Power is on - lights are flashing but the carriage does not move it seems it has just locked is there a keystroke to unlock ?
  • 2 more comments
  • artie3030 Sep 11, 2009
    I have a typewriter
    I have a Lexmark International typewriter Serial # 11-7Y551 Power is on - lights are flashing but the carriage does not move it seems it has just locked is there a keystroke to unlock ?
  • 13,433 Answers
Lights are flashing would indicate a error condition or a fault.
can you send me the brand and model and tell me which lights are flashing.
Posted on Sep 11, 2009
  • 742 Answers
Try to pull out the cord to turn the unit OFF abruptly. Then after 3 minutes turn it back ON. The unit should initialize and start. try also to look at the inside part of the unit for debris preventing the movement of the head.
  • 854 Answers
- remove cartriage and insert again
- power cycle the copier
- check for jammed paper
- check paper try if fitted well
send the model of the copier
  • redhaze89
    redhaze89 Sep 11, 2009
    Option 1
    Electrolytic capacitors may cause this problem (might be bulging).
    Replace them all in CPU boar.
    option 2
    You can get service manuals on EBAY. But, if all the lights are flashing and you get 6 beeps. The batteries need to be replaced.
HP Photosmart Premium C309 with all lights flashing. Won't do anything, even scan. No resets work. All I want to do is scan. Help.
Either the carriage is jammed or there is a major electronic board failure. With the power disconnected, try to move the carriage back and forth with your hand. If it seems sticky, clean off the carriage rod and put a drop of light oil on it. Then work the carriage back and forth until it moves freely. Plug in and all should be well.
If this does not help and you can't find any jammed paper or objects, you have a major failure and it will be cheapest to buy a new unit.
Sep 22, 2016 | HP Photosmart Premium C309A All-In-One...
How do i install a black cartridge? in TX110 printer
If ink level reach ink out level, follow How to.. on Epson status monitor. But, if it's not, turn off printer. Unlock carriage lock, then move carriage by hand. Or you can turn on printer and unplug power while carriage moving. Then move by hand freely. Courtesy of " aicaxz
  • Rank: Wiz epson.gif
Dec 27, 2010 | Epson Office Equipment & Supplies
Red and green lights are flashing alternatively and colour ink cartridge has run out. How do i change the cartridge?
Flashing alternately mean waste pad full. Reset using SSC utility or Adjusment program/resetter. But, you must replace cartridge before. Turn off printer, unlock carriage lock (left side of carriage at parking position). Move carriage by hand to replacement position. Replace ink tank. Reset using the resetter.
May 21, 2010 | Epson Stylus C46 InkJet Printer
How do you unlock a De Ville 410
Are you saying the carriage is locked, so it can't go back & forth? Sticking out of the right-hand side of the carriage are two tabs; I think they're light blue. Pressing down one one locks the carriage. Pressing down on the other unlocks it. When the carriage is unlocked and moves out of the way, you can see the ramps and notch molded into the bottom of the case to hold the carriage for shipping.
Feb 17, 2010 | Smith Corona Office Equipment & Supplies
Scanner carriage jammed #3 and #6 does nothing.
Check if you haven't moved the scanner lock lever accidentally - find the lock lever (used to immobilize the carriage in transport) and move it to locked position, then to unlocked, and power up your unit. Chances are that the carriage was not dislocated when trying to move while locked, and will start to operate.
If it's not that, it may be a number of things, like broken belt, encoder strip (if any), carriage motor fault - things you won't be able to repair yourself.
Nov 12, 2009 | HP Office Equipment & Supplies
Epson Perfection V500 photo scanner, carriage unit unable to move
I have had the sam problem on 2 of the same scanners. Open the scanner cover and slide the transparency unit transportation lock to the unlocked position. Then close the scanner cover.Power it on and there you go.Somehow this little switch can get moved and there is the grinding noise and not working.
Aug 16, 2009 | Epson Perfection V500 Flatbed Scanner
Epson perfection 2400 photo scanner stuck with flashing red light
You may have accidently pushed the LOCK button - this button is used to LOCK the carriage into place when moving the scanner to another location or shipping it.
Check for a button and the picture of a LOCK, it is usually at the back of the scanner, you can push it left or right, and you have an open lock and a closed lock picture under it. Make sure you didn't accidently push it to the LOCK position when holding the scanner - that loud sound means your carriage is locked and cannot move - once you set the button to UNLOCK this should solve your problem.
Jul 27, 2009 | Epson Perfection 2400 Photo Flatbed...
Red warning lights remain on.....
Ink and paper light on : head carriage error/general error. Head can't move extremely to right : head carriage blocked or CR motor error. Turn of printer, unlock head carriage lock. Move head left and back to right (to parking position). Is it move freely?
Jun 16, 2009 | Epson Stylus Photo R200 InkJet Printer
Ink carriage not working properly
this is a common error whith this printer, if you keep on trying it WILL return to the (exchange ink) position eventually ,however,Another neat trick , When you try to change ink and the thing moves unplug the mains power cable , once you have done this the cartridge will be unlocked and will move freely anyway,, move it by hand and install the ink you have,
May 23, 2009 | Epson Office Equipment & Supplies
HP deskjet 5550
If there is power to the machine then there is most likely something broken in your printer. If there is no power then the carriage is locked. Turn the machine on, when the carriage moves pull the power. The carriage will now be unlocked while the the power is off.
Oct 20, 2008 | HP DeskJet 5550 InkJet Printer
16 people viewed this question
k24674
jasbo
jasbo
