The best solution on earth!!!
the same thing happened to me. all you do is press the eject button until it turns yellow. when that happens, immediately unplug the ac cord, & plug it back in. repeat this process until the light stays green! trust me, it works. it saves alot of money too if your warranty has ran out
Follow the procedure below to fix the problem on your ps3,
1.
Turn off Playstation®3. 2. Hold the power button down; the system
will turn on and turn off once again. 3. Once the System has been
shutdown, re-press you finger until you hear 2 consecutive beeps 4.
When you hear the 2 beeps take finger off power button. 5. You will
be prompted to plug in your controller via USB and then hit the PS
button 6. The Recovery menu will pop up.
The current Recovery
Menu supports: • Restart System: Restarts the PLAYSTATION®3 System. •
Restore Default Settings: Reset all system settings back to default. •
Restore File System: Checks for corrupt/missing system files. •
Rebuild Database: Rebuilds the OS for the PLAYSTATION®3. • Restore
PS3 System: Fresh restore; Deletes everything and starts from Scratch. •
System Update: Update the PLAYSTATION®3 System.
PS3 red indicator light flashes with yellow means hardware errors and need some maintenance. Do you know, send back to game shop is too expensive and waste your time. Learn the correct repair skills and fix it by yourself is the ultimate method. Here is the repair guide for you to learn : DIY PS3 Repair Guide Not only such yellow light flashing problem, you can repair other red and yellow light related issues as well.After you purchased the product, you will be guided to the step-by-step videos and ebooks for you to work with.
PS3 console turn off iteself with red light flashing means hardware errors and need some maintenance. Do you know, send back to game shop is too expensive and waste your time. Learn the correct repair skills and fix it by yourself is the ultimate method. Here is the repair guide for you to learn : DIY PS3 Repair Guide Not only such turning off problem, you can repair other red and yellow light related issues as well.After you purchased the product, you will be guided to the step-by-step videos and ebooks for you to work with.
this happens when the ps3 has overheated-try removing the hard drive and replacing then give the console a hoover out.....if this doesnt work try holding the power button on for 5 sec....if this doesnt work its back to sony im affraid
Your system is getting hot......Clean the dust from the unit with a vacume...not a can of air, Canned air will only push the dirt further into the unit. also you can buy an intercooler for the ps3 nyco makes one that actually forms to the ps3
