Question about Westinghouse Dryers
My Westinghouse 77874 remote fan controller stopped working for the light or fan. I cannot find the manual & was wondering if there was a reset function or coding procedure I could try or does someone have a manual. Here is a picture of controller: http://www.lightingdirect.com/westinghouse-77874-fan-control/p101948
SOURCE: remote control code for westinghouse sk-19h210s television
I just tried a Sony code for my Westinghouse tv after reading other sites, and it worked. The code that worked for me was 10000
Posted on May 05, 2008
picatudo
  • 239 Answers
SOURCE: fan and remote not working
make sure the main switch is on ,also the chain switch on ,before using control remote!!
Posted on Jan 04, 2009
  • 33 Answers
SOURCE: Control panel dead
1. Unplug dryer.
2. Remove 2 screws from rear top of dryer.
3. Lift panel assembly up, taking care to not pull wires.
4. Check plugs on circuit board for panel display. Press each one firmly, but carefully.
5. Put back together, plug in, turn on.
Posted on Jul 28, 2009
SOURCE: Light remote control stopped working
First, make sure there are good batteries in the remote.
If light still doesn't work, I would suspect the receiver in the fan ceiling box.
The receiver can be tested with a multi-meter, but if you're not experienced with electrical troubleshooting, it's probably best just to replace the remote system, both receiver & transmitter.
Charlie
Posted on Aug 21, 2009
  • 56 Answers
SOURCE: Fridge compartment of westinghouse bj433v-r is not
The freezer control on most units is just a door that you open or close to let more or less air into refirig from freezer. The higher the setting, the less air to the frig side.
If frost build-up on freezer side, then you have a defrost problem. Too much frost build-up on evaporator is blocking air flow to refrig.
Posted on Nov 05, 2009
Where to order remote control for my ceiling fan no.uc7130t
from the service dealer / authorized service agent for your brand of fan
Oct 25, 2015 | Westinghouse Televison & Video
Why did the remote suddenly stop working?
Try disconnecting power at the source, not a switch. Wait for a minute or so and turn on the power again. This action may "reset" the receiver. You also may find that remote control is restored after a power outage. Finally, if nothing else works, you may have to install a replacement Lutron receiver.
Aug 16, 2015 | Lutron Electronics MIR-ITFS-LF-WH...
Light button stopped working
Hello Becky,
I Have a lot of questions and it may be easier to call me. Don't worry I won't try to sell you anything!! My name is Jack Jr and I am a ceiling fan tech and troubleshoot / work on fans all day. I can be reached toll-free at Fan Man Lighting (1-866-600-3267). Some things I will ask you though is does the little indicator light on the transmitter come on when you press the light button? I would start by switching off the transmitter (the slide switch you mention), tugging the light pull chain, restoring power (with the slide switch) and then trying the light again. If this does not work I would like to know approximately how old is the fan? How many dipswitches does your wireless system use?. Where is the Receiver located in the fan? Don't worry, I can walk you through each of these questions and make educated guesses if you do not know. Also I will have some trouble shooting tips. Stay warm!
Jan 04, 2014 | Westinghouse Wireless Ceiling Fan and...
Hunter fan works light broken
Check to make sure light wires are connected at light kit & remote. Otherwise it's probably a bad receiver. If there is a pull chain for the light pull it once & try the remote light button again.
Mar 10, 2013 | Hunter Ceiling Fan Light Switch Control
I have a Westinghouse 77870 remote control with a light problem
read your intruc. manual and proceed according. download from www.fitness.manualsonline.com or www. retrevo.com
However you retight the spring contacts with pliers for better contacts batteries. 2) Open the re.control and clean the keypads for dirty, oxide with special spray contacts. 3) If the problem persist go to the repair shop TV for fix it.
God bless you
Jul 06, 2012 | Westinghouse 77870 Remote Control
Casablanca fan stopped working suddenly, both fan & light
You must 'reset' the remote. I've had it happen quite a few times.
1. Turn off power to fan. Then back on.
2. Using remote cycle the following fan buttons from high to med to low, then from low to med to high again. That 'should' fix the problem.
Sep 29, 2009 | Casablanca Fan Versa Touch2 W-72 Remote...
most of my fan controls have done this to me. you know the reciever is working cuz the fan works fine. you need to dis assemble the remote completely and clean the contacts for the light button. mine are two small black dots that seem to keep getting slimey and wont work till i clean them, then all works like brand new again.
good luck.
Aug 21, 2009 | Hunter 52" Ceiling Fan With Light And...
Put remote on hampton bay ceiling fan and the led light keeps blinking when turned off
I am looking for the White Westinghouse sk26h240s remote codes for a Comcast universal DVR Remote control. any ideas, please email me at renee.walton@comcast.net.
May 29, 2008 | Universal Remote Control Hampton Bay...
Westinghouse universal ceiling fan & light remote control #77870
make sure that you have the power cord on the fan in the right position. Pull it once to see if that starts the motor. Then go back to your remote and try starting the fan from the remote.
Oct 20, 2007 | Westinghouse 16093 Remote Control
Dryers Logo
196 people viewed this question
Top Westinghouse Dryers Experts
Pranavendra Pranav
Pranavendra Pranav
Level 1 Expert
Paul Bade
john h
Are you a Westinghouse Dryer Expert? Answer questions, earn points and help others
