Question about Sharp R-820B Convection/Microwave Oven
Enameled Cast Iron Pans In Sharp Convection Microwave 820
The manual does not address cookware like Le Creuset--enameled cast iron. I have some Descoware which LC bought out some years ago and incorporated into their own products. Descoware is totally encased by enamel.
If the cast iron is totally encased, can it be used in microwave cooking in the Sharp? If not, can it be used in convection cooking which has 30% microwave?
I would not advise it. Why would you want to put it in the microwave? I'm quite sure that putting iron in a microwave is going to ruin your microwave and the pot.
Posted on Feb 18, 2009
It will be fine also in 100% microwave?
Posted on Dec 17, 2007
You think it will be fine in just the microwave too?
  • Sharp Master
  • 9,098 Answers
It should be fine, but to be sure I'd contact Sharp.
You can contact Sharp at 1-800-BE-SHARP (1-800-237-4277).
We're happy to help and we appreciate your thoughtful rating of our answer.
When the unit is turned on it shoots flames from the roof of the unit WHY?
It sound like the antenna behind the plastic plate may be warped and touching the cavity. From my experience when they start shooting sparks it is time for a new microwave.
Apr 23, 2015 | Sharp R-820BK Microwave Convection Oven,...
Stopped working without power. Unplugging/re-plugging did not work. No display, no buttons responding. Is there re-set option?
there is a fuse inside,take it to someone that knows how to repair,if you use the wrong fuse,you could cause a fire or health problems
Mar 14, 2015 | Sharp R-820BK Microwave Convection Oven,...
Sharp carousel microwave convection oven keeps blowing fuse
The service manual is here:
http://www.microwavedisplay.com/r820bc_bk_bw_sm.pdf
You can get Sharp parts from Encompass here.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
See http://www.microtechfactoryservice.com/cap_test.html
If it went dead several seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
See: http://www.microtechfactoryservice.com/xformer.html
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
See this: http://031d26d.namesecurehost.com/mwd/doorsw.txt
Aug 01, 2013 | Sharp R-820BK Microwave Convection Oven,...
Burnt bottom of large cast iron pot very discoloured and a certain taste seems to affect the food
Hi, Most microwaves do not allow you to put metal pot or pan in side. If sparks are coming off of pots do not use any more. You should be using proper microwave safe ware. Good luck.
Jun 20, 2011 | Microwave Ovens
I have an old Le Creuset 16cm frypan an food especially eggs stick to the bottom .Is there any thing I can do to fix this?
It probably needs re enameling but the good news is that Le crueset guarantee for life. I can't point you at a link as i dont know where in the world you are but if in the UK see here
http://www.lecreuset.co.uk/Care--Use/Cast-Iron/
hope that helps
Jan 25, 2011 | Microwave Ovens
I seasoned my new stainless steel skillet in the oven now I have built up oil stuck to the sides inside the skillet. How can I remove this without damaging the stainless steel finish? HELP!
You only need to season a cast iron skillet, not stainless steel. Soak it in hot soapy water and use something like a mister clean pad to clean it.
Dec 07, 2010 | Microwave Ovens
Metal turntable's enamel chipped, so sparks fly.
Try Going To Your Local Hardware Store And Finding Enamel Repair.
It May Just Cook But I Hope It Doesn't.
Jan 05, 2009 | Sharp R-820B Convection/Microwave Oven
Clicking sound sporadically
That particular skillet is just too heavy a load for the turntable system to handle.
I would suggest a lighter skillet or a different container, otherwise, the motor or shaft or both will be damaged.
It is of course perfectly okay to put metal in a microwave (after all, that's what they're made of!) but you just have to do it only according to the instructions in the owner's manual.
And as you know, metal in convection mode poses no problem at all.
You just need to use a lighter or different container.
Jan 04, 2009 | Sharp R-1480 Microwave Oven
Sharp R-820B Convection/Microwave Oven Logo
644 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
