Question about Gateway Computers & Internet
Can't eject the cd/dvd and computer doesn't read the disc
My device manager detects an error with the driver for the TS-T632A cd/dvd drive on my Gateway One computer. I tried restore but the driver won't load properly and the error message also says the registry has been corrupted or has errors (code 19).
Please help.
  • tokonoma556 Sep 13, 2009
    I use Norton 360 for my antivirus and spyware program.
    Sergeant:
  • 336 Answers
Okay, if your registry was corrupted, you would be experiencing more symptoms, but as the error suggested the registry is the problem, I am going to ask, what your anti-spyware/ antivirus software is, just to know whether a virus is possible or unlikely.
Ryan Frame
Creative Energy Associates Technical Center
Posted on Sep 11, 2009
  • Ryan Frame
    Ryan Frame Nov 09, 2009
    Okay, that is most likly the problem. I would uninstall it (as even when you disable it there is a system that still scans) and try updating the driver again If it works you found your problem, but if not it could be the driver itself. I would attempt to download a generic driver again and try to install it so we can rule out a corrupted driver.
    Ryan Frame
    CReative Energy Associates Technical Center
Ts-h292b cd-rw drive doesn't read disc when inserted.
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark? ! or a red x right click you will need to update the driver or
hope this helps you
Oct 09, 2011 | Computers & Internet
MY , CD/DVD LAPTOP DRIVER DOESN'T WORK. IT CAN
goto run and type "compmgmt.msc"(without quotes) and select disc management if the dvd drive is showing below the hard disks means your dvd drive is working fine only thing you have to do is to right click on the CD-Rom 0 and change drive letter and paths to it
.if the CD ROM option is not seen in disk management then you have to go to the device manager option under computer management and expand cd/dvd -rom drives and you will find your dvd drive model if not that means that your dvd drive has got hardware problem
Aug 06, 2011 | Dell Computers & Internet
My TSST CDDVDW TS-L633L reads only and can not write since I wiped off the hard drive and installed a clean version of Windows 7 Pro 64 bit...Updated all the needed drivers but the above mentioned drive...
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver if your computer came with a motherboard disc the drivers could be on it
http://newdd.pcdriversheadqu.revenuewire.net/driver-detect/download
this is only a free trial
hope this helps
Mar 31, 2011 | Computers & Internet
Dvd drive noisy put in dvd go to my computer driver is showing but wont play driver ejects
1. Try a different cd or dvd to see if it's reading any dics
2. Boot computer and try again
3. Uninstall the dvd drive from your computer (windows xp machine) , Right-click "My Computer-icon" -> Manage -> Device Manager -> DVD/CD-rom Drives -> right-click and select uninstall Restart the computer and it should install the drive again automatically Try reading the discs again
5. Update driver if available, see manufacturers website for driver updates
6. Try the dvd drive in another pc (if possible)
7. Propably faulty drive, replace the drive with a new one
Mar 06, 2011 | Computers & Internet
Won' read discs, won't eject manually or through Eject under DVD drives.
you might have to uninstall both the dvd/cd + its drivers then reinstall them actually unplug the cd/dvd from its power cable then restart your computer plug it back in your computer should activate found new hardware or
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
hope this helps
Nov 14, 2010 | Dell Vostro 1500 1700 / Inspiron 1520 1521...
When i want to burn dvd on samsung dvd writer, it ejects the disc and when i insert data disc into the drive, it shows no disc. so, what is the problem?
try using a different type/brand of cd/dvdrw you might have a bad batch of cd/dvdrw or test all leads that attach to your dvdrw any faulty lead will result in computer error or control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
hope this helps
Oct 19, 2010 | Samsung SpeedPlus DVD-Writer 20x, Black ...
Drivers not working. Can not play any dvd,cd's.Its been about a week. Reinstalled drivers on Help and Support, but still not working. Any Ideas?
When you say Drivers not working, can you please confirm if you are referring to the CD Drives ?
If yes you can first make sure that the Drives are detected in Windows Explorer.
Click on Start Then click on "Computer" or "My Computer"
See if the CD / DVD drive is detected
If the drive is detected in Explorer and not able to read the discs, try various discs of different brands.
If none of the disc is readable then the Drive is gone back and you will need to replace it.
In case the Drive is not detected in the Windows Explorer then you can check if the device is detected the Device Manager.
To open device manager Press the Windows key + R and type devmgmt.msc
Press Enter of click OK
It will open the device manager
look under CD/DVD drive if there is any yellow exclamation mark.
If you see the Drive listed with an Exclamation then follow the steps to delete lower filter and upper filter from the Windows registry Editor.
http://support.microsoft.com/kb/929461
Jul 17, 2010 | HP Computers & Internet
TSSTcorp CD/DVDW TS-L632D ata dvd drive doesn't burn!!! Vista HP
Most of the time MEMOREX brand is not compatible with HP.
