Question about Campbell Hausfeld PW1750 Electric Pressure Washer
Wont come on when switch is pushed to on - Campbell Hausfeld PW1750 Electric Pressure Washer
Looked up Campbell Hausfield service on internet. found dealer within 1 mile of home.
Posted on Sep 12, 2009
Motorcycle will push start but not ignition switch start
Does it turn over when trying to start? If no then it could be the starter, switch, or battery. Sounds like the starter, especially if you tried another switch.
Apr 14, 2014 | 2008 kawasaki Ninja 250R
Wont start when button is pushed
could be a bad door switch, wen door switch goes bad it wont start the dryer thinks the door is still open.
Dec 17, 2012 | GE GTDP300EMWS Dryer
Broken hazard switch on ford fusion
Most likely the switch has to be replaced. It should have a push 0 - push off action.
Sep 07, 2012 | Ford Fusion Cars & Trucks
The blades don't engage when i push the pto switch on dash
Sounds like you have a loose or broken wire. It may have an inline fuse that blew. I would start at the switch and work my way down checking the wires for breaks or disconnections. If nothing, it may be your brake switch. If your brake switch is defective or not hooked up, your mower wont register you have pressed the brake lever and wont allow you to activate the mower deck as a safety measure.
Mar 30, 2012 | John Deere Garden
My car wont start sometimes i can push start it but it wont jump start is that clutch pedal lock switch?
sounds like clutch switch, Check under dash follow clutch pedal up and see if there is a switch under dash, should be Purple wires going to it Heavy gauge wires, need to unplug it and put a jumper in from one side to other and cover with tape so it doesen't touch and ground out and blow a fuse, then see if it will start and if it took care of your problem, if so replace switch
Jan 05, 2012 | 1999 Saturn SL
My sandisk mp3 is frosen on the meau and wont trun
1. Push the "Power" switch downward into the "Hold" position.
2. Press and hold the "Menu" and "Record" buttons at the same time until the device resets.
3. Push the "Power" switch upward all the way to turn it back on.
OR
1. Grab a steady hold around the device.
2. Push the "Power" upward and hold it there until it powers off.
3. Power the device back on by releasing the power switch and then pushing it upward again.
OR
1. Unscrew the screws on the back of the device (or simply push the lid off if it is a model without screws.)
2. Take out the batteries from the slot and wait until the screen goes black.
3. Insert the batteries the same way they were mounted and attached the lid again.
4. Push the power switch upward to turn on the device.
Oct 01, 2009 | SanDisk Sansa e250 MP3 Player
Wont turn on
Sounds like something is not in the right place. Tghere are safety switches, one on the front where the nozzle mounts, if it didn't get on right, it may not be pushing the switch. There also is another switch where the bag mounts onto the base, if it isn't pushed all of the way on, then that switch won't work. But if either one isn't set, then it won't start up.
Dec 15, 2008 | Kirby G4 Bagged Upright Vacuum
Agitator wont turn
Some of these have a resetable circuit breaker, if it has one, push it. There is a motor on the brush roll which could be bad. There also is an on/off switch, it may have a problem.Also may have a switch where the hose goes into, some models have a actuator for the switch, when the hose is pushed in, it actuates the switch so the brush roll motor turns on and stops when you pull the hose out.
Sep 03, 2008 | Kenmore 31913 Progressive Direct Drive...
Fills with water but wont start
probably the switch is broken push the switch down with a pen or something that gonna fit in if it start change the switch or bypass it by bypassing it it will run even if the cover open cheers
Jan 19, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Campbell Hausfeld PW1750 Electric Pressure Washer Logo
289 people viewed this question
Top Campbell Hausfeld Garden Experts
John Trevino
Mike Squire
Are you a Campbell Hausfeld Garden Expert? Answer questions, earn points and help others
