Question about Seagate 80GB Barracuda 7200.9 SATA s - 8MB Cache (5-pack) 80 GB IDE Hard Drive
Seagate barracuda7200.9 80 gig.
Hi i've just FORMATTED my HDD, using the "cmd prompt" . the system can detects my HDD,I already check the Disk Management and it s there, and it shows "enabled" and the problem ist i can't get any access to it btw i forgot to mention, my HDD used to have 2 partitions, i partitioned the first part, and leave the other one? did formatting 1 part can affect the data of the other 1? I already set the BIOS settings to detect w/c is the master and w/c is the slave but still it didn't solve anything. I tried to use the disk alone and when it opens the system say's " DISK BOOT FAILURE INSERT SYSTEM DISK AND PRESS ENTER" what does it mean? The said HDD was a slave all along ididn't load any os on it! Do i have to install an OS on it to be able to get any acces to it?? plsss someone out there help me!!!!!!!!! PLSSSSSSSSS!!!!!!!! thank's A lot!!!!
I have seagate barracuda 7200.9 sata HDD nd want install RHEL-4 but they want a device driver link of  downloading for linux-4
  my e-mail is mukesh_cse52@yahoo.com
Posted on Jan 05, 2008
  • 556 Answers
Some of the following answer assumes a windows operating or possibly DOS based operating system. If your original OS was not Windows or DOS -- there may be different considerations.
1) Did you lose the contents of both partitions?
That depends were they soft or hard partitions.
Soft partitions are created as files inside of other partitions
If that is what you had allocated in the formatted partition
you have lost their data content.
Hard or physical partitions allocated using FDISK and some other utilities the second partition would still exist.
2) Where are/were your system files. Often but not always they appear as the first partition of the master drive on the primary IDE controller all assuming a PC (based on the master slave comments you have indicated.) (sometimes the second when diagnostics are loaded on the first partition)
a) if the partition on the drive you formated contained the system files yes they must be installed to access anything on the disk for the most part. A significant exception may be utilization of a DOS boot diskette might permit DOS access to the other partitions if they are formatted with the FAT file system.
NTFS partitions and possibly FAT32 partitions may not be accessible to all versions of DOS -- there may be some bootable CD's that would allow access to NTFS partitions without installing an operating system.
Question back from the DOS and older version of windows days and even some more modern operating systens in subsequent actions with the disk did you use FDISK or another utility to rewrite the boot blocks to point to a different partition?
Question this was not a dual boot machine was it?-- if so disregard anything that follows.
Question did the machine boot after formatting the partition and before you started moving the drives around? If so the operating system is probably on a drive you have removed from the machine. It needs to be replaced onto the same cable position it was originally located upon -- probably on the Primary IDE cable master position or jumper setting.
If not reinstallation of the operating to the formatted partition is probably the correct next step. Be careful in doing this because if you choose one of the other partitions that were not formatted it could wipe out the data in them based on the installation process chosen.
Posted on Dec 10, 2007
  • david Dec 10, 2007
    I just noticed the comments that this was a slave drive, if true. In all likelyhood this was not a system partition unless this was some form of dual boot machine. I get a strong feeling the drive you removed was the bootable drive with the operating system on one of it's partitions.
    As far as immediate actions - Power off the machine and put the other drive back taking the slave drive out and get the machine to boot again. Open My computer and record the drive letters present if your machine boots if that succeeds -- shutdown the machine and reinstall physically the "slave" drive open my computer and record the drive letters == we will attempt to deal with situation from that point.
Seagate raw drive
Your data is already gone. The drive is raw. No partition no format.
here is a link to a free data recovery program, this probably wont work but may be worth a try
http://getdataback-data-recovery-for-ntfs.soft32.com/free-download/?lp=dsa&tg=us&kw=_cat%3Asoft32.com&mt=b&ad=35354358678&pl=&ds=s&gclid=CIa78aSmk74CFc5ffgod9gEAlA
just be sure to opt out of all garbage they want to infest your computer with.
Jun 05, 2013 | Seagate U6 (ST340810A) 40 GB Hard Drive
Hi just installed Windows XP Pro on a Dell Dimension 3000 with 1 gig RAM. This machine was running W2000 pro with no problems. But after formatting the drive and installing Windows XP pro and all updates...
Well you definately tried everything I would have sudgested.
It sounds like the Hard drive is near the end of its life.
If you have only just installed windows, it may be worth getting a new drive, installing your OS on that, you could then use the other drive as extra storage.
I have had a few HD that started to fail. Maybe the format and installation pushed it over the edge. You could always run maxtors drive check tool to see if it can detect a problem.( maxtor is now seagate)
http://www.seagate.com/www/en-us/support/downloads/seatools
Aug 06, 2010 | Maxtor Hard Drive
Hi, I have a seagate freeagent external disk with 500 Gb capacity, I had long time without to use my diks, then when I tried to use, It doesn't work, the power source is Ok, but my disk it It doesn't...
is the hdd getting detected....??? if it got detected then format it and try to use... if it is not detected then, let me know, i shall assist you further...
May 17, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Brand new Seagate 250Gig supposedly a plug n play device. After I formatted with NTFS with 4k allocation size through right click F: format. Then I transferred 22 gig of data into it. The drive then...
I guess its the Seagate thats the culprit. But just to isolate the issue,can you plug the HDD in a different computer and check again ?
Thanks Ranjit
Dec 08, 2009 | Computers & Internet
Hard disk prolem'
Probablel corrupt partition. Please advise which OS you are using. In windows you can access the drive from disk managerment from where you can re-partition and format it. Keep me posted
Jul 26, 2009 | Seagate HDD 40GB 7200RPM ATA100 2MB...
Hard Disk Problem
first download and install Drive Rescue . Click on Find lost drive, select the drive you miss and click "find logical drives". Now you should access all of your files. Save them to another drive and format the hard disk.
hope to be helpful
Riccardo
Aug 03, 2008 | Computers & Internet
How to detect two IDE drives with same brand
You need to set one of the drives to be 'master' and the other to be 'slave'.
This is done by positioning jumpers on the back of the harddrives.
Pretty sure that on the drives is explained somewhere how to position the jumper, for several options.
Good luck,
Please post some feedback.
Apr 23, 2008 | Dell OptiPlex GX280 PC Desktop
HDD Size Recognition
Hi, 10243MB is 10.02 GB..
You will not get exactly 10.2GB out of the drive, as most HDD makers use the 1000MB = 1GB ratio, as really 1024MB = 1GB.
So the bios is detecting the drive correctly.
Apr 12, 2008 | MSI KM4M-L Motherboard
Hard disk problem
Change the other HDD to either Cable Select or SLAVE.
Then make sure you partition it correctly, Windows does a decent job at it.
Right click on My Computer, go to Manage, then under storage, click on Disk Management; you should see the HDD here.
Dec 09, 2007 | Toshiba (HDD2188) 80 GB Hard Drive
Seagate 80GB Barracuda 7200.9 SATA s - 8MB Cache (5-pack) 80 GB IDE Hard Drive Logo
344 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
