Question about Boating
Alarm/buzzer going off without shutting off
What is making a small round buzzer go off under the dash of my 2002 bass tracker pro team 175 special edition?
  • 65 Answers
That could be the engine fault alarm, if its a Mercury that indicates high engine temp, low oil pressure (4stroke) low oil level (2 stroke and 4 stroke) Either way, dont ignore it, it will get expensive. this information is similar for Yamahas as well
Posted on Sep 21, 2009
I have a bass tracker 2010 Pro Team 175 with a 50 HP Mercury motor. Phenomenal boat. Fished this past weekend and boat would not start when I went to return home. Nothing, no turn over of ignition,
check battery condition with a load test. check charge rate from motor
clean battery terminals and posts to shiny clean
It has been known for batteries to deplete from electrolysis when stationary in the water so ensure that all cables are in good condition
fit a circuit breaker switch on a battery terminal to switch it off when stationary
May 30, 2016 | Boating
Why won't the buzzer alarm go off at the end of a drying cycle
Search Results
    Why does my Kenmore dryer model 417.94802/94862 end ...
    www.shopyourway.com > Manage My Life > Questions
    Why does my Kenmore dryer model 417.94802/94862 end of cycle alarm go off ...washer/dryer unit I do see that it is normal for the end of cycle buzzer to go off ...Why won't my Kenmore dryer model 110.86872100 shut off at the end of the ...
    Why won't the buzzer shut off on my Kenmore 80 Series ...
    The buzzer won't stop buzzing after the load is complete. ... or turn on the timer and the dryer will start just by selecting a cycle and closing the door. ... The dryer should continue to run and at the end the buzzer should only stay on as long as ...
    FIXED The Buzzer At The End Of The Dryer Cycle Comes On But Won't ...
    www.applianceblog.com/.../21739-The-Buzzer-At-The-End-Of-The-Dry...
    Dec 11, 2010 - 10 posts - ‎2 authors
    My maytag dryer has operated wonderfully until today. All of a sudden the buzzer that goes on at the end of the drying will go on but will not shut off unless I open the door.... To test it: by-pass the push-to-start switch and see if when you turn the timer on and close the door, the ... VERY annoying dryer End of Cycle Signal
    Jun 29, 2012
    Maytag DE8410 electric dryer - End of cycle buzzer stuck ...
    Mar 27, 2011
    Kenmore 80 series, buzzer won't shut off
    Sep 10, 2005
    More results from www.applianceblog.com
Feb 08, 2016 | Whirlpool Dryers
I have a 1998 VW Beetle and Im trying to locate the alarm/buzzer that comes on with the oil light. I need to unhook it. ITS DRIVING ME CRAZY! HELP!!!
First thing, check your oil pressure. Even if you check the oil level, if the oil pump is going bad then the oil pressure isn't high enough to keep the engine lubricated- that's probably why you hear the alarm. You'll end up needing to rebuild the engine if you drive too much without the proper oil pressure. If you're really sure you want to disable the alarm you'll need to remove the dash to get to the buzzer and disconnect the wires. You can also experiment with removing the fuse for the instrument cluster, but you'll lose all your dash lights too. Good luck.
Oct 29, 2013 | 1998 Volkswagen Beetle
Troubleshooting bass tracker boat
kill switch possibly problem.
Jun 26, 2013 | Boating
The bass of my wowee one doesn't work anymore
The problem is most likely a broken solder connection on the the voice coil side of the bass transducer. I just repaired one and it was a 5 minute fix if you have a small soldering iron. Carefully pry off the glossy plastic cover where starting with the side the speaker slits (grill) are. It's just held in with some sticky adhesive (peel it up slowly, allowing the glue to separate without cracking the cover). Below that cover are 6 phillips screws. Unplug bass transducer's wire harness from the circuit board. IThe white connector comes apart with a small tug. The other end of the wire harness goes to the round, green transducer's board which contains the voice coil. Remove the transducer assembly (the round thing with with the clear Gel like substance). Carefully remove the gel surround and separate the round circuit board from the round magnet. One of the black or red wires will probably be disconnected. This is probably due to the a bad solder connection coupled with the constant vibrations. Simply re-solder the connection and re-assemble and you're good to go. When re-asembling the transducer, be sure to install the round board first and make sure it slips UNDER the raised lip inside of the Gel. If installed correctly the whole bottom of the round green board will be in full contact to the gel. Now install the magnet. The magnet should rest on TOP of the gel lip inside, the lip keeps the magnet raised slightly above the board and allows it to vibrate freely without touching the the round board and the voice coil (brown colored wire winding attached to green board. Hope this helps.
Mar 22, 2012 | Audio Players & Recorders
When i start the car the alarm when on and the car wont start
Aftermarket alarm, look for the small button under the dash or hiding under the steering area press and hold it then crank and start the vehicle. If you cant find it be prepared to just remove the alarm system you will need to go under the dash at the ignition starter signal and remove the alarm starter relay and restore it to its original way. depending and the manufacture of the alarm these alarm that where installed for Toyota are a headache and fails all the time
May 22, 2011 | 2002 Toyota Camry
Bass tracker fuse descriptions
I was trained at a tracker dealership and that is one of their faults. The best way to find the fuse for the bilge pump is to look on the back of the bilge switch and trace a wire to the fuse panel. Most of the time they are color coordinated so you can match fairly easy without trying to manually probe for the wire.
Jun 10, 2009 | Boating
SEAT BELT BUZZER WHERE IS IT
does it do it on the driver side? hook it up without sitting in the seat start the rig if the buzzer is on sit in the seat if it is still on you have a bad ground on the seatbelt side the short belt that it connects to. the buzzer is under the dash driver side above the sterring wheel.
May 24, 2009 | 2003 Ford E150
My Mustang Cobra has a Viper alarm system that won't set
Under the dash, Your installer that worked on your Cobra should have put an valet button under the dash, It is a small round Black button, Ok with the driver door open,,put your key in the ignition and go to the on position, Locate the black button before you do this, once the ignition is on hold the black button down for 3 seconds hit it once more and then turn the ignition off, the light should start flashing again and the chirp for arm and disarm with work again, What you have going on is called Valet mode which is designed to put the alarm side of the system to sleep which can happen from accidentally bumping it.
Hope this was helpful.
That Crazy Install Guy.
Apr 05, 2009 | Vehicle Parts & Accessories
Boating Logo
643 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Boating Expert? Answer questions, earn points and help others
