Question about Whirlpool Inglis IP8200 Dryer
Dryer quit running when I was drying a pair of shoes
Will no longer start. The breaker did not flip off. The button will not start the dryer any more.
  • 986 Answers
If a dryer is not working at all that's not good! But it doesn't mean you need to go appliance shopping just yet. It may be something very simple like a bad door switch or even a broken door switch actuator, in a kenmore dryer there is a tab thats sticks out of a hole in the wall that allows the dryer to run only if the door is shut, other models may have button that protrudes out of the dryer and when the door is shut, this allows the dryer to run. These switches go out from time to time, also if a dryer is full of lint build-up over time this will cause the dryer high limit or fuse to blow. The fuse is located near where the blower is in most cases. When the air in the dryer gets way too hot the fuse/hi-limit will blow and the house wont burn down.
Posted on Sep 12, 2009
Was working fine. Tried a few days later to dry a load and the starter wouldn't turn load on.
First. Check voltage if its a electric type flip breaker all the way off than back on sometimes breaker flips halfway. Then check for a thermal overload near blower housing usually long and white if it fails motor won't run
Jun 12, 2015 | Dryers
My Whirlpool Dryer (model no. LGR4634EQO) is no longer heating, or getting hot at all. How can I troubleshoot it??
Hello.
suggestions about things they can do to troubleshoot commonproblems.
Instructions
    • 1 Open the dryer door and remove the lint screen ifthe clothes are not dry after a drying cycle completes. Remove the lint fromthe lint screen and replace the screen. The dryer ought to dry more efficientlyafter the lint screen is cleaned.
    • 2 Open your home's breaker box if the dryer is notturning on or no indicator lights are visible on the front panel. If theswitches for the dryer in the breaker box are flipped to "Off," flipthe switches over to the "On" position.
    • 3 Remove some of the clothing in the dryer or drysmaller loads if you notice that the clothing is wrinkled when you finishdrying a load. Larger loads cause the clothing to wrap around one another whendrying, increasing the likelihood of wrinkles.
    • 4
Pull the dryer unit away from the wall and checkon the position and arrangement of the exhaust vent. An exhaust vent that ispinched between the wall and the appliance or an exhaust vent that is kinkedcan't allow air to flow through it properly, making it difficult for theappliance to dry properly.
    • 5
Make sure the door is closed if the dryerdoes notrun. Also check to make sure that you hold in the "Start" button forat least a second. Pressing the button for less than a second may not give thethe dryer enough time to recognize the button has been pressed and that itshould start.
Thanks for using fixya.
Jul 31, 2011 | Dryers
My dry quite working after my was work in electric box he was flipping power on and off
Your dryer is a 220 appliance and should be on a circuit all by itself. Are the items in your circuit box labeled (Lights? kitchen, etc.) One should be labeled "dryer". If you cannot locate one that is labeled for your dryer, Check out the position of the circuit breakers. If the dryer breaker is turned off it will be in the oppoite postion of the others.Caution: DO NOT do what he did and begin flipping breakers! If your dryer breaker is in the off position,is you should be able to flip it back on. Before you do this, have the dryer turned off.
If this does not work, unplug your dryer and leave it unplugged for 5 minutes or so, so that the dryers' operating system can reset itself. Then try turning it back on.
Dec 16, 2010 | Maytag Dryers
Whirlpool duet dryer GEW9200L will turn on but will only "click" when push button in. Timer light starts flashing. Wife was drying a load of towels with her pair of tennis shoes in it on the last load that...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 17, 2010 | Dryers
Dryer will not restart after tennis shoe getting stuck in it
Make sure door is closed firmly. Try to Press and hold the START Button for 4-5 Seconds.
Good Luck and have a nice day.
Jun 29, 2010 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Dryer won't start
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
May 01, 2010 | LG DLE2532W Electric Dryer
The dryer just quit working. The last item dried in their was a pair of tennis shoes. Next day it won't even turn on. Checked the thermal fuse and jumped it but it still would not start, spin, etc. Help!
This may not be a solution but try testing the outlet its pluged into or the circuit breaker at the main box. Stranger things have happened.
Oct 03, 2009 | Dryers
Dryer is flipping breaker after 10 minutes into dry cycle.
You have a weak circuit breaker . Should be a 30 amp or higher . If you have access to an amp meter , split the dryer cord , separating the 3 wires (do not remove the insulation ) . If you have a black round cord ( 4 prong ) , carefully slice into and remove the black insulation in a small portion only . Check the amps on both outer wires while running dryer . Make sure the amps being pulled are lower than the circuit breaker amps . On a black cord , test the black wire and the red wire amps . If the dryer has a short , it would not run for 10 min and then throw breaker . It would be almost imediate . A bad breaker will gradually get hot and then flip , but check the dryer amps anyway to be sure .
Aug 15, 2009 | Estate TEDX640JQ Electric Dryer
The dryer is not drying but has power
First thing to check is look for ~220 volts AC across the two slanted connections in the dryer power socket. You need a voltmeter for this. If no 220 volts, check the house electrical panel to see if the dryer circuit breakers (pair) have tripped--push them OFF, then ON. Recheck for 220 volt at the dryer socket. If voltage is still missing, you may have one or two bad breakers--replace the pair. If ok, try the dryer. If it starts, then quits, you have a short inside the dryer--likely the heating element. Nearly full tear down to get to the dryer element in back of the drum. Weigh repair cost versus a new dryer. Hope this helps!
Jul 23, 2009 | Whirlpool Dryers
My dryer drum is no longer turning when I press start.
When you turn it on, can your still hear the motor running but the drum doesn't spin? If so, yes, the belt could have broken or slipped off the pulley.
With my dryer, putting in a pair of shoes often makes it turn off. I hear it tumble for a while and then and then I hear a squeal and then the dryer turns off.
I have seen a device that can be put inside a dryer and adjusted to fit tight between the diameter of the drum and will allow you to put shoes on it. This solves the CLUMP - CLUMP - CLUMP issue.
If you don't hear the motor, its possible there is a blown fuse. have you checked your breaker panel too?
Good luck,
- Jim
Jul 15, 2008 | Danby DCD5505W Electric Dryer
Whirlpool Inglis IP8200 Dryer Logo
173 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
