Question about Dell 926 All-In-One InkJet Printer
Added new dellink supply but now printer will not turn on ?
Added new dellink supply but now printer will not turn on?
Canon mf 4150 printer the printer acts like it will work when turned on, yet the data processing lites remain on and lcd screen is blank computer does not recognize printer it will not even copy
I'm not sure about this brand of printer but from past experience from other brands, something is wrong in the setup of the printer or it's not compatible with your computer. I would first unplug the printer, re install the printer software, make sure you have all updates of your printer, you can go to manufacturer website to check. Then hook up the printer and start by adding a new printer. Make sure you don't have the printer still in your computer from before. Hope this helps.
Aug 13, 2017 | Canon Office Equipment & Supplies
How to replace an Epson R2400 power supply?
Replace adapter cable only, do not replace the power supply by your own ! tTake it to the nearest vendor representatives
Apr 22, 2014 | Epson Stylus Photo R2400 InkJet Printer
Computer wont boot up,
what computer? when you say added new power supply what state was the computer in before you added power supply ? do you know the new supply is a good one ?
S
Jan 24, 2012 | Shuttle Computers & Internet
I purchased a new computer having WINDOWS 7 as operating system. I am having printer HP Officejet 4355 All-in-One and CD drive supplied for this is not compatible to WINDOWS 7 OS. What to do?
I think this printer don't have the cd software available for Windows 7, 32 or 64 bits. But you can use it with the plug & play feature of Windows. Just turn the printer on and plug the USB cable (try cables of less than 6ft and a port in the back of the PC, also avoid the use of any USB HUB). Windows will automatically recognize the printer and install an embedded driver. You will see in the control panel under printer and devices if the unit was successfully added
Sep 07, 2010 | HP Officejet 4355 All-In-One InkJet...
Xerox Phaser 7750 Imaging Unit Percentage Question?
turn macine off wait 5 min repower and run recheck
Apr 06, 2009 | Xerox Phaser 7750GX Laser Printer
Computer slow since adding hp 7280
turn of printer when it not in use , to make ur pc fast download reginout intel partner to make it fast to some extent
Mar 03, 2009 | HP OfficeJet 6110 All-In-One InkJet...
No cartridge on screen after adding new cartridge
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Dec 30, 2008 | Brother MFC-440CN InkJet Printer
Flashing green light
Could be a power Supply fail. It is well known in the trade that Emachine power supplies are very poor. A new power supply is easy to fit and cheap.
Aug 27, 2007 | E-Machines T3265 PC Desktop
Add toner message
have you tried another toner cartridge? eyo7 eyoifiok2005@yahoo.com
Mar 30, 2007 | Savin 9935DP Laser Printer
Dell 926 All-In-One InkJet Printer Logo
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
