Question about Bissell 1697-7 Powersteamer Pro Deluxe Vacuum
Brushes not turning
Brushes will not turn on hoover steam cleaner
  • Anonymous Dec 29, 2008
    water in container does not seperate anymore...HELP!
  • Anonymous Jan 23, 2009
    brushes do not turn. is there a way that i can remove the brushes
  • 1,673 Answers
Check the shaft on top of the brush block to make sure it hasn't broken, if brush block is ok, then most likely the turbine is bad and will have to be replaced.
Posted on Jan 06, 2008
I have a hoover F5853-900 steam cleaner.Everytime i lift it up the brushes turn but when they are on the carpet they quit.I got told that this model does not have a belt.I really love this steam clean
The brushes are turned by a motor. No belt. It's possible the gears on the brushes have a flat spot on them which would stop them from turning under a load.
Dec 06, 2014 | Hoover Vacuums
belt probably broken. unplug from power and remove the plate from the bottom of cleaner.belt should be visible on one side or other.
Feb 02, 2013 | Hoover F5891-900 Steam Cleaner
Where is the belt located on my hoover steam shampoer
There is probably not a belt. The brushes on the carpet cleaner head and attachments work from air and there is a roller bearing deep inside that will wear out and the brushes won't turn. I've found no way to fix this. I consider it a design defect.
Apr 20, 2011 | Hoover SteamVac Carpet/Upholstery Deep...
On hoover steam carpet cleaner, the brushes do not rotate on low or high settings.
Follow these steps if the Brushes Fail to Spin
•If the brushes on your Hoover carpet cleaner fail to spin, there may be a problem---some sort of blockage---with the suction or with the belt that turns the brushes.
Turn the Hoover carpet cleaner over, and inspect the brush area. Debris, strings, or pet hair may be tangled in the rollers, keeping them from turning. Use a pair of scissors to cut away any obstructions in this area. Flip the Hoover carpet cleaner back over, and turn it on to see if cleaning the rollers has solved the problem.
To check the belt, turn the Hoover carpet cleaner over, and remove the bottom plate screw with a Phillips head screwdriver. Investigate the belt area to see if it is broken or has somehow slipped off. If it is broken, you can order a part from or from many of the other online parts stores.
When the belt arrives, simply slide it on in place of the broken belt, reattach the bottom plate and turn the Hoover carpet cleaner right-side up. Turn it on to test your solution.
Sep 03, 2010 | Hoover SteamVac F5914-900 SpinScrub...
Brushes on Hoover steam vac dual v do not turn
(1) Assure the Brush Control on the hood is NOT set to the OFF position.
(2) Remove the brush assembly by pulling/unlatching it from base on each side.
(3) Does one of the brushes have the drive pin present? It should be about ¼ inch square, and two inches long. It attaches the brushes to the drive mechanism.
(4) Remove and clean the intake filter. One the base of the cleaner, behind the brushes, squeeze the two red abs together and pull the panel down to access the screen. Clean the hair/debris off the screen and reassemble.
Nov 19, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover Steam Vac Spin Scrub
Remove the brush block, is the shaft on it or broken off. Replace the block if broken off. Turn unit over, with brush block removed, handle tilted back, is the square hole turning, if not then the turbine is bad, this is what turns the brushes.
Sep 01, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Drive went out on my Hoover Steam Vac Shampooer and brushes won't turn plus there's a burning smell coming from it. Only used it 6 times - bought it in March - 2008.
Generic problem for all Vacuums
Posted by buster_lls on Jul 09, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. It sounds to me like you have multiple problems with your power drive; a burning smell and the brushes don’t turn, and the dop is on March, 2008 – the Hoover Steam Vac Shampooer has a one year factory warranty and it could be a broken part for the brushes won’t turn or a belt would cause the burning smell. If it is not the belt or broken part it probably is the motor of which you should take it to a authorized Hoover vacuum cleaner dealer in your area or to contact the Hoover factory cust serv listed below or the Hoover website for information. If it is the motor the factory authorized dealer will replace the part for the motor and the broken part for the brushes, if it is the belt that would be an out of pocket expense. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions. Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 09, 2008 | Vacuums
The brushes will not turn. How do I open the unit to put the belt back on?
Hoover doesn't use belts on their steam cleaners. Either the shaft that is on top of the brush block broke off, or the turbine is bad. The turbine is what turns the brushs.
Jun 12, 2008 | Hoover F7220900 SteamVac V2 Upright Vacuum
Hoover steam vac dual model F7425900
If you are talking about the brush block, take it out and see if the shaft that goes up into the turbine is broken off, if not, then the turbine has gone bad and will have to be replaced. The turbine is what turns the brushes.
Jan 20, 2008 | Vacuums
Bissell 1697-7 Powersteamer Pro Deluxe Vacuum Logo
62 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
