Question about Garden
Wont stay running - Garden
  • dontbother10
    dontbother10 May 11, 2010
    What make, model, and serial number does this apply to?
    Brigadier General:
  • 4,088 Answers
Probable loss of fuel--check the fuel lines from inside the tank to the carburetor. If the saw is fairly old, the carburetor is likely due for a re-kit and cleaning. Make sure the air cleaner is clean and in good condition. Check for plugging in the muffler. Check the spark plug condition.
Posted on Sep 12, 2009
  • djino35 Sep 19, 2010
    new fuel lines, air cleaner clean and good condition, new spark plug. will check muffler. tks
  • drallim Sep 19, 2010
    Check the fuel filter for plugging. If it is dying at idle, set the idle speed screw CW somewhat to keep it going. If the chain is beginning to turn at idle, then turn the L jet needle CCW somewhat instead to make the idle fuel mixture a little richer. Make sure you have fresh fuel mix in the tank. Check for blue snappy spark at the plug (gapped at 0.020"). If weak, remove the left case cover to expose the flywheel and ignition module. Use a thin business card for a gap gauge, and turn the the flywheel magnets just under the module poles. Insert the card into the gap, loosen the module screws, and allow the module to contact the magnets. Tighten the screws and rotate the flywheel somewhat to remove the card. Turn the flywheel one full turn to make sure the gap closes no further. Reassemble and recheck for spark. Hope this helps!
My 1999 audi car i start it and it and it wont stay running it konks out
Vacuum or incorrect air fuel ratio .also if you moved the butterfly inside the throttle body you will need a throttle position sensor .
Sep 27, 2014 | Cars & Trucks
Why wont truck stay running.
Check the alternator! It may be bad!
May 15, 2014 | 2005 Ford F-150 SuperCab
2000 chevy monte carlo when trying to crank it won't stay. the alternator has been checked, the starter, and battery, please help.
Wont stay?? cranking or running? Assuming it cranks but wont stay running I would be suspect of a Crankshaft Position Sensor
Feb 13, 2014 | Chevrolet Monte Carlo Cars & Trucks
5.3 wont stay running
Check your security light on the dash and see if it stays on or blinks with the key in on position. If so google how to reset the security.
Dec 02, 2013 | 1999 Chevrolet Tahoe
The car wont stay running when in the run possion
OK lets start with this..
I am guessing that when you say possion you are meaning you gear selector and when you put it in say drive.
If that is the case.....
Your problem is most likely the fuel pump relay or fuel pump itself.
Start with checking, or have it checked, the fuel pressure at the fuel rail.
If the pressure is low then a fuel pump can be suspect. There are then other test which have to be performed to see where the exact problem is.
Sep 16, 2009 | 1986 Ford Tempo
Why wont jeep stay running without giveing it gas
throttle is set low, or you may have a fuel pump going out.
Aug 24, 2009 | 2001 Jeep Grand Cherokee
I have a 1988 GMC Sierra 1500 thast wont stay running
Use a gage and check proper fuel pressure. With tbi fuel injection, the fuel pressure is 9--13 psi. I have seen fuel injector spray pattern that looked good to me, but, the fuel pressure was half of what it should have been. 5 psi may show a good spray pattern, but, it won't start and run a v8. In my opinion.
Any applicable trouble codes? Your obd1, you should be able to check some codes yourself, if there are any.
Apr 21, 2017 | 1988 GMC C1500
Wont stay running
check your tps it may have gone bad. had that happen to a friend changed out the tps and when he cranked it it stayed on hope this help u out let me know
Jun 28, 2008 | 2001 Kia Sephia
Garden Logo
71 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
