Question about Clarke Power Products Mig/Fluxcore 180En 220V
I need to know what size wire and plug to use on my clarke 220 volt welder model 160 en how many amps does it pull? what amp breaker do i need?what size wire do i need? the site will only let me post it as a model 180 en but it is a 160 en ........... 220 v
  • 2 more comments
  • jasonbehrend Sep 15, 2009
    a 60 amp breaker - but what size wire coming from the house to that 60 amp breaker which is going to be located in a sub panel in the garage
    a 60 amp breaker - but what size wire coming from the house to that 60 amp breaker? (which is going to be located in a sub panel in the garage)
  • jasonbehrend Oct 15, 2009
    thats what another guy also said -thanks for the help
  • fougzki May 11, 2010
    Commonly if 60 amps breaker is use a 5.5 sq.mm wire or # 10 AWG on supply side.
I would run a 10 AWG wire from the breaker to the outlet, if that is what you are asking. I have the same welder works great just wish I could find a spare wire roller.
Posted on Oct 14, 2009
    Novelist:
  • 92 Answers
Check out the house wire gauge on this link. http://wiki.xtronics.com/index.php/Wire-Gauge_Ampacity
Posted on Sep 15, 2009
  • 92 Answers
60 amp breaker will do.I use a .35 wire with a matching tip.If you arenot using gas use a wire with flux(intershield) inside.--Good luck!
Posted on Sep 12, 2009
230 volt welder
Breaker must be 50A and the size wire should be a 8/3.
Feb 23, 2014 | Welding Tools
Need a hook up maual
According to the specs for this welder
You need a 50 amp breaker and #6 wire
Century/Lincoln Inverter Arc 230 DC stick welder.
  • 230 Volt stick welder compatible with optional TIG equipment. Welds 18ga to 5/16. Includes:
  • 10 ft Work cable with small dins connector and clamp,
  • 10 ft Electrode holder with small dins connector,
  • shoulder strap for portability,
  • 6-1/2 ft input cable with attached 50 Amp (NEMA 6-50P) plug
Oct 12, 2012 | Century lincoln K27901 Inverter Arc 230...
CLarke 130 en everything works Great except when I select # 4 on the heat then it won't feed when the trigger is pulled?
i put a new motor on the welder an i have 9 to 12 vote coming to the motor but the motor wont run all works but the motor
Mar 14, 2012 | Clarke Power Products Clarke 130EN...
Can not get a spark
Check internal fuses and breakers first. Then see if the contactors are closing. If they are not check the 24 volt contacter for coil continuity. If that is okay, check for voltage at the wire feed motor with an analog meter. Put it in a plstic bag and tape the bag where the test leads come out- there is a big magnet in the movement. Keep the meter in the bag to protect it, but check the motor to see if it is seeing power impulses from the control board. If it is not gettin pulsed power when trigger is pressed, suspect a failure of the SCRs on the control board.
Feb 07, 2012 | Clarke Power Products Clarke 130EN...
Need matco 160 repair manuel
Hi:
Here's Clarke's owners manuals web site, just choose your model and download it.
http://www.clarkeservice.co.uk/product_manuals/mig_welders.shtml
Don't forget to rate me.
Sep 24, 2011 | Clarke Power Products Clarke 130EN...
When the welder is first turned on I can weld with gas for about 5 seconds. Then the breaker trips. ( i have the proper wiring and breaker). The more times I reset the breaker the shorter the weld time...
Hi:
Just make sure that if you are using an extension cable between your machine and the power outlet, this cable is at least a 12 gauge size, if you are using a 14 or 16 it's too small to handle the amps.
Other point is to check that your breaker is 20 or 30 Amp capacity.
Hope this help.
Sep 08, 2011 | Clarke Power Products Clarke 130EN...
Need to know how to get my clark welder to weld aluminum model we6527
Using a Spool gun and an adaptor to your welder is better, but you need to open your wallet and spend at least 600 bucks. The modest way to go is:
1) change the gun liner to a teflon kind one instead of steel.
2) Change your drive rolls for knurled one instead of grooved.
3) oversize your contact tip for more wire feed freedom.
4) use straight argon gas.
5) use aluminum 4043 type 035 size.
And always try to maintain your gun lead as straight as you can.
Good Luck!
Jan 24, 2011 | Clarke Power Products Clarke 130EN...
Everything comes on and the wire feeds. However it
Check that your ground clamp is connected to the work piece securely.
Mar 14, 2010 | Clarke Power Products Clarke 130EN...
Clarke Power Products Mig/Fluxcore 180En 220V Logo
794 people viewed this question
Top Clarke Power Products Welding Tools Experts
Wade Mobley
Wade Mobley
Bill Boyd
Are you a Clarke Power Products Welding Tool Expert? Answer questions, earn points and help others
