Question about Hitachi Flat Panel Televisions
5 Suggested Answers
SOURCE: close caption
You need to turn on closed captions through the menu of your PVR. To have it on all the time, turn the box off, press menu on the front of the box, and scroll down to captions.
This should fix the problem
Posted on Mar 10, 2008
  • 122 Answers
SOURCE: hdmi inputs stopped working
It sound like the cable box or the Blue ray player is set to high - such as 1080P when the set is only rated at 720 - try scaling the output down and see if that helps
Posted on Nov 27, 2008
SOURCE: Problem with Brand New Sharp LC-46SB54U
Well this is not exactly a solution as much as it is just to inform you of what I've found out. I actually posted one of the problems listed below as guest. Either way, after having techs come to my house to replace the main board and component board to a total new (well, refurbished) TV exchange; I finally got some answers that clarified exactly what was going on. Today when I called Sharp to complain about the problems still happening with the new unit, they explained that they looked into the problem and it actually seems like there is an issue with the TV interpreting the signals coming from the XBOX. So essentially the signal is more than the TV can handle and then it lags behind a little. When this happens it can get confused and might want to switch resolutions (like going from 1080p to 1080i) for an instant and this is what causes the "blackout" issue. Apparently they are working on a firmware upgrade which should take care of the issue which should come out (hopefully) within the next 30 days. As soon as they do come out with the firmware upgrade I will post it on this page so everyone having the same issues can go ahead and upgrade. Hope this information is useful to some of you.
Posted on Mar 03, 2009
SOURCE: Acoustic Solutions TFT LCD TV - Red Lines
Get it repair
Posted on Apr 02, 2009
  • 11896 Answers
SOURCE: freeview
go to menu settings, channel settings, set tv to CATV for cable, AIR for analog, or HD for high def.
Make sure you have the correct cables depending on your connection
Posted on Sep 16, 2009
0 characters
1 Points
I have a Toshiba older TV that doesn't have HD digital converter box I bought a leaf ultimate antenna do I still need to use the converter box with this new antenna
if the tv does not have a built in hd digital tuner you need a Hd digital converter to analogue converter. What you need to be careful about is the available inputs on the TV if it only has AV in then you need a converter that transmits out RCA video or an analogue tv channel on RF the tv can tune into. Some of the new converters have HDMI out so if TV does not have HDMI input it won't connect. The antenna would go into the converter. Not sure how much signal you need you may need an rf amplifier if the signal is poor in your area.
Jun 01, 2015 | Toshiba Flat Panel Televisions
Hi all please help, I have an LG 32ld450 with no remote so I'm using my sky+hd remote. The problem I have is that I've tried to set up a magic eye in my room but I can't get off DTV to get the right...
Your TV has menu buttons on the side. When you go in to the menus then the normal thing is for the Volume and channel keys to act as Up/Down and Left/Right. I can't tell you which will do what function; you'll have to try it, but they should work. The TV also has an OK/Select/Enter button on it so you can activate a sub menu as you navigate through.
From the side menu it should be possible to access the tuning menu. Once in there you can set up the TV's analogue tuner to receive the Sky box RF2 out signal.
As for how you change between the analogue and DTV tuners, that could be a tougher nut to crack. There's a little trick with a Sky remote that allows one to program the Help key to bring up a TV's input menu:
On your Sky remote, press TV
Now hold down Green and Select together until the red LED flashes twice.
Now press the help key
Now press Select
Now, when you press TV and then the Help button the TV should display its input menu. Pressing help repeatedly will cycle through the inputs.
Of course,m the above only really helps if the TV lists the analogue and DTV tuners individually. If it doesn't, and there's now way of accessing it through the TV's menu navigation, then you might have to just bite the bullet and go to a supermarket and buy a cheap universal remote. Check it has the TV/Radio or TV/DTV function before you buy.
Sep 17, 2014 | Flat Panel Televisions
Accidentally set my TV to factory defaults
only digital signal is available now analog has been switched off no longer transmitting. You could try returning in all of your channels from the main menu the tv can do this automatically but you need to select the procedure . retune the digital channels only
1. click on the home button
2. scroll sideways till you reach settings
3. in settings scroll down or up and click on digital set-up (centre button of your scroll control)
4.then scroll down to, and click on digital auto tuning (centre button of your scroll control) this will activate automatic channel tuning the tv will do the rest and will wipe out old settings and retune in all channels
Jun 04, 2013 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Hi someone i know haas a techwood hd ready 32" tv i cant see for her which button on her remote she has to press to change it back over from analogue tv to digital please could you tell me which...
