Question about DISH Network IR Remote Control
Remote works at time, and does not work after dark
  • 2 more comments
  • Rajiv Arora Sep 11, 2009
    I have a Dish Network DVR Model 501. The remote control works during the day, meaning I can use it to switch channels, when it is bright outside (during the day), but the remote does not work after dark. The rooom is brightly lit with 2 lamps, during the remote control will not switch channels (up or down). I have replaced batteries on the remote, cleaned both the IR sensor on the Dish Network receiver, and the remote.
    Does that clarify the problem? Thanks in advance
  • Kenneth Klare
    Kenneth Klare May 11, 2010
    Do you have a fluorescent light or other novelty light on in the room? Your TV may be sensitive to its light, although I would expect more UV and TV uses IR. Try turning out lights or shielding the path, remote to TV sensor, with a tube to test this.
    -Ken
  • try to clarify your problem. it doesn't work at night?
    Novelist:
  • 123 Answers
It would be our pleasure in assisting you with this. The first thing we want to check is if the issue isaffecting multiple buttons on the remote. If you are having the issue withspecific buttons then the remote needs to be replaced, give us a call at1-800-333-DISH (3474). If you are having the issue with more than one button checkif you are using the correct remote for the correct room, there may be a numberon the bottom of the remote that tells you which room the remote should be in. Atthis point we want to re-address your remote, if issue is with the TV2 remote.Access "System Info" at TV1, then using the remote that is NOT functioning, press and releasethe "SAT" button then press and release the RECORD buttonon remote control, this should re-address the remote. If the batteries in theremote have not been replaced in the past 60 days, replace the batteries. Resetthe receiver by unplugging it for 10 seconds then plug it back in thenre-address the remote again. If the remote is still not working at this pointthen it may be an interference issue. Find interference source (back lighting orpower save mode on LCD TV's, fluorescent lighting in room, or direct sunlight),eliminate. If the remote is still not working after all these steps we need tohave your remote replaced, give us a call at the number mentioned above.
We really hope all these steps resolve your remote issue. Thank you for being avalued DISH Network customer!
Phillip Chang
DISH Network Customer Service Representative
Posted on Feb 25, 2011
Hello, I changed the ribbon. The ribbon and labels
can you adjust the printhead pressure?? if so then do that
Aug 22, 2017 | Zebra ZM400 Thermal Label Printer -...
Dish Network controller doesn't work if you happen to pause or stop when the screen is black or on a dark picture. You have to turn TV and control box off then back on to regain controller.
falcondan
The remote works fine other than this stated problem? What type receiver and TV do you have? Do this just began occurring? Have you checked the batteries to make sure they are fresh? Is this on TV 1 or TV 2? One thing you may try is readdressing the remote to the receiver.
Remote: All Other Remotes
  1. Go to System Info screen (press Menu button 2 times on remote).
  2. Hold down the SAT button until all mode lights light up.
  3. Enter a number between 1 and 15 using the numeric keypad on the remote.
  4. Press the pound (#) button.
  5. Once the SAT button blinks three times, press record. Note: If successful, the number selected in step 3 will appear in the System Info screen under Remote Address.
Jun 25, 2011 | DISH Network IR Remote Control
Remote code for Seiki TV 32"
The "try the Samsung codes" suggestions works. I have a ONN (Seiki) LE-24G90. The first Samsung code on the HDTV list (1019) did the trick on my Telus CISCO ST6400 remote.
Dec 01, 2010 | Televison & Video
MY REMOTE CONTROL DOES NOT WORK AFTER DARK
bdale
You may have IR interference at night because of other items you turn on at night. Try leaving everything off except your TV and receive, try your remote to make sure it functions. Then turn 1 item on at a time, try the remote to see if it works or stops working. Once it stops working, the last item you turned on is causing the interference. It is then a matter of relocating that item so it won't continue to interfere with the remote functions. I hope this helps.
Ray Calo
DISH Network
Nov 22, 2010 | DISH Network IR Remote Control
Comcast remote does not work after dark, works just find in day
I have had the same problem I have two bell receivers one in the bedroom and one in the living room, in low light the remote in the living room would work much like yours, but if I took the same remote into the bedroom it worked fine in low light, the second remote responded exactly the same, the problem in my situation was the TV had a light sensor that adjusts the picture depending on the light in the room, with this option turned off. The remote works just fine in low light situation.
Oct 20, 2009 | DISH Network IR Remote Control
Remote key will not open or close to car
ok, stab in the dark. turn off your radioand disconnect you battery negative for five minutes, then reconnect.didn't work, ok. Turn your ignition awitch on and of 3 times... Hopefully these two methods of reset for ecu worked. Good Luck, Ned
Sep 16, 2009 | 1999 Audi A4
Sylvania LC320SLX - No Comcast Code
IF YOU HAVE THE DARK GREY REMOTE FROM COMCAST, IT WILL NOT WORK. SWITCH YOUR DARK GREY REMOTE FOR A LIGHT GREY REMOTE AT COMCAST OFFICE.
Jul 28, 2009 | Sylvania LC320SS8 32 in. LCD Television
None of the buttons on the remote will work!!! dmr ex95v
Try unplugging the dvd player for 30 seconds. Try to turn unit on a couple of times without power (discharges capacitors). Plug it back up and see if that works. It's a shot in the dark, but worth trying.
Is the remote the original remote for the unit? Could try reprogramming for dvd player if it's a universal remote.
Apr 06, 2009 | Panasonic Televison & Video
Bose 321 remote control not working
You can test a remote control using these methods:-
Method 1 - If you have AM, Medium Wave radio then set the tuning off a channel and press the remote control buttons. If there is a change in sound, higher and/or lower tones the remote is working.
If not check the batteries are charged and fitted correctly.
Method 2 - If you have a digital camera with nightshot, wait until it's dark turn off the lights and turn the camera to nightshot. Aim it at the remote in the dark and focus then press the butoons. Look at the led light is there any change/flashing on the end of the led.
This will confirm it is the remote control and a replacement is required, or batteries need changing
Jan 17, 2009 | Bose RC-18S Remote Control
Remote control sensor doesn't work when the room is dark.
its probably the led in the remoter, check with a camera on a phone point the camera at the remote if its dim, that's the problem, it could also be a damaged battery in the remote.
Jun 18, 2017 | Televison & Video
DISH Network IR Remote Control Logo
443 people viewed this question
Top DISH Network Televison & Video Experts
S. Gontko
john milligan
Jaime Hernandez
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
