Question about Garden
Buddy turned air fuel mixture screw on 5hp mini bike engine
Now it doesnt start and when it does idles to fast
  • josh hibben Sep 11, 2009
    idle mixture screw
  • 2,841 Answers
Start the engine and turn the screw in ever so slightly inward. You will know if you are going in the right direction. If you cannot start it, turn the screw slightly in or out until it starts, and then make slight adjustments. Once you get it set right it will run correctly.
Posted on Sep 11, 2009
  • 11,896 Answers
Two screws. One for idle mixture, and one for idle.
I have a 01 katana 600. just had sparkplugs changed.bike was running good for about twon weeks now it dont want to go past 50mph on highway.it also takes time to pick up speed. what could be the cause
How did it run before replacing the plugs? Did the problem start suddenly or slowly slowly develop? Does it start and idle ok? Did it happen right after getting gas?
Mar 04, 2015 | 2001 Suzuki GSX 600 F (Katana)
2015 Polaris 900 won't start. Was starting with fast idle, rough running with backfires, now won't start at all. Was running perfect.
fast idle start usually indicates an air leak somewhere.check carburettor bolts are tight and engine head bolts are tight.try that first
Feb 19, 2015 | Polaris 2015 Ranger XP 900
What are standard settings for idle and air mixture screws
The idle speed will be dependent on model, particularly if 4- or 2-cycle, 2, 4, 6 cylinders, etc. If your engine uses carburetors, I'd say no less than 600 RPM, maybe up to 850 RPM at idle. If your engine is fuel injected, the computer should set the idle speed and air mixture for you (if it's functioning correctly), and a big twin could idle as high as 1150 RPM .
Your Idle air mixture settings are important for proper idle. A good approach is to let the engine tell you what it likes. For this method you will need either a tachometer or a vacuum gauge. Here are some steps to guide you.
1) If the engine will start and run, go from there. If not, a good initial setting is to turn the idle screw(s) all the way in (GENTLY--don't break the seats!), then back them out about 1 1/2 to 2 1/2 turns.
2) Attach either your tachometer or vacuum gauge to your engine. Tach is connected to the ignition system (usually at the coil); vacuum gauge would be connected to a manifold vacuum port. (The bike's built-in tach MAY work for this, but they are often not graduated finely enough.)
3) If using a tachometer, warm up the engine. Working on only one idle mixture screw at a time, begin turning it IN until RPM begins to decrease. Then back the screw OUT again until you achieve maximum RPM on that screw. Feel free to "play," turning the screw in and out until you achieve highest RPM at at minimum turn-out (if you leave it turned out too far, bike will run rich and foul spark plugs; if not far enough, bike will run lean and hot). Now do the other idle mixture screws the same way. Finally, go back and do all the mixture screws again (and again and again, if necessary) until all throttle bores are synchronized.
4) If using a vacuum gauge, engine temp is not as critical, but go ahead and warm it up anyway. Similarly to the tachometer method, turn the mixture screws in until RPM drops, then out until max vacuum reading at minimum turn-out. If you have multiple mixture screws, do the same on each, then repeat on all screws until you feel they are all synchronized.
5) Throughout the process of adjusting idle air mixture screws, you will probably have to adjust the idle screws to keep the engine in the RPM range you want it to idle. (If adjusting air mixture screws has no effect on the engine idle, the minimum requirement is probably a carburetor rebuild.)
6) Have fun getting to know what your engine "likes!"
Oct 14, 2014 | Motorcycles
Air intake problem or carburater problem?
Check there are no air leaks around where the air intake rubbers are at your carburetor. It sounds like your bike is running too lean or weak which means your air/fuel mixture is running on too much air and not enough fuel. This would explain it running smoothly when you put the choke on as the choke "chokes" the majority of the air from the carburetor and allows more fuel to flow through the carburetor creating a richer mixture. There will be a mixture screw somewhere on the carburetor which will allow you to either richen (more fuel and less air) or weaken (more air and less fuel) by turning the screw either in or out. Only adjust this by a small amount (about a quarter turn at most) at a time and try the bike to see how it rides each time. After adjusting the screw each time let the engine idle for about 30 seconds or so to let it settle to the new mixture setting before riding. There will be another screw on the carburetor which is your "idle" or "tick over"speed adjustment screw which adjusts how high your engine revs while the engine is "ticking over". Turn it in to increase idling speed and out to lower the idling speed. This will probably need adjusting as you change the fuel/air mixture. I hope this helps you and good luck :o)
Jul 17, 2013 | Motorcycles
Honda gx160
Kescorpio56:
Check your throttle and choke settings. Something is causing the throttle plate in the carburetor to remain open or the governor is improperly set. I would reset the air/fuel mixture screws to one and a quarter turns out and back the idle screw all the way out. Make sure that the throttle cable operates the throttle properly and check the governor setting and reset the governor setting if needed. Start the engine and adjust from there. When the engine starts, adjust the idle screw until the engine idles. Adjust the fuel/air mixture screws for the best idle. Then run the RPM up and adjust the fuel/air mixture screws for the best run/idle combination. Don't forget to adjust the governor if the engine runs too fast or too slowly.
