Question about RIM BlackBerry? Curve 8330 Cellular Phone
Same same same
Same stuff,everything works but camera n movie mode aren`t.
Tried all resets n update to 4.5 but nothing is working...
Need asistance please
Video/movie mode stuck
Have you tried to reset the camera?
Reset switch is on battery compartment you will need a small needle or toothpick. Let me know if this works!
Jan 02, 2008 | Sony Cyber-shot DSC-W100 Digital Camera
Sprint TP2 with no data
well, this is obviously not an Android handset. however I have a TP2 on Sprint and run Android as well and I get data and wifi.
I would suggest going back to the forums where the developers are working on this stuff (ie: ppcgeeks dot com, etc) and grab a newer copy.
your inquiry is obviously not supported but it does work (with GPS too). There's still no main speaker nor camera, etc but I can totally get/ use data, google maps (sucks without sound but whatever).
you likely know you can also update your OS to WM6.5 and the new Bing has navigation integrated and it's actually pretty good
Jun 03, 2010 | HTC Touch Pro2 Smartphone
Is there anywhere can reset my computer cause there is stuff i cannot delete on my travelmate 2200 without disks
I opened a mail that contained a virus. I updated Kaspersky 2010 scanned tha computer, downloaded Spybot installed it and cleaned up the problems. The problem now isthat the computer boots up, goes to desktop without any icons, and then logs off. I tried all safe modes, booting from a cd and everything else I knew, but nothing seems to work. The main disk is partitioned in C and G drives with G housing all the data and C mainly the programs. Don't know what to do anymore please help!!
Jan 16, 2010 | Acer Travelmate 2200 Notebook
My PS3 wont play any movies but still plays video games???
Ok so its 60GB its definatly alright to play movies and all sorts, but if you are that desperate to watch movies then you may want to reset to factory settings just access settings and look for reset console, then it would start from square 1 you have to make your accounts and earn your trophies again but if you want to watch movies desperatly then recommed you do that or go to game settings in the game column and have a poke in the folders because there might be a few things in there or go to the film column and check for setting sin there or go to the settings column and check for film settings in there its nothing to do with the updates thats for sure because ive done the same as you but havent played the game in a while but im still able to watch films
Aug 08, 2009 | Sony Playstation 3 (PS3) Console
Locked out of the menue ,Need to reset command mode
Indeed, I did the same thing.... I did find the answer in the manual!
Here's a copy of it (pg 23):
Set the command mode for the remote so it matches
the command mode for the recorder you set above.
1 Hold down ENTER
2 While holding down ENTER, enter the
command mode code number using the
number buttons.
Command Mode Code number
DVD1 number button 1
DVD2 number button 2
DVD3 number button 3
3 Hold down both the number buttons and
ENTER at the same time for more than 3
seconds.
4 Let up, press RETURN, all done!
Jul 28, 2009 | Sony Televison & Video
How do I get out of Movie Mode?
Unfortunately it sounds as if that camera will need to be sent in for service. Call Tech Support at 1-800-828-4040 to do a little troubleshooting and get your possible repair options.
Hope this helps.
Sincerely,
HeavyDLB
May 24, 2008 | Canon PowerShot A570 IS Digital Camera
Camera Frozen
I tried Option No.1 successfully when my Panasonic DMC-FZ7K froze once:
Option No1:
1. Try turning the camera on with the battery inserted.
2. Now remove the battery while the camera is on.
3. Flip the switch on the camera to off, then insert a fully charged battery. (Make sure that the battery's orientation is correct. Also make sure that the battery being used is not damaged).
4. Now flip the camera's switch to ON again.
Option No. 2:
If you can open the Setup menu then the camera can be reset which might help:
Turn on the camera.
1. Press MENU SET.
2. Press the left arrow button.
3. Press the down arrow button.
4. Press the right arrow button.
5. Now, press the up arrow button several times until the menu item named RESET is highlighted. Push the right arrow button and then select and set YES when the camera asks to be reset.
Oct 18, 2007 | Panasonic DMC-FX07 Digital Camera
PLEASE HELP ME! Panasonic firewire connection won't work!
In short, many people have firewire issues such as missing motherboard drivers, or dead firewire ports. You have to show it working on some machine before you know to try to fix your machine. Did you try Movie Maker?
Sep 06, 2005 | Panasonic AG-185 Camcorder
RIM BlackBerry? Curve 8330 Cellular Phone Logo
35 people viewed this question
Top RIM Cell Phones Experts
Computer Repairing
Computer Repairing
Longtime User
ismael castillo
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
