Question about Motorola Mobility RAZR2 v9 Cell Phone
The only keyes that work are off and up and it randomly opens and closes the call log
Training mode closed how do i re open
The training mode on the 5200 is activated using a clerk number that has been programmed to be a training clerk. To log the clerk off turn key to REG and press 0 then clerk. Then log on a clerk which isnt programmed for training - try 1 then clerk. If that doesnt work, try 2 then clerk. Clerk key is usually top right key on keyboard.
Jul 15, 2014 | Samsung Sam4s ER-5200M Cash Register WITH...
Slow, logging out for reason, & freezing up @random intrvals
YOU ARE ALL NUTS, DELETE MY ACCOUNT? RU DRUNK? MAN WHERE AM I, HOTEL CALIF,?,, I 'M OUTA HERE, OH YA THE PROBLEM IS YOUHAVE TO MANY WINDOWS OPEN, IF U R MAINTAING YOUR COMP. THEN START CLOSEING WINDOWS CAUSE THAT IS WHERE THE SLOW AND THE FEREEZE ARE HAPPENING FROM,,, SEE YA
Mar 06, 2014 | Facebook Social Network
Why do i continue to lose my connection to the server when playing a game?
LAN Connection Issues and Port Settings LAN-based matches between players on your internal home network are not routed through the Internet or Battle.net servers. Disconnections from LAN matches are attributed to faulty internal wiring or router settings. Log in to your router's administration page via a Web browser and ensure ports 6112 through 6119 TCP are open for traffic flow. If this does not work, check your network wiring and ensure it's properly seated in the computer's and router's Ethernet ports. Corrupt Server List and Virus Attack If you have recently downloaded any maps or connected to privately hosted servers, it's possible you picked up a virus that altered your server file list and is directly causing connection issues. Scan your computer for viruses, using an updated virus definition database. b> Multiple IP Connections b> If you and a friend share a single license or key, disconnects occur if you attempt logging in while the other is playing or vice versa. Key sharing is against the Terms of Use and can lead to an IP ban or restriction. Ensure no one else has access to your CD key or tries to access the game while you are playing to avoid multiple IP disconnects. b> High Latency Disconnects Internet connections with latency over 500 ms can cause disconnects while playing in heavily populated online matches. Alleviate this issue by closing all connection-intensive programs running on your computer. Reconnect to the .net servers with only running on your computer. If you continue experiencing disconnects, visit Speedtest.net and determine whether your latency is above 500 ms. If so, contact your Internet provider for further troubleshooting. Internet crashing b> If your Internet Explorer keeps randomly crashing (closing by itself), there may be an add-on or temporary page disrupting the connection. Every time you browse the web, Internet Explorer keeps track of the websites you visit. It keeps these pages, along with cookie trackers, in the "Temporary Browsing History" folder. Some websites cause Internet Explorer to crash.
Open the Internet Explorer browser. Go to "Tools > Delete Browsing History." Hit "Delete All." Check off the box that says "Also delete files and settings stored by add-ons." Hit "OK." Close and reopen the browser. b> Disable Add-Ons b> Go to "Start > Search." Type "Internet Explorer" and hit "Enter." The computer will search for any files with this label. Double-click on the file that says "Internet Explorer (No Add-Ons)." This will allow you to browse in IE without any additional plug-ins or add-ons that might be causing the browser to crash. b> Reset Internet Explorer b> Open the IE browser. Go to "Tools > Internet Options." Hit "Advanced." Click on "Reset" and then hit "Enter." Close and reopen the browser. Hope this helps. b>
Dec 12, 2012 | Computers & Internet
The keyboard doesnt work properly. when i type it moves around the screen and randomly closes things down
it seems that any key is stuck in the key board, if you can open it & clean the membrain it may fix the problem or you can replace the key board.
Sep 26, 2011 | ASUS Eee PC 904HD
My Emerson MS3108 door keeps randomly opening. All CD music stops when it opens and it opens within seconds of the previous openings. Is there something I can do?
It is a leaf switch that senses that the door is closed. A C-clamp in the upper left hand corner clamping the door closed will make it work. If you remove the clamp, it will randomly open again. The correct fix is to open up the unit and bend the leaf switch to make it activate earlier and fully close when the door is closed.
Nov 14, 2009 | Emerson MS3108 Shelf System
My friend has a 1994 Nissan Infiniti that's alarm goes off when he opens the door with his key. The darn thing seems to sound randomly when he uses his key to open the locked door, and to shut the alarm...
I have the same Infiniity and it has a similar problem. On my car the alarm can be shut off by turning the lock on the drivers door with the ignition key. Works every time.
Jun 25, 2009 | 1994 Nissan Altima
Random based logarithms
to do logarithms with other bases, use change-of-base. let's say you want to do log base 5 of 25. for clarity i'll write this as log(5) 25. you would have to do log(10) 25 / log(10) 5 to get 2. key sequence: [LOG], 2, 5, ), / (divide), [LOG], 5, )
Apr 03, 2009 | Texas Instruments TI-83 Plus Calculator
Please explain the working of this code
It's a Java http server (webserver) that serves random "prices" if they match a search string.
Well here is an explaination:
private static String[] symbols = {"DELL", "INTC", "MSFT", "ORCL", "SUNW"};
These are search strings
private static Random rnd = new Random();
This generates a random number
private static Charset cs = Charset.forName("UTF-8");
This is the charset that the http server uses
ServerSocketChannel server = ServerSocketChannel.open();
Create a new server
server.socket().bind(new InetSocketAddress(8055));
Bind the http server to port 8055
The rest is handling the request and processing it
But here:
if(Arrays.binarySearch(symbols, symbol) >= 0)
response = "Price is " + (1000 + rnd.nextInt(9000)) / 100.0;
else
response = "Price not available";
channel.write(cs.encode("HTTP/1.0 200 OK "));
channel.write(cs.encode("Content-type: text/plain "));
channel.write(cs.encode(response));
channel.close();
It sees if the string input matchs: DELL INTC MSFT ORCL SUNW.
(private static String[] symbols = {"DELL", "INTC", "MSFT", "ORCL", "SUNW"};)
If so, it gives a price based on a random number.
response = "Price is " + (1000 + rnd.nextInt(9000)) / 100.0;)
Or else
It says "price not available"
then it gives a html header to end the error message.
Hope I helped you :)
Gook luck
Nov 26, 2008 | Computers & Internet
Motorola Mobility RAZR2 v9 Cell Phone Logo
43 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
Richard Lane
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