Try a diffrent brand and check if it works.
Jun 05, 2010 | HP Computers & Internet
My dell inspiron 9300 reads and plays DVDs, but does not detect any other type of CD in the CD/DVD drive (music, data, etc.). i've had a problem before where it didn't read CDs or DVDs and it turned out to...
Go to the support.dell.com webpage, enter the service tag number, located on a label on the bottom of the laptop, and download the latest BIOS update and drivers for the CD/DVD drive. You can verify the drive type in Device Manager. Once you have downloaded the files, upgrade the BIOS, this will restart the system. Next, remove the CD\DVD in Device Manager and then install the new driver for the drive. When the driver has been installed, Open Device Manager and right click on My Computer at the top of the list and left click on Scan for changes. The drive will be detected adn installed with the new driver and the registry will be updated.
Good luck, and please let me know how it works for you.
~Spoem
Dec 14, 2009 | Dell Inspiron 9300 PC Notebook
DVD+RW
dot.gif Unable to read a CD-R or other recordable disc. Question: Unable to read a CD-R or other recordable disc.
Answer: Unfortunately this can be a difficult question to answer because of the amount of potential reasons for this issue to occur. Below is a listing of several steps and recommendations that can be taken to help identify the cause of the issue and/or resolve this issue.
Drivers Verify you have the latest drivers installed for the CD-R or recordable drive. There are numerous driver related issues that may cause a CD-R drive or other recordable to stop reading a CD-R disc. If you are running Microsoft Windows verify your drive is properly detected and listed in Device Manager with no conflicts or errors.
If Windows Device Manager detects an error on the drive or if it has other drives listed in Device Manager with errors on them remove the device from Device Manager and reboot the computer to let Windows re-initialize the drive.
If Windows shows no errors, the above steps did not resolve the issue, or you are running a different operating system check with the drive manufacturer for updated drivers. A listing of disc drivers can be found here.
CD-R disk Not all CD-R disks are compatible with all types and speeds of CD-R drives or other recordable drives (especially earlier CD-R drives). Verify the manufacturer gives 100% guarantee for supporting all drives and disc speeds, for example, TDK discs often give a 100% guarantee.
Pre-mastering/Mastering Software Pre-mastering software can sometimes produce incorrect tracks due to bugs. An incorrect ISO image could be generated, or incorrect sub header codes could be recorded in the case of Mode 2 discs. A good way to check whether the incompatibility problems lie with the originating software or with one of the other causes listed above is to test the same disc on several CD-ROM drives. If one drive is capable of reading the disc back correctly, chances are that the problem was not in the mastering, but is one or more of the other factors listed.
Disc is a recordable disc that the drive or player does not support Verify the drive supports the recordable media you are attempting to read. Below are some situations to watch out for.
  • Old CD-ROM or early DVD drive - Some early CD-ROM drives and Gen 1 DVD drives (some of the first DVD drives released) do not support CD-R discs and/or CD-RW discs. Not only does this apply to computers but also home entertainment DVD players.
  • CD-RW in CD-R or CD-ROM drive - CD-R drives are incapable of reading CD-RW drives. If you are using a CD-RW disc verify the drive is a CD-ROM or CD-R drive is capable of reading the disc.
  • DVD recordable discs - If you have a DVD recordable disc and are unable to get it to read verify that the DVD drive is not a Gen 1 DVD drive and/or that it supports reading the DVD recordable media you are using. Additionally a standard CD-ROM, CD-R, CD-RW, etc drive is not able to read DVD discs.
Disc was created incorrectly Make sure you're creating the disc properly. For example, a common mistake users make when creating audio CD's that they can listen to in their computer, car, or home stereo is burning the MP3 files or other files directly to the CD as a Data disc and not an Audio disc. All this will do is burn the data files to the disc and not create an audio disc. This may allow you to listen to the audio files in the computer but will not allow you to listen to the music in the majority of other CD players unless they support MP3 format.
Disc or DVD contains media content not supported by the player Not all home entertainment DVD players are capable of supporting and playing all the different formats movie files and audio files are stored in. Make sure the format or codec of the movie or audio file you're saving to the CD or DVD is supported by the DVD player. If you're computer is capable of playing the files off the DVD but your home entertainment DVD player is not able to play the file it's likely you're encountering this issue.
Bad disc If after reading through the above recommendations you still continue to have the same issue it's possible that the disc is a bad disc. Try re-burning the disc and if possible try a different type of recordable disc.
Computer DVD Support
Click on the above link should get ya back up and going/Good Luck....Please dont for get to Vote.Thank you.
Dec 15, 2007 | HP Pavilion zd8000 Notebook
Computers & Internet Logo
166 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
