Question about 1995-1997 Chevy Suburban Ignition Starter Alarm switch
1995 chevy suburban 5.7, dtc 23, intake air sensor low, dtc 32, EGR error, dtc 44, o2 sensor lean, (recent) , random problem, engine runs rough and stalls   increasing frequency. e-mail if needed bmccann891@comcast.net
  • bee_man May 11, 2010
    When you say random problem, do you mean it is intermittent and doesn't happen all the time?
95 chevy suburban 4by4 code DTC 32 EGR Error. How do I fix it?
Posted on Jun 13, 2011
  • 21 Answers
Check for a vacum leak or broken wire
Posted on Oct 06, 2009
2000 chevy silverado p0171 ; p0174; p0300
Sounds like you have a serious vacum leak.; DTC 0174 and 0174 are lean conditions on bank 1 and bank 2, 0300 is random misfire. The only thing I can think of is a big vacum leak like the brake booster / vac line leaking, or maybe the intake manifold is cracked ... even a stuck-open EGR doesn't normally lean a motor that much. Start by checking for a vacum leak, if the motor will idle you can spray a little WD-40 around ports and lines >> if the idle speeds up or becomes smooth you on the right track in the area you judt sprayed.
Feb 26, 2015 | 2000 Chevrolet Silverado
Hyundai santa fe 2001
Car error codes::
Diagnostic Trouble Code Storage Condition Remedy
P0100 Mass Air Flow Sensor Voltage High C-8
P0100 Mass Air Flow Sensor Voltage Low C-8
P0110 Intake Air Temperature Voltage High C-10
P0110 Intake Air Temperature Voltage Low C-10
P0115 Coolant Temperature Voltage High C-9
P0115 Coolant Temperature Voltage Low C-9
P0120 Throttle Position Sensor (TPS) Voltage High C-7
P0120 Throttle Position Sensor (TPS) Voltage Low C-7
P0130 O2 Sensor 1 Circuit Voltage High C-30
P0130 O2 Sensor 1 Circuit Voltage Low C-30
P0130 O2 Sensor 1 Open Circuit C-30
P0150 O2 Sensor 2 Circuit Voltage High C-31
P0150 O2 Sensor 2 Circuit Voltage Low C-31
P0150 O2 Sensor 2 Open Circuit C-31
P0201 Injector Valve 1 Voltage High C-20
P0201 Injector Valve 1 Voltage Low C-20
P0201 Injector Valve 1 Open Circuit C-20
P0202 Injector Valve 2 Voltage High C-21
P0202 Injector Valve 2 Voltage Low C-21
P0202 Injector Valve 2 Open Circuit C-21
P0203 Injector Valve 3 Voltage High C-22
P0203 Injector Valve 3 Voltage Low C-22
P0203 Injector Valve 3 Open Circuit C-22
P0204 Injector Valve 4 Voltage High C-23
P0204 Injector Valve 4 Voltage Low C-23
P0204 Injector Valve 4 Open Circuit C-23
P0205 Injector Valve 5 Voltage High C-24
P0205 Injector Valve 5 Voltage Low C-24
P0205 Injector Valve 5 Open Circuit C-24
P0206 Injector Valve 6 Voltage High C-25
P0206 Injector Valve 6 Voltage Low C-25
P0206 Injector Valve 6 Open Circuit C-25
P0230 Fuel Pump Relay Voltage High C-6
P0230 Fuel Pump Relay Voltage Low C-6
P0230 Fuel Pump Relay Open Circuit C-6
P0325 Knock Signal Circuit 1 C-26
P0330 Knock Signal Circuit 2 C-26
P0335 No Engine RPM Signal C-32
P0335 Incorrect RPM Signal C-32
P0340 Hall Sensor Voltage High C-15
P0340 Hall Sensor Voltage Low C-15
P0403 EGR Valve Voltage High C-28
P0403 EGR Valve Voltage Low C-28
P0403 EGR Valve Open Circuit C-28
P0410 Secondary Air Pump Voltage High C-27
P0410 Secondary Air Pump Voltage Low C-27
P0443 Fuel Tank Ventilation Valve Voltage High C-29
P0443 Fuel Tank Ventilation Valve Voltage Low C-29
P0443 Fuel Tank Ventilation Open Circuit C-29
P0500 Vehicle Speed Signal C-42
P0505 Idle Air Control Voltage High C-33
P0505 Idle Air Control Voltage Low C-33
P0550 Power Steering Voltage High C-14
P0550 Power Steering Voltage Low C-14
P0560 Battery Voltage High C-4
