Question about Hoover F7431-900 SteamVac Vacuum
Hoover steamvac won't spray water/cleaning solution
MIne won't dispense water and cleaning solution either? Any ideas how to fix it?
  • 14 Answers
Clogging of the pump that sprays water/cleaning solution is very common in Hoover and Bissell Steam Vacs. Try running a cycle of 1part vinegar or CLR to 3 parts warm, distilled water through the vacuum pumps. The heads get clogged with soap and the water pumps get clogged at the opening of the flash heater due to minerals in hard water. If you want to extend the life of your steam vac, don't use the heater unless you are using distilled water. This can get expensive, so I recommend not using the heater.
Posted on Sep 11, 2009
  • gloriabutrum Sep 03, 2010
    Where are the water pump located
V -024A WILL NOT DISPENSE SOLUTION
Try cleaning spray tip in CLR. Hard water?
Apr 14, 2014 | Hoover SteamVac F5914-900 SpinScrub...
Hoover SteamVac LS F5899-910
Did you try to clean first the unit..
Jun 01, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
My hover extract deep cleaner won't spray water or cleaning solution
If you have the receipt from when you bought it, take it to the closest Hoover warranty center and they will fix it under the warranty at no cost to you.
Jun 11, 2017 | Hoover F7431-900 SteamVac Vacuum
I have a Hoover v2 steam vac F7430-900 the water container will not dispense water only soap yes, any idea to fix this problem?
This is most likely due to a problem with the solenoid on the rinse side not opening. The solenoid may require replacement.
Jan 17, 2011 | Hoover F7425-900 SteamVac V2 Widepath...
My hoover steamvac spot doesn't spray
the pump has to prime first ,put water in the solution tank an yurn on and keep the trigger pulled till it sprays.if that don't work take it back
Apr 28, 2009 | Hoover F5505 SteamVac Spot Vacuum
Hoover V2 SteamVac
Under the detergent side, there is a metering plate,(located on the machine) which can be removed. ensure that this is installed. have you verified whether the machine will dispense detergent only without any water in the water tank?
Jan 03, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
Hoover SteamVac Model F5887-920 - hand attachment won't spray
I have a model I got in 2001. I found that the water sprayer on the hand tool is driven by a little turbine that relies on suction from the main vacuum motor. I eventually found that the spindle inside the turbine had separated and hence the hand-tool wouldn't spray. I glued it together but that only fixed the problem until it broke again. I am going to buy another (about $23).
Jul 29, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover cleaner model f5865-900
There is no belt, either the turbine part #43191003, or the brush block, the shaft that goes up into the turbine broke off part #48437022. The turbine is what drives the brushes.
Feb 02, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
I have a Hoover SteamVac Deluxe and it will not spray the detergent. I have taken it apart and still can't solve the problem. Any help or suggestions?
If yours has separate tanks for the solution and water, it is a pressure regulator switch. It happened on my mine and I replaced it. 3 hoses attach to it and it was located in the handle area on mine. If you mix your own solution in one tank, look at the spray nozzles. They can get plugged.
Aug 17, 2007 | Hoover F7205900 SteamVac V2 Wet/Dry Vacuum
Vacuums Logo
2,684 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