Normally TV's don't switch from analogue to digital signals in quite that distinction. The 'Input' or 'Source' or 'Video Source' buttons usually cycle through the different kinds of input the TV has ports for. In most cases theres a Component, Composite, HDMI, DVI or VGA (or both sometimes), and S-Video.
May 02, 2011 | Flat Panel Televisions
I have grundig lenaro 32"tv
Sounds like you're only viewing analogue channels.
Go into Menu and find Inputs and select & choose DTV. This will restore reception of Freeview (Digital TV) channels.
Mar 30, 2011 | Grundig Flat Panel Televisions
On able to use hdmi or usb inputs
HDMI and USB both run off the 5 volt power inside the TV. It is possible the 5 volt power is down in the set. Shop repair time.
HDMI connectors are frequently broken by allowing the wires to hang at the back of the TV. Most USB connections can only be used for MPEG movies and pictures. Check your owner's manual.
Mar 29, 2010 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Panasonic TX P50V10B Plasma TV
In order to get any of the Freesat channels, you need to connect a Satellite dish to your TV. If you have a Sky dish, you simply need to run an extra Cable from the LNB from the dish and connect to your socket on the back of your TV.
In order to get Freeview channels and Analogue channels, you need to connect a aerial to the back of the TV.
There is a menu option for the TV to start straight to the AV input (your Sky HD box). It is Menu > Setup > Other Settings > Power on Preference. Select 'AV' for your TV to start on Sky HD.
Also even if you have your TV to start on TV, when you turn on your Sky HD box, it should automatically switch to the Sky box.
Oct 28, 2009 | Panasonic Flat Panel Televisions
I just got a Vizio 37" TV from Walmart.When I turn it on, I get a blue screen that says No Signal. Help.I have Dish Network. What am I doing wrong?
Check that the connection where the dish box is connected to the TV is the selected input on your TV.
You should have either a component connection (5 cables) or HDMI (1 cable) connecting the dish box to your TV. The VX37 has two component inputs and two HDMI inputs (if I remember correctly). Use the INPUT button on your remote to select the correct input.
Once you confirm this and still have problems, post a response and I will follow-up.
Dec 21, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
How to get a high definition Picture??
Hi, first of all you need a high definition source. I'm not sure if your cable box is HD but lets take it as an example. The component leads which you are using isn't 'true' HD video quality, what you need is a hdmi cable from your source to your TV.
Your cable box maybe HD with a HDMI output, if it is then you need the lead to come out of the cable box into your tv's HDMI input using a HDMI lead. Then you switch your TV's source to the HDMI input and it then should be producing a HD quality picture, but to truly get the full HD experience you may want to subscripe to a HD channel or purchase a blueray player becasue most cable TV channels are upscaled to HD and the definition is not as good as on a blue ray disc or a true HD channel.
So in conclusion the cable and input you are using is not designed for HD input. I believe your TV is HD, check for HDMI inputs or DVI inputs.
Hope this explains your problem
Nov 28, 2008 | Sansui HDLCD-2600 26 in. LCD Television
You do not say which breed of sky you have.. old analogue, digital, sky + or sky HD if you have old analogue then you may have to connect through aerial connection, digital will have a scart socket to connect to your tv, sky + will have the same and finally the cream of the crop sky HD will have hdmi in addition to scarts.
The very least you need to do for a digital picture (not to be confused with hi-def which it isn't) is connect through scart lead then unless it auto-switches to scart input upon switching on sky use your tv remote to select the ext input 1, 2 or 3 etc (some remotes have a button called source for this some call it input etc) select each ext input until you find the one your sky is connected to
Oct 12, 2008 | Flat Panel Televisions
Flat Panel Televisions Logo
55 people viewed this question
Top Hitachi Flat Panel Televisions Experts
Are you a Hitachi Flat Panel Television Expert? Answer questions, earn points and help others