May 31, 2013 | Air Tools & Compressors
1996 Kawasaki ZZR 250 air/fuel mixture setting
Hi, Whiskers_57 it should be noted that the "AIR FUEL" mixture screw adjustment "ONLY" manages your idle and has no effect on any other circuit also any intake leaks must be repaired before the A/F adjustment procedure can be performed otherwise you will never obtain a proper idle and you will waste a lot of time chasing the impossible. The A/F mixture screw's purpose is to fine tune the fuel charge entering the combustion chamber. The following applies to both 2 and 4 stroke engines:
1. The mixture screw may be sealed at the factory with a Welch Plug please review the following video for removal.
https://www.youtube.com/watch?v=wAXcksgvDkM
2. The mixture screw manages a range of 3 complete 360-degree counterclockwise turns from the bottom/closed position.
3. The mixture screw should have a spring and o-ring for tension and sealing integrity.
4. Turn the mixture screw clockwise until it gently bottoms out, this makes the fuel charge very lean and the engine should not idle if it does then the pilot/idle jet is too big and needs to be replaced with the next size smaller.
5. Turn the mixture screw 1 and 1/2 turns counterclockwise to establish a baseline for starting the engine.
6. To fine-tune the idle circuit, adjust the mixture screw 1/4 turn in or out to achieve maximum idle RPM, wait 15 seconds between each adjustment for the idle to settle.
7. Never go past 3 full turns out this will make the fuel charge rich, foul plugs, and produce black smoke out of the exhaust, if the engine RPM keeps increasing past 3 turns the pilot/idle jet is too small and needs to be replaced with the next size larger.
8. After achieving maximum idle back out the mixture screw another 1/8 of a turn then adjust the throttle cable idle stop screw to 950-1050 RPM.
9. This procedure works great on 99% of all engines, for the 1% that demand a more robust throttle response on aftermarket monster fuel delivery systems additional tweaking outside the box may be necessary.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
How do adjust the idle mixture
DIY Accessing and adjusting idle mixture screws ninjette org
Kawasaki ZZ R250 Service Manual Page 2
OEM Parts for Kawasaki
Kawasaki Ninja Owners Manuals
Apr 07, 2013 | 1996 kawasaki ZZR 250
Honda H100 SJ carburetor A/F mixture settings
Hi, Michael it should be noted that the "AIR FUEL" mixture screw adjustment "ONLY" manages your idle and has no effect on any other circuit also any intake leaks must be repaired before the A/F adjustment procedure can be performed otherwise you will never obtain a proper idle and you will waste a lot of time chasing the impossible. The A/F mixture screw's purpose is to fine tune the fuel charge entering the combustion chamber. The following applies to both 2 and 4 stroke engines:
How to tune air fuel mixture
How to adjust carburetor jetting and mixture explained
Honda CB125S Shop Manual
https://www.partsfish.com/page/oem-parts-for-honda
Honda CB Owners Manuals
Feb 09, 2013 | Honda Motorcycles
My 1995 honda accord will start and then die what is the problem?
well i could be a copule of things it could be the fuel filter it could also be that the fuel pump is going out it could be clogged fuel lines it could be dirty air filter it could be the timimngs off and it could be the spark plugs or wires are going out
Sep 14, 2012 | 1995 Honda Accord
How do i idle down the engine or govern down the engine on a briggs and stratton 550 series mower model 10T802
that engine uses a fin style governor remove the upper cover and see if there is a nest or something holding the fins movement
Jul 12, 2012 | Briggs & Stratton Briggs Stratton...
Fast idle 90 GMC Sierra
if you haven't disconnected the battery try that next
May 24, 2017 | 1990 GMC Sierra
Garden Logo
55 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
