Question about Kohler K-8030-CP Polished Chrome WaterTile WaterTile Rain Shower Overhead S
I need parts for a Kohler watertile
The gasket and black plastic piece that holds the gasket on my Kohler watertile is damaged. I can't find them separately and don't want to replace the entire tile. Where can I buy parts for this product?
  • 30 Answers
The link below is a flash page from the Kohler site that will allow you to find the correct part and order it directly from them. Please note that 22 nozzle version is on the left and the 54 nozzle version is on the right (they share most parts).
http://www.kohlerserviceparts.kohler.com/ServicePartsPage.aspx?DocumentID=99c05672f13f47a9a1b79ddf02ef6a01&ModelID=a459511abb154ecc908927a35cb9a015
Posted on Sep 18, 2009
The three-bolt gasket seal between the upper half and the bowl; how do you get the plastic water flow out from the gasket?
I assume you have separated the tank (the upper part) from the bowl. The rubber gasket just pulls off. Under the gasket you will find a large nut holding the plastic flush pipe to the bowl.
Dec 14, 2010 | Kohler K-11466-0 White Cimarron Comfort...
I have a K4632-AA which usually works just fine but now it has started to run water every few minutes. What might be the probelm and how can I fix it?
Toilets seem to run on their own because the water in the tank is seeping our past the seal that was designed to keep it in the tank inbetween flushes. Commonly called flappers, they go by seals, tank balls discs. etc. The K4632 requires a flat seal from Kohler. The actual part number is 1059291, however Kohler may only sell this as part of a kit by a different number with pieces not truely needed in your circumstance.
You should contact them at 1-800-4KOHLER, navigate the prompts, and talk to a service member. You may have to do some research in your area to find a retail or wholesale business that will order this for you. There are circumstances where, with some parts, Kohler will send the parts free to your doorstep. No promises on this one. I have put a link below that will give you a complete parts explosion for your reference.
http://www.kohlerserviceparts.kohler.com/ServicePartsPage.aspx?DocumentID=28e40a91273141a5b63e28ad7230d6a5&ModelID=e9143848792b4415a62b4e384caeb856
Nov 09, 2010 | Kohler Home
I need to change the gasket 83996 on my kohler santa rosa toilet,but cant get the part that says waterline off.how do i get it off?
You have to twist the whole thing. There is no nut or threaded portion under the gasket like you'd find on most (two-piece toilets). The hole under the gasket seal is a triangle-shaped and the bottom of the flush valve (the part that says waterline) has three prongs that lock the unit down against the gasket.
I don't remember which direction worked, but I put the grip/handle of a channel lock pliers down into the flush valve and that gave me the leverage to remove the whole part with gasket.
Nov 01, 2010 | Kohler - Toilet - One-piece - Santa Rosa -...
I have to replace the gasket which the flush valve sits on. How do I remove the flush valve. The toilet is Kohler 1 piece model K-3323
The top of the pipe above the flush valve is threaded if you unscrew this you will be able to remove the flush valve and replace the gasket. I am assuming we are talking about the same here is a link that has all the parts:
http://www.plumbingsupply.com/kohlertoiletparts-santarosa.html
Oct 24, 2010 | Kohler - Toilet - One-piece - Santa Rosa -...
I have a Kohler toilet. The triangular black gasket between tank and boel needs to be replaced. While I had the tank off, I noticed the large plastic pipe that comes from the tank is threaded like a screw....
Inside the tank it has a gasket from the stand pipe to the bottom of the tank. The stand pipe threads go through the tank and a plastic nut holds it to the tank. Then a gasket goes on the nut and threads to make a seal between the tank and bowl. I have included this picture that has the above look. I hope this will be of some help for you.
Sep 02, 2010 | Kohler KOHGP51487 Authorized Original...
I cant get the new flush valve on my kohler 3386 toilet to fit in the hole with the gasket. The foam gasket is quite thick. Is there a trick to doing this short of mutilating the thing?
The foam gasket stays on the inside of the tank, the only part that gets pushed through the hole is the hard plastic threaded part, then you add the rubber washer and the nut from underneath.
Jun 26, 2010 | Kohler - Toilet - One-piece - Gabrielle -...
How install Kohler part no. 87988 in Santa Rosa
look under the tank, their should be a nut holding on the old one. by removing that nut the part should free itself.
Feb 27, 2010 | Kohler Santa Rosa K-3323-0 White Compact...
Gray plastic piece that holds the black clips that holds the door shut is cracked
you tape the door shut just make sure tape does not cover and vents. check web sites for parts?
May 12, 2009 | Minolta Di3510f Bizhub Copier
Black and decker mm675 lawn hog
Wedge a short piece of 2x4 between the blade and the housing,
turn clockwise to tighten !
May 19, 2008 | Black & Decker 19" Electric Lawnhog...
Kohler K-8030-CP Polished Chrome WaterTile WaterTile Rain Shower Overhead S Logo
224 people viewed this question
Top Kohler Home Experts
Donni Steen
john h
Tim Whalen
Are you a Kohler Home Expert? Answer questions, earn points and help others
