I also brought this TV during 2007 Thanksgiving sale. Yestarday onwards, we were getting problem with blank screen and a smoke smell from top of the TV. Audio works fine.
Does Polaroid covers any replacements for such problems?
Any help is greatly appreciated.
Raj
Open the cover and look for the burned componet.Usually it must be a condenser. Rarely a resistor.If it is a condenser just replace it with the similar one. Note the polarity while replacing. If it is resistor need to check the associated circuit for over load. If you not sound in electronics reffer to an expert.
Replacing 2 capacitors 10uF 450V in the power supply fixed my problem.Hope this helps
Hi breezeloe,
Power on the unit in the dark room then shine with the flashlight directly in
the screen, you will barely see the images. This is because your backlight is
not functioning. The following reason is the caused.
1. Power supply - missing
B+(supply voltage) coming from this board feeding the inverter board. This is
caused by faulty transistor, dried/leaky electrolytic capacitor, open fusible
resistor.
2. Inverter board - even
the B+ is good from the power supply, if the fuse, driver transistor, driver transformer
is faulty no output to the backlight resulting to black picture.
3. Busted backlight - even
inverter board is good but if this is busted resulting to black picture also.
Diagnosing the fault is technical and if you don't have necessary tools and test instrument and can't fix it yourself, I would
advice you to look for an experienced
technician to isolate the
problem.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