P0560 Battery Voltage Low C-4
P0602 Control Module Programming Error C-2
P1110 Intake Manifold Valve 1 Voltage High C-34
P1110 Intake Manifold Valve 1 Voltage Low C-34
P1111 Intake Manifold Valve 2 Voltage High C-35
P1111 Intake Manifold Valve 2 Voltage Low C-35
P1230 Power Supply Relay Secondary Circuit C-3
P1405 EGR Valve Feedb. Voltage High C-28
P1405 EGR Valve Feedb. Voltage Low C-28
P1405 EGR Valve Feedb. Incorrect Signal C-28
P1501 Immobiliser No or Wrong Coding C-5
P1502 Immobiliser No Signal C-5
P1503 Immobiliser Wrong Signal C-5
P1530 A/C Relay Voltage High C-41
P1530 A/C Relay Voltage Low C-41
P1600 Reprogram or Replace Electronic Control Unit (ECU) C-2
P1602 Knock Control Module; Replace ECU C-2
P1690 Check Light Voltage High C-43
P1690 Check Light Voltage Low C-43
P1690 Check Light Open Circuit C-43
P1740 Torque Control Voltage Low C-40
P1740 Continuous Torque Control C-40
These are the error codes:
Jul 08, 2008 | 2001 Hyundai Santa Fe
Code 1150 on a 1997 ford f 150 with a 4.2 motor
I will try to paste an article for you. Several sources indicate this is a Bank 2 O2 sensor problem and that it is failing to switch and adjust for the fuel mix. But as you can see, many defects can lead up to this O2 sensor Code 1150.
I would try to use a spray bottle of water and go around the Intake manifold and spray the water while the engine is running. An intake leak will draw water into the engine and change RPM.
If no success then try changing the O2 bank 2 sensor. You may need to wipe the computer and clear the Code. H40 DTCs P1131, P1132, P1151 AND P1152: UPSTREAM HO2S NOT SWITCHING. DTC P1130: FUEL SYSTEMicon1.png NOT SWITCHING AT FUELicon1.png TRIM (RICH OR LEAN)
Diagnostic Trouble Codes (DTCs) P1131 bank 1 (Cylinder 1) and P1151 bank 2 indicate the fuel/air ratio is correcting rich for an overly lean condition. The HO2S voltage is less than 0.45 volt. DTCs P1132 bank 1 (Cylinder 1) and P1152 bank 2 indicate the fuel/air ratio is correcting lean for an overly rich condition. The HO2S voltage is greater than 0.45 volt.
DTC P1130 and P1150 indicate the fuel control system has reached maximum compensation for a lean or rich condition and the HO2S is not switching.
DTC/HO2S Reference List
•HO2S-11 = DTCs P1131, P1132 and P1130
•HO2S-21 = DTCs P1151, P1152 and P1150
Possible causes:
Fuel system
•Excessive fuel pressure.
•Leaking fuel injector(s).
•Leaking fuel pressure regulator.
•Low fuel pressure or running out of fuel.
•Contaminated fuel injector(s)
•Vapor recovery system
Induction system
•Air leaks after the MAF.
•Vacuum leaks (vacuum lines and gaskets).
•Restricted air inlet.
•PCV system.
•Improperly seated engineicon1.png oil dipstick.
EGR System
•Leaking gasket.
•Stuck open EGR valve.
•Leaking diaphragm.
Base engine
•Oil overfill.
•Cam timing.
•Cylinder compression.
•Exhaust leaks before or near the HO2Ss.
•Check intake air system for leaks, obstructions and damage.
•Check air cleaner element, air cleaner housing for blockage.
•Verify integrity of the PCV system.
•Check for vacuum leaks. user_online.gif quote.gif post_old.gif )
Mar 28, 2013 | 2003 Ford Ranger Regular Cab
1995 dodge ram 1500 318 motor it wont get fire where is the logic module located
Under hood,passenger side mounted on the firewall,but ...
Could be something else ,crank sensor or cam,or ign.rotor ect.
The module like 3 hundred bucks.Try this ,turn the key
on-off-on-off-on( without out hitting the starter) the check
engine light should begin to flash.
