Question about Copystar CS-1500 Copier
I am getting an error code on my CS-1500 that says C-6 then 020. Unplugging and restarting do no good. Any idea what's wrong? Tom
  • 143 Answers
That is a HIGH temperature detect error code.
Check the thermistor, if you measure 0 ohm resistance in the thermistor, replace it.
Press the stop/clear key, start key
and the left copy exposure adjustment
key in the order presented and hold
them down.
Press the stop/clear key.
Enter the number of the maintenance
item to be executed using the copy
exposure adjustment keys or the zoom
+/- keys.
Go to U163 and hit the Start Key, this will reset the trouble code.
Posted on Sep 11, 2009
Sharp Model MXB401 Error L4-16 what is it and how do i fix it
Hello Joanne,
The error that you are receiving is due to worn gears going to the fuser assembly that need to be replaced!
The repair thread can be read at either link below:
Thread MX B401 L4 16 error
sharp mfp mx b401 error code c4 16
Good Luck!
Rich Lilja
Feb 24, 2015 | Sharp Office Equipment & Supplies
Hotpoint aquarius washing machine wf nstopped in middle of programme error message won't restart
First try unplugging the machine.
Then try emptying the machine, unplugging and running a small load.
Sep 03, 2008 | Hotpoint Washing Machines
Air conditioner restart.
check for any short circuit connections in the power input section
this can cause the unit to restart
Aug 03, 2008 | Sharp Heating & Cooling
Unable to connect to Netflix
What device are you using to connect to Netflix?
Error code NW-4-7 usually indicates a problem with your internet connection. Restarting the device and/or your router would be a good idea.
Cheers,
Tom
Aug 28, 2014 | Netflix
Error code c410 on cs-2218
If a C410 Error occurs, replace the DP-410 Main PCB Assembly, Ground Wire and Screw.
The PCBs part number is 303HL01018.
Apr 01, 2013 | Copystar Cs-2218/cs-2221/cs-2225 Developer...
Reset electrolux c 8 error
Hello cjsmith12345 - Are you certain the error code is C8? However, if you are receiving an error code E08 it typically indicates a shorted keypad, or a faulty User Interface Board. Depending on the model, these components may be the same. To reset, turn the power off to the unit for two minutes. This may be done by either unplugging it or flipping the household circuit breaker off and then restart unit. If error reoccurs, I would strongly recommend contacting a professional to make the necessary repairs. Unfortunately, most electronic parts cannot be returned so it is always a good idea to get the appropriate diagnosis prior to making any unnecessary part replacements.
Mar 04, 2013 | Electrolux Frigidaire Professional Series...
"error occured,call service person
Try unplugging it for 10 minutes. While unplugged, press and hold the start and stop but for 10 seconds. Double check for any paper jams. Just the smallest piece can jam it up. There should be a list of error codes for anything wrong. List paper jam would have an error code, change toner, change or clean ink, ect. Is this the only message you get? If that's so, try the steps I mentioned above so the machine resets itself. It the problem still occurs, let me know I will gladly help you to correct this problem.
Jan 27, 2011 | Kyocera Copystar CS-1820 Black and White...
Canon np1010 fuser assembly repair help I got an E 0 error code. Machine won't start. What is wrong? And where do I get replacement parts. Thank you all in advance. Tom
Hi Tom, The error code means that you have a problem with the fuser unit. It means the fuser is not warming up correctly. I would say that you need a new fuser lamp.. It most likely looks like a candy cane. You canfind it on the web. But, that is a very, very,very old copier. I was factory trained on it 20 years ago. It may not be worth repairing. It takes alot of work & taking the copier half apart & hope you get it back togather right... Good Luck
Feb 06, 2010 | Office Equipment & Supplies
Whirlpool Duet Front loader mdl WFW8300SW00 will not start
I had a variety of error codes show up on my duet, and I'm not sure but I seem to recall a 31, but the most constant was 02. I took off the front cover, pulled the white plug out from the unit, put a bucket under it, unscrewed it and drained it. It may be the MCU is having problems because the washer got plugged up.
Apr 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Copystar CS-1500 Copier Logo
123 people viewed this question
Top Copystar Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Tammie Duggan
Tammie Duggan
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
