Question about Crown XTi 2000 2-Channel Amplifier
I have my amplifier connected to my dj system only one speaker of the bass works wich is channel 1 channel 2 does not work and fault button keeps on blinking red?
    Problem Solver:
  • 10 Answers
The XTI 2k has lots of DSP options built into the front panel. If it's your intent to run the amp in bridge mono for subs be sure than you have all settings set correct for the DSP, it's very possible that channel 2 will render in-active.
This also applies in the case if you wanted to run your subs in stereo and the internal settings are set for bridged mono.
Another possibility would be if the DSP was set with a crossover. If you put a cross-over point (Low Pass Filter) on the high side of the sub, if becomes the High Pass Filter of Channel 2. Audio would pass if there was no other filter sets, but would not if you were using a crossover and then hitting the subs.
Posted on Sep 24, 2009
Have a xga 4000 amp only channel 2 works fine . Channel 1 very very low
Switch input connection pairs and if the 'fault' doesn't changes from one channel to the other it is almost certainly an amplifier or output fault.
Likewise switching the speakers. If after swapping the speaker connections the fault changes to the other speaker it is an amplifier fault. If not a speaker fault.
Aug 16, 2014 | Gemini Sound Products GEMINI XGA 4000 4000...
I just got one what is it an how does it work an how do i hook it up?
2 channel power amp
you will need additional equipment for this beast to work right.
1. you need a pre-amp, all audio connections go into the preamp which control sorces, volm, bass and treble.
2. out from the preamp into the power amp and out to your speakers
3. you can freak it if you have an 1/8" stereo to RCA stereo plug in this caee you can play your ipod, phone or mp3 player thru this amp using your input device (ipod, phone or mp3 player ) like a preamp to control volm, bass and treble.
Feb 21, 2011 | Sharp SX9860 2-Channel Amplifier
Unable to receive optimum output. The bass is totally flat !
Hi, ok the Bose Acoustimass III system consists of two small cube speakers and one subwoofer unit called the Acoustimass bass module. If the subwoofer stops working, three points can be the cause of the failure. The Bose Acoustimass III is a passive system, meaning the speakers do not power themselves, but instead are connected to a receiver or amplifier. Thus, the amplifier, the speaker between the amplifier and the subwoofer, or the subwoofer itself could be the issue.
Things You'll Need:
* Amplifier
* Speaker cable
* Extra subwoofer
Instructions
Disconnect the speaker cable from the back of the Bose Accoustimass bass module and connect it to a subwoofer that is known to be working. If the subwoofer works, the bass module needs to be replaced.
Disconnect the speaker cable from the back of the receiver or amplifier you are using and from the back of the subwoofer in Step 1.
Connect a speaker cable that is known to be working between the back of the receiver or amplifier and the back of the Accoustimass module. If the module starts working, then the cable was the issue.
Disconnect the speaker cable from Step 3 from the back of the amplifier or receiver, then connect the cable to the subwoofer port on the back of an amplifier or receiver that is known to be working. If the subwoofer works, the receiver was the issue. If the subwoofer still does not work, verify that the speaker cable is in the subwoofer port of the receiver/amplifier and that the cable is connected securely to the subwoofer.
If you think you did the connection properly,Fine... If not you can use the manual from the below link and know how to connect it properly..
products.bose.com/pdf/customer_service/owners/og_am5iii.pdf
Have a nice day..
Feb 19, 2011 | Bose Acoustimass 5 III System
System keeps cutting out and resetting
It is possible that you will need to check on your power lines and the output speaker connecction/ speakers/ If all these are fine, then you will neeed to check for loose, dry connections within the amplifier. Try to solder off suspected joints and check. If not check the amplifier when it had cut off. Confirm if the fault is a failure or absence of the power to the circuits. if so trace from the power section to find. If not it could be a protection acting in forcing a cut offf. In such case you will have to trace for load tripping of the circuit. reduce volume and Bass and test. try and tighten all leads, connectors and points. Helpful? Good day
Jul 17, 2010 | Bose Lifestyle SA-2 2-Channel Amplifier
CROWN CE1000- slips into fault immediately after connection
if ur output power amp is defective u will have that problem - meaning the moment u connect load across it it will go into circuit protection to limit/stop excessive output current. make sure the speaker terminals are connected to +/- output terminals. in bridge mode use only channel 1 and that too with 4 ohms speaker only otherwise amp will clip. considering all connections are okay if it still clips when speaker is connected, u have a faulty power amp section. this the way ur amp is designed
Apr 05, 2010 | Crown CE1000 2-Channel Amplifier
I HAVE A 1994 BUICK GRAND SPORT. I WANT TO HOOK A STERIO UP BUT THE STERIO THAT CAME WITH THE BUICK HAS A DOUBLE COMMPONET SET UP . HOW DO I BYPASS THAT AND HOOK UP THE CD PLAYER TO THE SPEAKERS?