Here is a code list,may narrow down the problem.
Diagnostic Trouble Code Descriptions and service hints. Fault Code DRB Display Code Description. Service hints. 11 No Crank reference signal at PCM No Distributor reference signal detected during engine cranking. Check the circuit between the distributor and PCM. 12 Battery Disconnect Direct Battery input to PCM disconnected within last 50 ignition key-on cycles. Normal if battery has been disconnected, otherwise check battery power and ground connections. 13** No change in MAP from start to run No difference seen between the engine MAP reading and the barometric (atmospheric) pressure reading at startup. Indicates a problem with the MAP sensor vacuum system. 14** MAP sensor voltage too low or too high MAP sensor voltage output is outside the acceptable range. 15** No Vehicle speed sensor signal No signal received from the vehicle speed sensor during road load operation. 17* Engine is cold too long Engine temperature too high or too low while traveling. Check coolant level, radiator cap, temperature sensor, and thermostat. 21** O2S Stays at center O2S shorted to voltage O2 sensor does not detect rich or lean condition, or O2 sensor input voltage too high. DRB will indicate which side with dual sensors. The O2 sensor signal should fluctuate under normal conditions. 22** ECT sensor voltage too high or too low Engine Coolant temperature sensor input out of normal range. Check engine temperature sensor. 23** Intake air temp sensor voltage too high or low Intake air manifold temperature sensor is out of range. Check sensor. 24** Throttle position sensor voltage too high or low TPS sensor is out of normal range. 25** Idle air control motor circuits A short is detected in one or more of the idle air motor circuits. 27* Injector # control circuit Injector number # output driver circuit does not respond to the control signal. Check the affected circuit. 31** EVAP Solenoid Circuit Short or open in the EVAP solenoid circuit. Check for loose, broken, or shorted wire in the charcoal canister purge solenoid wiring and connectors. 32** EGR Solenoid circuit Short or open in the EGR solenoid circuit. Check for loose, broken, or shorted wire in the EGR valve wiring and connectors. Possible air fuel ratio imbalance not detected during diagnosis. 33* AC clutch relay circuit Short or open in the AC clutch circuit. 34* Speed control circuit or speed control switch always low or high An open or short in the speed control vacuum or vent circuits. Speed control switch input above or below normal range. 35 Radiator Fan low speed relay circuit Open or short in the radiator fan relay wiring. 37** Torque converter clutch solenoid CKT or Trans temp sensor too high or low Open or short in CKT wiring or connectors. Voltage out of range at transmission temperature sensor input. See NOTE #1 below 41** Generator field not switching properly Open or short in the generator (alternator) field control (regulator) circuit. This indicates a problem with the charging circuit and the fault is set when the battery voltage from the ASD relay falls below 11.75 volts. Wiring, connectors, fuses, and the ASD relay should be checked. A shorted battery cell can also trigger this fault. 42* Auto shutdown relay circuit Open or short in the ASD relay wiring or connectors. 43** Ignition coil circuit # Open or short in number # coil circuit. Indicates that the ignition coil's peak primary circuit current is not achieved with the maximum dwell time. 44* Battery temp sensor volts out of range An open or short in the engine coolant temperature sensor circuit or a problem in the PCM's battery temperature circuit. 45* Trans OD solenoid circuit Transmission OD solenoid circuit failure. Open or short in the transmission overdrive solenoid circuit. 46** Charging system voltage too high Battery voltage sense input above target charging voltage during engine operation. Computer is indicating that the battery voltage is not being regulated. 47** Charging system voltage too low Battery voltage sense input above target charging voltage during engine operation. Also, no significant change in battery voltage was detected during a test of the generator output. 51** System lean L-Idle Adap at rich limit or lean R-Idle Adap at rich limit O2 sensor signal indicates lean air/fuel ratio during engine operation. The computer ran the mixture to the rich limit of programming, but the O2 sensor still indicated a lean condition. L or R indicate left or right side O2 sensor. Fuel pressure problems can lean the mixture and set this fault. 52** System rich L-Idle Adap at lean limit or rich R-Idle Adap at lean limit O2 sensor signal indicates rich air/fuel ratio during engine operation. The computer ran the mixture to the lean limit of programming, but the O2 sensor still indicated a rich condition. L or R indicate left or right side O2 sensor. Faulty ignition components, high or low fuel pressure, or leaking injectors can set this fault. 53* Internal PCM failure or PCM SPI comm failure An internal PCM failure or PCM communications failure has been detected. 54* No cam sync signal at PCM No fuel sync (camshaft signal) detected during engine crank. No camshaft position sensor signal was received from the distributor. Problem with the distributor synchronization circuit. 55 N/A End of message code. A DTC 55 is used to end all DTC messages. This code does not show on the DRB tool and indicates a completion of the stored codes on the Malfunction Indicator Lamp (check engine lamp). 62* PCM failure SRI miles not stored Unsuccessful attempt to update Service Reminder Indicator miles in the PCM EEPROM (memory). 63* PCM Failure EEPROM write denied Unsuccessful attempt to write and EEPROM location by the PCM. Controller failure, check the PCM. This code can be set when attempting an unauthorized reprogram of the PCM. 71** Aux 5V signal voltage low The auxiliary 5 volt supply output voltage is low. The 5 volt output signal is not reaching the required voltage level. 72** Catalytic Converter efficiency failure The catalytic converter is not converting emissions in the proper ratio.
