Question about Toshiba Satellite P25-S507 Notebook
How do I replace the keyboard? - Toshiba Satellite P25-S507 Notebook
The solution you presented was very helpful, even though it did not directly address the problem I had. I was able to determine the solution to the problem I had. Thanks!
Posted on Sep 11, 2009
Testimonial: "Helpful, thanks! "
On my Lenovo g500 laptop many keys(gh and many) are not working, what should I do?
Connect to external usb keyboard to check. If works ok, your keyboard is defective and you should change it.
See tutorial
How to replace or remove keyboard on Lenovo G500 keyboard replacement
How to replace the keyboard of Lenovo g500 g510 g505
LENOVO G550 Keyboard Installation Replacement Guide Laptop Remove Replace...
Lenovo G580 G570 G500 G510 disassembly replacement keyboard hard disk full...
A warning: might look easy but if you are not really familiar with dismounting a laptop, you might end taking your device to a repair shp in a shoebox.
Jul 20, 2015 | Lenovo Computers & Internet
Remove keyboard 646125-001
  1. Prior to replacing your replacement keyboard for sony vaio vgn-fe880e/h, make sure to remove the keyboard and disconnect the ac adapter from your laptop.
  2. The first step to replacing your laptop keyboard is to remove the screws from the back of your vaio vgn-fe880e/h. Sometimes your laptop will have a picture of a keyboard next to the screws that need to be removed. Otherwise, see your laptop manual for details.
  3. Above the laptop keyboard for sony vaio vgn-fe880e/h, you have a cover panel. If required, remove this part to easily access your keyboard. If you have screws above your keyboard, remove those screws.
  4. Now that you have removed all the screws, you are ready to remove and then replace your new laptop keyboard.
  5. To remove the vaio vgn-fe880e/h Keyboard, take a thin object and pry the keyboard out between the keyboard and motherboard. Be careful when removing the keyboard.
  6. Now that your keyboard is loose, simply disconnect your keyboard. In order to disconnect the keyboard, pay attention to the keyboard connector and connector cable. Unlock the connector cable device and remove your laptop keyboard. Your sony vaio vgn-fe880e/h connector cable should be easy to remove by simply sliding it out.
  7. Now that your keyboard has been removed, get ready to install your new laptop keyboard. Look at the back of the keyboard. If you see any screw holes, you will have a good idea of where to place the screws back in at the bottom of the laptop.
  8. Connect your laptop keyboard for sony vaio vgn-fe880e/h to the motherboard keyboard connection slot. Secure the keyboard cable. Now turn your keyboard in place, and align the grooves on the bottom of your keyboard with your palmrest or plastic bezel. Secure your laptop keyboard in place, make sure it fits properly and is snug. Now simply place the screws back in place.
Nov 30, 2012 | HP 646125-001 - Keyboard Tm - Us
Laptop keyboard keys
To determine if the keyboard or the keyboard controller is faulty, plug an USB keyboard into the USB port on your laptop. If all the keys are OK on the USB keyboard then the laptop's keyboard is faulty and needs to be replaced. If the USB keyboard also malfunctions then the keyboard controller chip on the motherboard is faulty, then the motherboard needs to be replaced, but this may not be a cost effective solution.
A replacement keyboard for your model laptop maybe available from this WEB site.Keyboard replacement, LCD screens for mobile phones, Ipods and computer equipment. http://www.yallstore.com/index.php?main_page=advanced_search_result&search_in_description=1&zenid=1lrjst3ncshlb4c7frn9bev3c3&keyword=keyboards
Sep 07, 2012 | Computers & Internet
Few keya are not working
Sep 07, 2012 | ASUS A52f-xe6 A52f Ci5/2.66 15.6 4gb 500gb...
Keyoard o hp dv-6 laptop has keys that will ot work ay more
Connect an USB keyboard to your laptop and if the keyboard functions normally then you need to replace the laptop's keyboard or just use the USB keyboard.
You maybe able to get a replacement keyboard fron this site.
Keyboard replacement, LCD screens for mobile phones, Ipodsand computer equipment.http://www.yallstore.com/index.php?main_page=advanced_search_result&search_in_description=1&zenid=1lrjst3ncshlb4c7frn9bev3c3&keyword=keyboards
Aug 01, 2012 | HEWLETT-PACKARD Pavilion DV 6 Laptop
How do you replace presario cq62 backspace key?
In these situations its usually easiest to just replace the keyboard. Replacement keyboards could be purchased here. The service manual for your laptop can be found here. The section for replacing the keyboard starts on page 57.
I hope this helps
Ray
Mar 07, 2011 | Compaq Presario CQ62-215DX Laptop
The letter k on my keyboard functions only when some pressure is applied the netbook is almost new and has been hardly used is it possible that the keyboard needs already to be replaced
Judging on your symptoms, it sounds like a replacement keyboard might be in order. If the machine is out of warranty, you can purchase replacement keyboards yourself.
Search "(computer model) keyboard" into eBay. You should see many products available for a reasonable price.
You should have a screw or two on the bottom of your laptop that have a keyboard icon next to them. Removing these screws should allow you pop the keyboard out and replace it. There is also a ribbon cable under there, so be careful when removing. For more info, search "replace (computer model) keyboard" in YouTube or a similar site. There should be many tutorials on keyboard replacement.
Aug 23, 2010 | Computers & Internet
Replace keyboard on acer 8100 series laptop
Replace the inside of the keyboard with a new piece. One of the major problems with Dell keyboards is that the plastic pieces holding the keys in place become loose or broken. You can find a cheap keyboard from Papatek.com or an electronics store. Simply take apart the new keyboard, pull the keys off your keyboard, lay the plastic piece on top and replace your keys.
http://www.papatek.com/Acer-Keyboard/Acer-Travelmate-8100-keyboard.html
Jul 23, 2010 | Acer Ferrari 4000 Notebook
Replacable Keyboads
there are ways to replace laptop keyboards but it is expensive. try going to a computer repair shop, they may have a broken laptop with the same keys as yours. you can also get a external usb keyboard.
Apr 03, 2009 | Acer 91.63X07.001 Keyboard
Toshiba Satellite P25-S507 Notebook Logo
88 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
