Question about Oster 12-Bottle Wine Cellar - Black
Not cooling anymore
I have Oster 12 bottle wine cool 0W0912H6H. I just noticed that the temp is reading 89 the control panel still works however I notice that there is no more sound (not running) If it is the compresser - where do I purchase one and is it difficult to install
5 Suggested Answers
SOURCE: oster 12 bottle wine cooler
I have the same problem. my oster 12 bottle wine cooler was only six months old. the temp of the cooler won't drop. stay at least 80 F and up. Bestbuy don't even carry this product anymore.
Posted on Sep 07, 2008
  • 7 Answers
SOURCE: Fan doesn't work on oster wine cellar
First question, do you have power to the unit and the cooling fan is not working? If this is the problem then sounds like one of the two fuses in back panel has burnt out.
Posted on Feb 23, 2009
SOURCE: No response from company on Oster 12 bottle wine refrigerator
just replace the 5amp fuse on circuit board with a 6.3amp. tada!
use an exacto knife to remove the shrink wrap on both ends of old fuse. heat ends with a soldering iron and pull away old fuse. solder new 20mm in line fuse holder from radio shack to both poles insert 6.3amp fuse and done. at least mine works again! $6.00 total cost!
Posted on Apr 19, 2009
  • 82 Answers
SOURCE: oster 12 bottle wine frig, how to set temp instructions please
I suggest you return that puppy as fast as you can.
The company that makes them took bankruptcy and warranties are no good.
To top it off the fans usually **** out in 6 mos or so.
Posted on May 15, 2009
My wine cellar (Model: ow0912H6H) still runs but it does not cool. What can I do? I don't believe that there is a compresser in ot. I don't know what cools it.
I had the same problem and noticed that the lint screen behind the cooler was full of lint where it was almost completely clogged. I vacummed it and it seems to have done the trick.
Feb 19, 2010 | Oster 12-Bottle Wine Cellar - Black
COOLER IS GETTING POER BUT NOT COOLING. TEMPERATURE CONSTANTLY SHOWING 72 DEGREES.PLEASE SUGGEST TROUBLE SHOOTING. #K0700305460011335 MODEL: OW0912H6H
Check the lint trap behind your cooler to make sure it isn't clogged... I had the same problem and after vaccuming the lint trap, my cooler started cooling again
Feb 06, 2010 | Oster 12-Bottle Wine Cellar - Black
I have an Oster 12-bottle wine celler model OWO912H6H that was a Christmas gift in 2007. I just noticed the temperature is 98 degrees and I cannot get it to come down with the down button. I am very...
Hi, could be faulty thermostat, can you check compressor, is compressor running (working), listen to compressor for clicking sound, unplug it(switched off) for about 20 minutes, replug and let it run (work) for another 20 mins. see if temp. drops, what about temp. inside bottle (wine) cooler, is it 98 or colder, more info. could be valuable. check thermostat, check to see if compressor operates, if cooler temp. 98. remove you products, to another cooler, call mechanic.
Aug 12, 2009 | Oster 12-Bottle Wine Cellar - Black
Wine Cooler Does NOT get cool.
Here is the web site to locate your closest oster service center. They should be able to tell you what their charge will be up front so that you can compare that charge to the cost of a new one.
Now days, sadly, many of these items are too costly to repair so they go to the landfill..
http://www.oster.com/CustService.aspx?content=center
May 21, 2009 | Oster 12-Bottle Wine Cellar - Black
Oster 12 bottle wine frig, how to set temp instructions please
May 15, 2009 | Oster 12-Bottle Wine Cellar - Black
Will not cool
HI,
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
any further question let me know.
thanks,
Mar 22, 2009 | Oster 12-Bottle Wine Cellar - Black
Don't cool-no refund/satisfaction from Oster.
Ok, fist problem was unit quit working..if it quit cooling yet lights still worked inside and still had power readings on door is not power coord. If the unit stoped cooling is probably fuse and there are two of them in back of unit. One fuse clearly can be seen, the other is coated with a black shrink fit coating and is not well seen. This second fuse is the problem, you will need to replace it. I have same unit and this is what I had to do to get it cooling again.
Jan 21, 2009 | Oster 12-Bottle Wine Cellar - Black
Dec 30, 2008 | Oster 12-Bottle Wine Cellar - Black
The fan does not go on
Ther are two fuses in back panel of unit. One fuse can be seen other is hidden top left of panel and is coated in black shrink rap. I had to replace that fuse to correct the problem. Problem is I had to cut away shrink rap and resolder another fuse, you may have to have someone who can do this look at your uint. Hope this helps.
Dec 19, 2008 | Oster 12-Bottle Wine Cellar - Black
Oster 12 bottle wine cooler not working, no fan temp running high. What could be the problem?
Well... the best solution is use it for parts and toss the rest in the trash. Go to any web site that sells it and has reviews, read the reviews, and you will see why I came to this conclusion. I got one free on FreeCycle.org. After reading reviews decided it was not worth fixing. She had dropped the one I had, door broke. Basiclife.com
Jun 21, 2008 | Refrigerators
Oster 12-Bottle Wine Cellar - Black Logo
53 people viewed this question
Top Oster Furniture Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
jasbo
jasbo
james laughton
james laughton
Are you an Oster Furniture Expert? Answer questions, earn points and help others