1) Understand the basics of all car stereo systems. A car stereo system consists of 4 main components and the wiring that connects them. These are the head unit, the main speakers, optional amplifiers and the subwoofers, which are also optional but generally considered a necessary part of any good system. 2) Know that the core of any car stereo is the head unit, which is the cassette or CD player that goes in the dash. All the other components are connected to the head unit by at least one pair of wires. 3) Know about car speakers. The main speakers are usually 2 in the front and 2 in the back, although with what are known as component speakers, each speaker is broken down into two speakers: one for the highs and one for the bass. Each speaker or speaker set (known as a channel) connects to the head unit via a pair of wires. Generally if you are installing a new head unit you want to install new speakers. 4) Know about amplifiers. Amplifiers provide extra power to your speakers and/or extra channels of power for additional speakers. The most common use for an amplifier (amp) is to power subwoofers. The amp connects to your head unit via an RCA cable and often a "remote on" wire, and also connects directly to your car battery through a fused "hot" wire and to the car's chassis with a short ground wire. This article assumes the use of a single amplifier connected to a pair of subwoofers. If you do not have these components simply ignore the steps specific to the amp, doing so will not affect the rest of your installation. 5) Know about subwoofers. Subwoofers are part of any good stereo system. They provide the deep bass that small speakers cannot achieve. Subwoofers are connected to the amplifier which can usually be mounted right to the subwoofer box. If you do not have subwoofers you can simply ignore the steps specific to them. FOR more help click on this link directly http://www.ehow.com/how_5829_wire-car-stereo.html ------ This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Jan 25, 2010 | Car Audio & Video
I want to run an additional amplifier from my 5.1 surround system amp speaker output to drive large dj speakers. The dj speakers need 175 rms and my 5.1 only has 100 rms per channel. Can I just wire from...
Speaker output from the amplifier is a higher voltage than a preout. The speaker level signal has to be reduced to a line level signal in order to connect to another amplifier. I used a car stereo "speaker to line level adapter" and then connected a second amp to run my front channel speakers. Works just fine.
Dec 15, 2009 | Sony STR-DG500 System
Ok this problem is killing me...
maybe the speaker is bad
First try one thing, switch the rca jacks around and see if the other speaker stops working this time.
If so the problem is in the rca jack or head unit.
If the same speaker is still not working, the problem will be the speaker, you will have no other options left since you changed amplifiers and checked all wiring.
Let me know if this helps you
Jun 18, 2008 | Visonik Dual Bass Box with Amplifier Car...
Connecting 4 bass speakers to one amp?
If you have a 4 channel amp and 4 speakers and each speaker is connected to each of the 4 channels you are just fine.
A stereo amplifier has 2 channels, typically labeled left and right and each channel has an amplifier. A 4 channel amplifier has 4 amplifiers. With one speaker on each channel, there is one speaker on each amplifier. Audio amps are referred to as amps or amplifiers, although if they have more than one channel it would be more correct to call them something like 'multi-channel amplifier' or 'multi amplifier speaker driver'. Semantics.
May 25, 2008 | Tomtom GO 700 GPS NAVIGATION BRAND ONLY...
I'm have'n a problem
You should be connecting this product to a dj mixer because this unit has no internal mixer.To accomplish this you should connect the two outputs lines for channel 1 from this cd player to the two input lines on channel 1 of your mixer and the same for channel two, connect channel two from your cd player to the channel two input on your mixer and then hook your mixer to a amplifier, then amplifier to speakers. D.J Fire in Louisiana***
Oct 15, 2007 | American Audio DCD-PRO310
Crown XTi 2000 2-Channel Amplifier Logo
176 people viewed this question
Top Crown Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Crown Audio Player and Recorder Expert? Answer questions, earn points and help others
