Question about Canon PIXMA iP4300 InkJet Photo Printer
My canon ip4300 won't feed the paper - Canon PIXMA iP4300 InkJet Photo Printer
SOURCE: 'paper jam' error on canon pixma ip4300
Hi guys, I eventually found a solution to the problem for my printer. With the top cover open, I pushed a sheet of 120 micron thickness A4 clear plastic binding cover through the exit tray as far as it would go to rest against the bottom row of rollers. I switched the printer off then back on again and as the rollers lifted momentarily, I pushed the sheet of plastic as far up through the machine as I could before the rollers went down again - it went in a fair distance. The printer then ejected the plastic sheet. I then put the plastic sheet into the paper tray and tried to print a blank document page. The plastic fed through cleanly and my printer has been working since without any error messages. I hope this works for you.
Posted on Mar 04, 2008
  • 50 Answers
SOURCE: Paper will not feed into
reseat the printer and even if it does not work then paper sensor has gone bad
Posted on Aug 12, 2008
ghassun
  • 499 Answers
SOURCE: canon ip4300 Error code 1300
u have to reset ur printer try to hold ur finger on power button for more than 15 sec then turn it on again
Posted on Jun 09, 2009
huntwolfe
  • 20 Answers
SOURCE: "Paper Output Slot Jammed" Canon Pixma iP4300
These printers are FULL of very sensitive sensors, and chances are that one of them may have a small piece of paper blocking them. If you can get the covers off by finding the "Triangle" arrow markers, you can inspect all these sensors.
Good luck!!!
Posted on Oct 02, 2009
SOURCE: canon ip 2600 printer. Paper does not feed
Hey I had the same problem. Called the company; we couldn't fix it. Well I turned it upside down and a 2" flower stem fell out from when I cut some flowers next to my desk. It still didn't work. I was examining the feed area while it was running and I found another little piece of stem that was lodged way in there. I had to get it out with tweasers and it turned out to be 1" long. Couldn't really see it at all. Works fine now.
Posted on Nov 10, 2009
Canon ip4300 manual
hello,maybe the paper feed is jammed try to see if it has something that stops the paper to go in and if you are asking for the service manual for the ip4300 printer you can download it from the below link:
http://goo.gl/ZYxxU
Good luck
May 25, 2013 | Canon PIXMA iP4300 InkJet Photo Printer
Paper feed issues when there is no Paper jam. All the rollers move when the printer tries to feed paper. It'll feed about and inch and a half of paper and then stop showing a Paper Jam.
85% of paper jams are caused by worn rollers . The rubber treads in the rollers wears down, making them smooth, so they won't pick up the paper. Sometimes, they are aged, which also gives them a smoother rounded texture, causing jams. The quick fix is to liven up that roller with a mixture of alcohol and soap. Damp a rag with the solution and wipe the rollers clean with it. That's make them more pliable and the paper jams will cease. If you plan to keep your printer,
Replace the pick-up and feed rollers.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
May 19, 2011 | Canon PIXMA iP4300 InkJet Photo Printer
My Canon iP4300 printer is giving me a service error 6000 message. How do I fix this problem.
Canon:
Sounds like you might have a paper jam. Sounds like there might be a piece
of paper, or a scrap torn from a piece of paper, stuck somewhere in the
paper path. The "peculiar sound" once you switch it on could be a clue that
there is a problem of that sort as parts that are not free to move properly
grind against one another.
Paper feed error [6000]
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Dec 17, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
Top paper feed does not feed 1 at a time, feeds multiple sheets or envelopes
Check for obstacles - top trays got biggest disadvantage: u may easily drop something into it. I`ve found 1GB memory card in mine
Dec 11, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
Canon ip4300 Error code 1300
Jun 09, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
Ip4300 canon
I had same problem this pm. Be sure you have not pressed the button to change paper source to the back feed. The green light on the paper feed button should be illuminated at the top of the printer icon. This solved my problem.
Nov 07, 2008 | Canon PIXMA iP4300 InkJet Photo Printer
Paper will not feed into ip4300 canon printer
Aug 12, 2008 | Canon Office Equipment & Supplies
Ip4300
Took a can of Blow Off (dust remover) and blew through paper track, and used a paper towel soaked in Isotope Alcohol and rubbed the tracking rails..
Everything seems to work fine for now except the canister paper holding is not feeding properly and the paper is getting jammed when you try to use it. This is not that important as long as paper can be fed the normal way and it doesn't jam..
Jul 12, 2008 | Canon PIXMA iP4300 InkJet Photo Printer
Canon ip 4300
Google "canon ip4300". The canon.com entry near the top has a support tab. and enter "paper skew", you'll get a roller cleaning procedure.
As a matter of fact, it didn't solve my problem. The alternative, of having the machine repaired, is, of course, silly vs. buying a new machine. But in the meantime, the lower paper feed still works, albeit slightly less convenient.
Apr 22, 2008 | Canon PIXMA iP4300 InkJet Photo Printer
Canon PIXMA  iP4300 InkJet Photo Printer Logo
333 people viewed this question
old marine
old marine
