Question about GE JVM2070 Microwave Oven
JVM2070 heats, no "fan" while running, no turntable
I have a JVM2070 that got wet (tub above kitchen leaked). It heats, but there is not the usual amount of noise and the turntable does not turn. The fan does not run while it is heating, but runs when I use the buttons at the bottom of the control panel. I suspect the noise that I am missing is because the "stirrer" is not working. I checked the top and side stirrer motors, and the continuity is good. I also checked all of the TCOs and they have the appropriate continuity. Fuses are fine. Any ideas?
  • GE Master
  • 9,098 Answers
I would suspect the primary interlock (bottom door switch) has failed, or maybe its mount is loose.
If it's not activating, then the oven lamp, internal cooling fan, turntable, and stirrer will fail to come on, and the oven will not cook since the high voltage section will not be receinving power.
The hood vent exahsut fan (which you can turn on and off at will) still runs, since it is a different part of the circuit.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
See these files:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
http://www.microwavedisplay.com/doorsw.txt
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
If a switch is all you need, we offer a universal type for only $5 postpaid which you can order here.
NOTE: The FixYa system is not currently notifying me when folks reply to my posts, so please contact me directly for more help.
William E. Miller
prototech@usa.net
Posted on Sep 11, 2009
    Scholar:
  • 178 Answers
Hi. It sounds to me like the control PCB was damaged and is not switching power to the cooling fan or T/T motor.... Does the oven light work?
Oven heats, but light, fan and turntable do not come on.
Hi Ted
many microwaves have safety mechanisms to reverse, or stop the turntable if it senses resistance to the turning. This is done both because
  1. the turntable is usually driven by a small motor with a gear reduction transmission to get more torque on the glass platter and your food, and if something resists the turning, it can damage the gear train or belt if it keeps running.
  2. if you have something with liquid in it and it hits a wall, it could tip over, possibly spilling scalding liquid all over and maybe surprising the person who opens the door.
In some cases, it'll just stop and then try again the next time you run the microwave. The banging on the case sometimes turning things back on suggests that either something in the turntable mechanism is awry, or that there is a common hot wire, ground loop, or possibly fuse for the light/fan/turntable.
the manual for the oven doesn't really say anything about this.
You can see generic intructions on looking for an internal fuse here
Panasonic Microwave NN CT552W has no power plug fuse ok Has it got thermal... . Please, in particular, make sure you unplug the oven before opening anything. This is one of those devices where defeating the interlocks and having it turn on can seriously hurt you.
With regard to the turntable, in particular, it's really easy over time for exploded spaghetti sauce, spilled cocoa, and overmelted butter to have run down into the indentation in the middle of the bottom of the oven cavity. Remove the platter. Is it clean in there? Does it look like the 'this person never flosses' picture for mechanical rotors? If so, start with some kitchen cleaner and a washcloth damp (not soaked) with hot water. Let the cloth steam /warm the area a bit, wipe it down. repeat if necessary. If there's a lot of cruft built up there, that could be keeping you on the edge of safety shut-down.
Good Luck!
D
Nov 24, 2015 | GE JE1140 Microwave Oven
Microwave will not heat. Display pad lights up, all features work, on that work, turntable moves, but no heat...
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Jul 27, 2011 | GE JVM2070 Microwave Oven
GE Microwave JVM2070 runs but does not heat food? What is the likely problem?
heatman101 ';';
Jun 14, 2011 | GE JVM2070 Microwave Oven
Heard a pop and now the jvm2070 will not heat anything
This sounds like the magnetron has failed, also! the high voltage capacitor and diode can be a factor, since all the above work together in generating heat for the food. If the magnetron has failed it is cheaper to replace the microwave oven.
Mar 10, 2011 | GE JVM2070 Microwave Oven
Microwave runs, turntable turns, fan runs, but does not heat,
No heat means the magnetron circuit has failed. It is the part that generates the microwaves to heat the food. Usually not worth fixing since the magnetron costs nearly as much as a new oven. To diagnose, if the oven is on, you will hear a loud buzzing sound if the magnetron is shorted.
Jun 30, 2010 | Sunbeam SMW777 Microwave Oven
Ge over the renge microwave runs but no heat
heatman101
hjdhjd
Feb 13, 2010 | GE JVM2070 Microwave Oven
Microwave runs but does not heat or cook food
If a Goldstar, LG or Zenith MV1610 or MV1608 is running but not seeming to heat a load placed in center of turntable, its probably because the "stirrer" intended to spread microwaves generated by the magnetron around the cook chamber is stuck so that most all the heating is directed toward the back and top rather than the center of the cook chamber. This usually occurs after cooking for longer than a minute with no load in the cook chamber - as when a model w/o a timer (such as a MV1608) is intentionally operated in cook mode to serve as a kitchen timer, or when a model with a timer function (such a MV1610) is accidentally operated for longer than a minute w/o any load. Before assuming the magnetron (usually warranted for 5, 8 or even 10 years) or other high voltage component such as diode or capacitor needs to be replaced, try “cooking” a 16 oz pyrex cup of water at full power on the outer edge of the turntable for 2-3 minutes - which usually reactivates the "stirrer" and restores normal cooking function.
Jan 18, 2010 | LG Microwave Ovens
No fan, turntable or heat, but counts downs
The 'Clock, is Machanical just like an ordinary kitchen timer The reast of it is electronic, and at that age time for a new one.
Jun 26, 2007 | GE JE1640WA/GA Microwave Oven
GE JVM2070 Microwave Oven Logo
101 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
