Question about Alpine PMD-B100 GPS Receiver
PMD-B100 turns-on, cycle thru all menus. However, the unit continue to attempt to locate GPS satellites. I attempted reset, different antenna angles, but no signal found after driving around town. Any ideas?
Mi pmd-b100 i trun on and no menu no map
Posted on Mar 16, 2010
Will not fire up a gps signal
Most GPS systems require a first time boot-up where they scan all registered satellites to determine where in the world they are and what satellites to concentrate their navigational efforts on. Try charging the GPS up entirely, and then doing a hard reset of the system (either by navigating to the hard reset in software or by pressing the tiny reset button usually located on GPS units), and then taking the system out under the open sky and letting it run for half an hour or so, making sure it is running in navigation mode (as opposed to setup or media mode). Once it locks properly onto a small subset of satellites, it should not have much difficulty.
If you continue having problems, check to be certain you are running the latest software on the device which can make a big difference. The latest software for the 520 is here:
http://www.navman.com/Navman/Templates/standardcontent____4407.aspx
Good luck...
Nov 21, 2007 | Fujitsu Siemens Pocket Loox N520 Pocket PC
I have lost my maps on my Alpine Blackbird PMD-B100 how can I get them back?
I am guessing you did not back them up on your computer.
You need to install the software that came with it on your PC,
assuming you have on, and connect the GPS. Follow the on screen instructions. You may have to purchace new maps.
Tip Backup to your pc this time :)
Good luck
Aug 21, 2009 | Alpine PMD-B100 GPS Receiver
Magellan roadmap 760
The Magellan 760 has been around for a few years now, and unfortunately, isn't one of the fastest units around when it comes to synchronizing to a satellite. I find with mine that the time it takes to lock onto a signal depends on several factors:
1) Having the GPS mounted in a way that allows the antenna to have a clear view upward 2) Having my vehicle in the open, so that the signal isn't impaired by adjacent buildings, overhanging trees, etc. 3) Being stationary while the GPS attempts to get a lock. It has more problems locking while moving. 4) Ensuring that the GPS is used frequently, as it loses its memory of what satellites it's synchronized with if you happen to be in a different place when you turn it on than the place you were at when you last turned it off.
Those last two points have the most affect on my GPS's performance. I find that by turning on the GPS and just parking in my driveway or parking lot for a few minutes will allow the GPS to acquire a signal in a much shorter time than if I start to drive immediately. While this will waste a bit of time on the front end, it does help you get synchronized more quickly
May 27, 2009 | Magellan Roadmate 760 GPS Receiver
Ique 3600 antenna reception problem
How long does it try to find the satellites? If it trys for a half hour of more with no results, the antenna may be broken. I have read in other forms that people have added an external antenna and their units would then work, evfen with the built in antenna broken.
Feb 25, 2009 | Garmin iQue 3600 GPS Receiver
My Pmd-b100 does not turn on with the power button?
It is working now and I really don't know what happend. I had left the battery out for a while, then put it back in and it worked.
Dec 19, 2008 | Alpine PMD-B100 GPS Receiver
Garmin Nuvi GPS won't acquire satellites
There is a known hardware bug in the Garmin 600 series relating to the detection of the connection of an external antenna. The GPS is supposed to do this automatically and when it detects an external antenna plugged in it switches out the internal antenna. Unfortunately, this circuitry doesn't work correctly in some versions of the unit and sometimes it get's comfused and thinks there is an external antenna connected when there is not. This causes the behavior you describe because, for all practical purposes, there is no antenna connected.
Garmin can fix this and they've been known to fix it even on units that are out of warranty. There is a fix that can be done by someone with the right equipment and know-how which requires disassembling the unit and bypassing the antenna switch. Not to be attempted by anyone not experienced in micro surface mount PCB re-work.
Wingflinger
Dec 04, 2008 | Garmin Nuvi 660 GPS Receiver
MAGELLAN 310 NOT TRACKING
Turn on the power while holding the right arrow. This resets the unit. You will then have to reset the time, date, and location.
Jan 22, 2008 | Magellan GPS 310 GPS Receiver
Alpine PMD-B100 GPS Receiver Logo
284 people viewed this question
Top Alpine GPS Experts
Shehu Pro
Shehu Pro
richie46
Are you an Alpine GPS Expert? Answer questions, earn points and help others