Feb 22, 2013 | Cars & Trucks
Cant Find a list of codes 1989 Buick Century. Car stalls and has a rough idle. coads are 31 43 and 44
Here is a code list for you. Remember this doesn't always mena a sensor issue, the problem can be in the wiring as well, or in the case of a lean code you may have an actual lean condition due to a vacuum leak at the intake or vacuum hoses or connections. I have highlighted your fault codes and added extra notes.
GM common codes for OBD1 (for vehicles made before 1995)
12 System normal
13 oxygen sensor circuit open
14 coolant sensor high resistance or shorted
15 coolant sensor circuit low or open
16 direct ignition system (DIS) fault in circuit
17 cam position sensor fault
18 crank or cam sensor error
19 crank sensor circuit fault
21 tps sensor out of range
22 tps sensor signal voltage low
23 intake air temp sensor out of range, low
24 vehicle speed (vss) sensor circuit fault
25 air temp sensor sensor out of range, high
26 quad-driver module (computer) circuit #1 fault
27 quad-driver module (computer) 2nd gear circuit
28 quad-driver module (computer) circuit #2 fault
29 quad driver module (computer) 4th gear circuit
31 camshaft position sensor fault
32 egr circuit fault
33 map sensor signal out of range, high
34 map sensor signal out of range, low
35 idle air control sensor circuit fault
36 ignition system circuit error
38 brake input circuit fault
39 clutch input circuit fault
41 cam sensor circuit fault, igntion control circuit fault
42 electronic spark timing (EST) circuit grounded
43 knock sensor malfunction or electronic spark control (ESC) circuit fault (ignore this for now)
44 oxygen sensor lean exhaust (make sure you no engine vacuum leaks)
45 oxygen sensor rich exhaust
46 pass-key II circuit or ps.pressure switch circuit fault
47 pcm-bcm data circuit
48 misfire diagnosis
51 calibration error, mem-cal, ecm or eeprom failure
52 engine oil temperature circuit, low temperature indicated
53 battery voltage error or egr or pass-key II circuit
54 egr system failure or fuel pump circuit low voltage
55 a/d converter error or pcm not grounded or lean fuel or frounded reference voltage
56 quad-driver module #2 circuit
57 boost control problem
58 vehicle anti-theft system fuel enable circuit
61 a/c system performance or degraded oxygen sensor signal
62 engine oil temperature high temperature indicated
63 oxygen sensor right side circuit open or map sensor out of range
64 oxygen sensor right side lean exhaust indicated
65 oxygen sensor right side rich exhaust indicated
66 a/c pressure sensor circuit low pressure
67 a/c pressure sensor circuit or a/c clutch circuit failure
68 a/c compressor relay circuit failure
69 a/c clutch circuit head pressure high
70 a/c refrigerant pressure circuit high
71 a/c evaporator temperature sensor circuit low
72 gear selector switch circuit
73 a/c evaporator temperature circuit high
75 digital egr #1 solenoid error
76 digital egr #2 solenoid error
77 digital egr #3 solenoid error
79 vehicle speed sensor (vss) circuit signal high
80 vehicle speed sensor (vss) circuit signal low
81 brake input circuit fault
82 ignition control (IC) 3X signal error
85 prom error
86 analog/digital ecm error
87 eeprom error
99 power management
Jul 21, 2011 | 1989 Buick Century
When i pull the code up on my 1992 park avenue it blinks once then blinks twice. what does this code mean?
