Question about Nikon Coolpix S210 Digital Camera
Nikon Coolpix S210 lcd broken - need step by step instructions
My Nikon coolpix S210 lcd was broken. I bought a replacement screen on ebay, but need step by step instructions on how to replace it. Can anyone help? Thanks in advance!
CPL
  • parkatola Sep 16, 2009
    I'm the one who posted the question, and with dlundmark's suggestions, I gave it a try.
    Sorry, no pictures of the process. (That's the whole point.)
    For the Coolpix S210, I purchased a replacement screen that came with a screwdriver and tool to use to pry the camera open. (About $25.)
    I took out all the screws, noting which ones went where. Then I pried off the back of the camera.
    The LCD was in a small, lightweight metal frame, but it was taped closed. I had to carefully work off the tape because the LCD backlight was also part of that frame. If you're doing this, and the frame is taped, go slowly and carefully. My LCD was totally trashed, so I didn't have a problem using a sharp knife to cut the tape between the frame and the LCD, but had to peel it away in other places.
    Once the tape was removed, I was able to lift out the LCD and keep the backlight in the frame. (I'm assuming that it was the backlight, because I've read other instructions that talk about them, and there was another narrower cable running from the light metal frame to the camera innards.)
    I wasn't sure how the LCD cable (about 1cm wide) hooked into the connector. I tried lifting the cover, but couldn't get it to move. I tried lifting it with the cable itself (again figuring that the LCD was already trashed), and it popped up. I took out the old LCD and cable, and carefully fitted in the new cable into the black clip, and pushed it closed. Then, I fit the light metal frame around the new LCD, and worked it back into place.
    I screwed on the outer frame screws, put in the battery, and SUCCESS!
    Tips/suggestions: As dlundmark notes, keep track of where everything goes. Go slowly. Don't force anything. Don't get frustrated. Take a few deep breaths, and use a magnifying glass and good light to make sure you can see what you're trying to do.
    Best of luck if you need to do this. I've never tinkered with a digital camera before, so this was my first project. As noted above, it worked. Good luck.
    Parkatola
  • parkatola Dec 14, 2009
    to AMG1167:
    I found mine on e-bay. I searched for the make and model of the camera plus LCD (or replacement LCD). Mine also came with a small tool to pry the camera apart (not as bad as it sounds, but after you've removed the screws, you need something thin to slip between the two halves to twist them apart). Hope this helps.
    Parkatola
  • 797 Answers
Most cameras are not that hard, if you are careful and willing to make notes of where each screw came from.
Be sure to get the correct screwdriver to fit the screws correctly and use enough pressure directly to loosen each screw...this is quite important, because if you strip the screw's head, it can be messy.
Most LCD screens are directly under the back cover, and can be replaced usually, once the back is off, remove three or four screw which will hold the LCD frame on. Once that is loosened, then you can carefully remove the screen and see if you need to remove anything else before loosening the cable plug. Take care here, because there are a few different ways these cables may be connected. Some are simply pushed into a connector. Some have a socket which has locks which must be loosened to remove the cable. These little sliding plug connectors are delicate, so you must take it slow and not rush the job. Some of these fold up to loosen, some simply slide away a bit to loosen the plug lock.
Most anyone who has done any delicate work on anything electronic will understand what I am talking about here.
A repair manual may be able to be downloaded for free, but you may have to be a member (usually free) in order to download manuals. Some may charge a small fee for the pdf file.
Hope it all works okay.
Posted on Sep 11, 2009
Testimonial: "Thanks for the suggestions and help. It worked."
I have the same problem with my camera. Can you tell me where you got the LCD screen for $25.00. I have not been able to find it.
thanks
Posted on Dec 12, 2009
I found my replacement screen at the Virtualvillage.com! $29 plus shipping!
Posted on Nov 18, 2009
Step by step to setup mode in my nikon coolpix camera
See the illustrated instructions on page 17 of the manual. If this isn't the initial setup, see the details in the paragraph at the bottom of the page.
Jan 26, 2012 | Nikon Coolpix S210 Digital Camera
Is the LCD screen replaceable on a Coolpix S220? Mine took an impact and is broken.
Yes, you can buy the LCD screen $14 on
http://www.ebay.com/itm/Nikon-Coolpix-S220-Replacement-LCD-Monitor-Display-USA-/220841672193?pt=Digital_Camera_Accessories&hash=item336b307e01
If you have patience you can install for ypurself or you can go to service center
Is important for people who share their knowledge, know your comments.
If the answer is helpful, rate my answers
Sep 21, 2011 | Nikon Coolpix S220 - Aqua Green 2.5" LCD...
My screens cracked
There is a site which explains how to replace LCD screen.
http://camerarepair.blogspot.com/2007/11/fixing-or-replacing-broken-lcd-screen.html
Jan 05, 2011 | Nikon Coolpix S210 Digital Camera
Broken screen
You can purchase a replacement screen for around $55.00 in US, or go on ebay for $20.00 and it is shipped from Hong Kong.
http://www.darntoothysam.com/categories/Nikon-Digital-Camera-Parts-and-Repair-Service/Coolpix-L-Series/
Aug 22, 2009 | Nikon COOLPIX L18 Digital Camera
Broken Nikon L20 LCD Screen
door where the battery goes broke
May 29, 2009 | Nikon COOLPIX L20 Digital Camera
How do I remove the lcd screen
The thin black piece pivots up towards the battery door, and the ribbon slides out.
Nov 08, 2008 | Nikon COOLPIX S9 Digital Camera
Nikon Coolpix S210 Digital Camera Logo
1,244 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
