My laptop is full. I have a 2002 Dell Inspiron 2600,with Win.XP with 18.6 gigs . Now I have less than 200mb of hard drive .Please give me some help on how to dump all the trash and reinstall as I have the the re install disk. Thank you in advance. KM in Pueblo Co.
  • 224 Answers
1) Accessories---System Tools---Disk Cleanup, this will clean up most of your trashed, unused files and free your disk.
2) Try and move old unused files to some DVD, if you don't have DVD writer move it using pen drive, this way your old unused data will be safe.
This way you will be able to free up at least 40% of your laptop disk space.
Posted on Sep 11, 2009
Testimonial: "Thanks for the fast response. It has helped, Hope it will help others KM"
Dell bootmgr is missing
Most likely cause is that the boot order in the BIOS is set up for the HDD first. When turning on the unit, press the key needed to enter setup. Once in setup, search thru the menus for the boot order. Choose the CD drive as the first boot device, then the hard drive as second. Save and exit the setup. When rebooting, ensure the WIN XP CD is in the drive. When the screen says, "press any key to boot from CD", press a key and the WIN XO CD should take over and start the install. Once WIN XP starts installing, follow directions. On each restart after that, DO NOT press the key to boot from CD. WIN XP setup will handle everything until the reinstall is complete. After you are done, you may choose to go back to setup and change the boot order back, but it is not really necessary. The only time you will get the "press and key to boot from CD" message is when there is a bootable CD/DVD installed in the drive. Otherwise, it overlooks it and goes to the next boot device (HDD).
Sep 07, 2014 | Dell Inspiron 2600 Notebook
My Dell Inspiron 6400 (Windows XP Home) won't reboot. It's giving me a "Loading PBR for descriptor 1 ... done" line on a black screen. What can I do to fix it. Can I salvage my content / files
Before you use the Recovery CD you need to backup your data because to restoring your laptop will wipe your data off the hard disk.
To backup your data when you cannot boot up your laptop, remove the hard drive and connect it to an USB hard drive adapter. Connect this hard drive/USB adapter into the USB port of a working computer. The computer will see it as an external storage device, you can then open the folders and backup your data.
You can then fit the hard drive back into the Dell laptop and boot up with the Dell recovery CD to reinstall Windows etc.
Mar 04, 2013 | Dell Inspiron 6400 Laptop Computer Core 2...
Need hdd password for dell inspiron 2600 laptop
You can format the hard drive with a windows disc which will get rid of the password and all personal data. The second option go to www.ebay.com Type HDD password, there are a list of sellers for a fee can recover the password, read carefully.
Jun 25, 2012 | Dell Inspiron 2600 Notebook
HELLO!PLAESE HELP ME.I HAVE dell vostro 1015 windows vista but i want to convert it into xp,the problem is whenever i try to install windows xp a blu screen appears saying that something about my bios
Are you using a full version retail or OEM copy of WIN XP to install? Or is it a recovery copy from another PC or laptop? You will need to use a full version disc to perform the retrofit. You will also need to download the WIN XP Drivers for your laptop from the Dell Site. You CANNOT "upgrade" install WIN XP over VISTA and keep your drivers, settings, files. Performing a WIN XP install will require a total wipe of your hard drive. Therefore you will have to save off all your personal files before you do this. Microsoft doesn't provide assistance for downgrade-type installations, so you must basically wipe your hard drive and then reload the OS.
Jan 07, 2012 | Dell Vostro 1015 Laptop
Install Win XP SP 2
Yes you can, Do I recomend it, no, Why?
Windows easily uses up to 756MB of RAM to run the O/S alone but can run at a minimum of 512MB.
I have personally seen it run on as low as a 900Mhz processor, 256MB of RAM and on a 10 gig hard drive.
If you decide to install windows XP on the specs you describe above please note the following.
1. System will be very slow and have lengthy start up times.
2. Applications may crash or take a long time to open.
3. With all the updates for WinXP you will easily use 8 gigs for installing XP and its updates. Not to mention whatever software you will use/install.
4. On a system with those low specs, you probably have a low end video card whcih may result in: A. chooppy windows, screen freezing, system crashes and lock ups, low video graphics all around.
I would probably go with windows 2000 instead. If your bent on having XP, at least upgrade the RAM to as much as possible. Then install windows and only install the programs you really need, remove any other junk.
Hope this is of some help to you, good luck
Feb 17, 2009 | Dell Inspiron 4000 Notebook
Hard drive caddy stuck
Try giving it a lift and then try to remove it.
Feb 05, 2009 | Dell Inspiron 2200 Notebook
Multiple Boot on a Dell Inspiron Laptop
Invest in a couple USB drives and install the other os's on them. before you boot up plug in the apropriate drive and boot from it. Thats less complicated and painful to me
please, Let me know :)
Dec 24, 2008 | Dell Inspiron 6400 Notebook
Deleted dell system restore partition
Dell usually supplies all the cd disks your computer was set up to use. the Win xp restore disk will reformat your hard drive with the original partition. I have a dell 4600C desktop and all my original stuff is on the burgundy win xp disk. the auxillary stuff is on the blue cd-s.
Dec 28, 2007 | Dell Inspiron 6400 Notebook
Computers & Internet Logo
70 people viewed this question
David Payne
David Payne