This is code 12 and it means "System Normal"
Here is the complete list of fault codes for your Buick
12 System normal
31 cam position sensor fault
43 knock sensor
or electronic spark control circuit fault
85 prom error
87 eeprom error
99 power management
May 05, 2011 | Buick Park Avenue Cars & Trucks
I have a 1994 chevy work truck with a 305. I have trouble codes # 15, 22, 33, 34, 44, and 53. The egr valve had been removed but apeared good. Someone had put a plate over the port. Additionaly someone...
DTC - 15 Engine coolant temp sensor error (low temp indicated)
DTC - 22 Throttle position sensor error (signal low)
DTC - 33 MAP sensor circuit error (signal high indicating low vacuum)
DTC - 34 MAP sensor circuit error (signal low indicating high vacuum)
DTC - 44 Oxygen sensor error (lean condition indicated)
DTC - 53 Digital EGR Valve solenoid 1 error
MAP is short for manifold absolute pressure sensor,,it senses the manifold pressure and applies the right amount of gas with the right amount of ignition timing so the car runs and performs well if this does not work properly,it throws off the whole loop cycle for the computer,,which in turn makes it run badly,,and get poor fuel economy,,it causes one to have a lack of power,,combined with a loss of fuel economy,,and also poor take offs,,and sometimes an occasional stalling,,i hope this helps.
EGR system was really developed for was emissions control. the purpose of the EGR valve is to regulate the amount of exhaust gas recirculated back into your combustion chamber to send the gasses through another cycle in order to eliminate any excess pollutants like NOX (nitrogen oxides), N2 (nitrogen), O2 (oxygen), CO2(carbon dioxide) and HC (Hydrocarbons). the EGR was also developed to lower combustion temps that's another reason why the exhaust is recirculated the exhaust gasses will not burn therefor lowering combustion temps, because there is less "usable" air going into the cylinders.
Nov 17, 2009 | 1994 Chevrolet C/K 2500
What does the 44 code mean on a 95 gmc 5.7 tbi truck
Code 44
oxygen sensor detecting lean exhaust
Nov 13, 2009 | 1995 GMC Sierra C1500
Jaguar xj6 4.0 1990. showing fault code fuel 14, fail 14. what does this code mean ?
2 airflow sensor out of operating range 3 coolant temp sensor out of operating range 4 oxy sensor indicates full rich 5 throttle potentiometer/airflow sensor... (low throttle pot signal with high airflow sensor signal) 6 throttle pot/airflow sensor...... (high throttle pot signal with low airflow sensor signal) 7 throttle pot...idle fuel adjustment failure(idle speed??) 8 intake air temp sensor...open or shorted circuit to sensor 11 Throttle pot at idle: Throttle pot idle trim out of normal range 12 Airflow meter: MAF signal out of range 14 Coolant thermistor: Resistance out of range or static during engine warm up 16 Air thermistor: Resistance out of range 17 Throttle pot: Out of range 18 Throttle pot/Airflow: Low throttle pot signal at high airflow 19 Throttle pot/Airflow: High throttle pot signal at low airflow 22 Fuel pump drive: ECU output to fuel pump relay 23 Fuel supply: Engine running too rich 24 Ignition Drive: ECU output to ignition Amp 26 Air leak: Engine running too lean 29 ECU self check 33 Injector Drive: ECU output to injectors 34 Injector: Looks for Injector dribble 37 EGR Drive: ECU output to EGR switching valve 39 EGR check sensor: EGR not working (normally pipe blocked) 44 Lambda (O2) sensor: Poor mixture control rich or weak (or misfire) 46 Idle speed Control valve: ECU output to Coil AB 47 Idle speed Control valve: ECU output to Coil CD 48 Idle Speed Control Valve: Stepper motor grossly out of position 66 Air pump: ECU output to air pump relay 68 Road speed sensor: Seen speed < 5km/h at high engine airflow 69 Drive/Neutral switch: Seen cranking in "D" or high airflow in "N" 89 Purge Valve drive: ECU output to purge valve
this is all I could find
Nov 09, 2009 | 1990 Jaguar XJ6
1995-1997 Chevy Suburban Ignition Starter Alarm switch Logo
913 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
