Question about Refrigerators
My ice maker wont make ice. What should I check
My ice maker wont make ice. What should I check first?
  • 135 Answers
Is the freezer temp at least -15 degrees? Is there water to the water valve in the back? Is there a cube stuck in the harvest arm of the ice maker? Is there water in the tray of the ice maker?
Posted on Sep 11, 2009
Whirpool ed2shaxmt10 ice maker wont get water
Check the fill tube that goes to the ice maker , it is where the water goes into the ice maker it may have a ice clog in it, this is due to a leaking water valve solenoid, you would have to replace the water valve to stop it from happening again but the ice clog need to be removed. If you want to attempt this your self contact me and I will tell you how I do it everyday.
Mar 30, 2014 | Washing Machines
Ice maker wont make ice
Is water getting into the ice tray of maker? If not check for the water solenoid's proper operation. Is freezer temp at least 10 degrees or less? If not, the ice maker will not work. If ice in tray then perhaps the heater element is not working to melt it a tad ans allow the fingers to pudh the ice out and into the tray.
You can get those suckers for about 40 bucks new on ebay eBayeBay
Aug 30, 2017 | Star Manufacturing GE Profile PFSS5PJX...
WILL NOT DELIVER ICE CUBED OR CRUSHED
Please check the bellow link, if it helps-
http://www.ehow.com/how_7592870_whirlpool-refrigerator-wont-make-ice.html
However if the ice maker has completely stopped producing ice check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahrenheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
Let us know if you want something else please accept the solution.
Jan 02, 2011 | Whirlpool Refrigerators
WATER NOT GOING IN ICE MAKER
Check if the filling tube to the ice maker is clogh with ice that means the dual valve that opens when the ice maker calls for water is leaking and this water freezes up and wont let any into the ice maker.
Aug 05, 2009 | Frigidaire FRS26H5AS Side by Side...
Roper Ice maker wont kick ice cubes out of tray.
Remove white plastic cover on ice maker. On bottom you will notice the heater connections, check for voltage. If good, heater is most likely bad.
Apr 16, 2009 | Roper RS22AQXKQ Side by Side Refrigerator
Ice dispenser wont work....ice maker works
Need to check and see if the water filter is stop up ,if you don't have a filter it I would start with water value at the bottom .
Mar 14, 2009 | Refrigerators
Frig.
Make sure you check your water supply and filter if you have one. Check the ice maker. Make sure the motor and gears are turning in the ice maker itself. As the ice maker goes through the cyle it activates the water solenoid for about 5-10 seconds at a certain piont to fill it. If the ice maker isn't running the ice maker will not fill.
Apr 20, 2008 | Refrigerators
Refrigerators Logo
217 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
