Question about Agfa FUJIFILM FINEPIX Z33WP Digital Camera
Fujifilm z33wp will not turn on only 2 weeks old
It will not turn on even after charging the battery and wiggling the battery in the chambeer
  • wayne722 Sep 11, 2009
    Hi Bill:
    Thanks for your suggestion. As the camera is only two weeks old and little used the contacts are OK.
    I solved the problem by turning the battery so that the orange stripe on the battery faces the orange clip in the battery pocket and the arrows on the battery face down.
    President:
  • 2,761 Answers
The problem may be due to corrosion on the battery contacts inside the camera. Remove the batteries and wipe the inside contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sand paper). Remove any residue that may have fallen into the battery compartment during cleaning, wipe the ends of the batteries, and replace them in the camera. This cleaning process works about 90% of the time, and I hope that it cures your problem.
Posted on Sep 11, 2009
5 Suggested Answers
  • 244 Answers
SOURCE: fujifilm finepix v10 does not turn on. when
Fuse F351 has possibly blown on the board. It is a 2.5A 32v UL type surfacemount fuse which is soldered to the board. The fuse has a coded letter on it for identification. Recomend you find someone who knows electronics to repair
Posted on Jan 03, 2010
  • 11967 Answers
SOURCE: Unable to download photos from Finepix z33wp to iphoto on Mac
Use a card reader to download to a folder you create on your desktop. Then, from there, send them to iphoto.
Posted on Feb 14, 2010
  • 3 Answers
SOURCE: my camera fujifilm z33wp forms a moist inside the
Take the batterie out and let it all dry over night. That happend to mines and it worked fine, but after a week it BROKE and im so flippin' mad.
Posted on May 28, 2010
SOURCE: I have a Cannon Powershot SD1200 IS which is only
I have the same problem and I'm not sure why it does this. I think it has something to do with the connection inside the camera.
Posted on Oct 19, 2010
How do I replace battery door on Z33WP digital camera
This is quite an expensive part, compared to the price of the camera: http://camerarepairparts.com/fuji-finepix-z33wp-blue-battery-door-cover-unit-15452-p.asp
I'd suggest sending it to Fuji, using insured post. If it gets lost, you claim the insurance and get a new camera.
Dec 05, 2014 | Agfa FUJIFILM FINEPIX Z33WP Digital Camera
I have a fuji finepix z33 wp camera. is it possible to charge battery via usb to computer or usb wall plug?
No. The camera does not contain charging circuitry. You need to use the supplied charger (or equivalent).
Jul 29, 2011 | Agfa FUJIFILM FINEPIX Z33WP Digital Camera
I accidentally broke the battery chamber on my Fujifilm Z33wp camera, were can i get a new one, and also the flash doesn't work, what can i do to fix the flash
In my experience regarding the flash; make sure to check the settings of the camera that you did not deactivate the flash. It is usually a lightning bolt symbol displayed in the lcd screen; it is usually activated in full auto mode. If you do not see the lightning bolt or the symbol with the lightning bolt crossed out this also means it is deactivated.
If the camera still does not fire the flash then you may need a repair and the authorized FujiFilm service center that I deal with is Photo Tech Repair Service in NYC. www.phototech.com They can also probably get you the battery door that is broken. Contact them and tell them you were referred by Paul
Good Luck
Jun 30, 2011 | Agfa FUJIFILM FINEPIX Z33WP Digital Camera
So the USB wont charge the battery then.
The USB for this camera is only to transfer pictures from Camera to PC.
Take the battery out of the camera and stick it in the charger (camera comes with one in the box). The USB is strictly image transfer only.
* Please rate this solution with Thumbs up and comment to help us improve providing support
Dec 08, 2010 | Agfa FUJIFILM FINEPIX Z33WP Digital Camera
My camera fujifilm z33wp forms a moist inside the monitor when i tried it underwater then after several hours the monitor went all black and i cant turn it back on.... help.
Mar 19, 2010 | Agfa FUJIFILM FINEPIX Z33WP Digital Camera
The battery for my z33wp won't charge anymore. It has only been fully charged 3-4 times. The camera's fine because with the little bit of battery left, it still worked perfectly. I don't know if the fault...
Hello
Thank you for using FixYa for your problem
Always check the batteries first but if is it still giving the same fault, your camera is faulty.
It should be taken to an authorized repair centre for a repair estimate. Very few digital cameras have any user-serviceable parts.
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Feb 21, 2010 | Agfa FUJIFILM FINEPIX Z33WP Digital Camera
Feb 14, 2010 | Agfa FUJIFILM FINEPIX Z33WP Digital Camera
Agfa FUJIFILM FINEPIX Z33WP Digital Camera Logo
581 people viewed this question
Top Agfa Cameras Experts
Larry Stiles
Larry Stiles
Computer Links
Are you an Agfa Camera Expert? Answer questions, earn points and help others
