it says ''no signal''. I have tried using the monitor on another PC and it works fine, so im guessing I have a computer related issue.
