I also have a onkyo pl-25f with the arm stuck in position.
If i budge the arm by pushing it to the left a bit, it seems to catch. i think the motor on mine is worn out and cannot get started on its own, but with help, it will slowly move on its own to the edge of the vinyl and drop into playing position
2 Suggested Answers
SOURCE: Operating instructions for Onkyo PL-25F turntable
I have the same problem with mine! If i budge the arm by pushing it to the left a bit, it seems to catch. i think the motor on mine is worn out and cannot get started on its own, but with help, it will slowly move on its own to the edge of the vinyl and drop into playing position. If that doesnt work for you, you might need to clean the belt for the arm motor, or buy a new motor.
Posted on Sep 11, 2009
The Dyson Ball gets stuck on DC25
Hi there, it's Jack at Dyson.
If your DC25's ball seems to get stuck, this is likely to be because the post-motor filter is out of position, and is catching on the inside of the ball shell. This is simple to resolve - the video below shows how to remove and replace the post-motor filter. Push it firmly back down into position until you hear a click from the red catch.
If for any reason you find that the issue reoccurs, the best course of action would be to contact our experts directly so we can help make sure the filter isn't damaged in any way. If it is, we can take some further details to confirm whether a replacement is covered under your Dyson guarantee.
You can reach us by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Feb 16, 2015 | Dyson DC25 Vacuum
How can I manually close the sunroof on my Lincoln MKX?
Put the switch in the first detent for manual open/close
Mar 11, 2013 | Cars & Trucks
Hi. Our 8560MFP has come up with the error code 07,010.43:93096, plus the message "power down error - head not parked" - is this something we could look at ourselves or do we need professional...
7,010.43 Printhead is stuck or is not tilting properly over the cam.
Initial Actions
• Check that the Process Drive gear train is properly homed.
• Check for obstructions or ink spills around the Printhead.
• Verify the Printhead travels smoothly from left to right.
• Check the Printhead Restraint Arms.
• If the problem persists, follow the procedure below.
Table 1 7,010.4x through 7,015.4x Troubleshooting Reference Table
Applicable Parts Wiring and Plug/Jack References
Process Drive, PL 4.0 Right Side Harness / I/O Control, Figure 8
Head Tilt Solenoid, PL 4.0 Left Side Harness (2/2), Figure 5
Head Tilt Gear, PL 4.0
Restraint Arms, PL 2.0
Head Maintenance Clutch, PL 4.0 I/O Board (2/2), Figure 10
Table 2 Printhead Restraint Fault 7,010.xx through 7,015.xx Troubleshooting Procedure
Step Questions or Actions Yes No
1 Reboot the system.Does the error persist? Go to Step 2. Complete.
2 Check the Printhead Lock Arms. Go to Step 3. Repair or replace Do the arms rotate correctly? the Printhead Restraints
3 Check for ink spills around the Printhead Go to Step 4. Remove ink spills or obstructions.
and Printhead Tilt Gears. The Printhead
should move when pushed left or right.
Is the area around the Printhead clean
and unobstructed?
obstructions.
Jul 04, 2011 | Xerox Phaser 8560MFP Laser Printer
Wiper motor starting making a noise (almost a grinding noise) next day when I turn on wipers they moved up about 2" and then totally stopped in place. Can't get them to budge. I also thought i noticed...
There is a motor above the firewall in the engine compartment.(Not easy to get at). To that motor there is a gear that attaches the motor to the wiper arms. Tighten that connection. You may want to try to turn the wipers on then off. Thiss will put the blades in what it thinks is the rest position. Other wise they may be out of wack. So with the wipers off loosen the drive gear force the wipers down all the way and then tighten.
Good luck.
ash
Aug 01, 2010 | Mercury Villager Cars & Trucks
I have a 06 montana the rear wiper not working but it only works when i push on the arm so i check and tight the arm but it till doing the samething what could it be
Wiper shaft is stuck by rust (aluminium oxide). Remove wiper motor. Knock out wiper shaft with soft hammer. Clean shaft hole with similar size drill bit.
Mar 14, 2010 | 2006 Pontiac Montana SV6
Mar 08, 2009 | Audio Players & Recorders
How do you load brads into the Arrow t50pbn staple gun?
Look at rear handle and push in tab then pull out load brads. Please Rate Thanks
Jan 08, 2009 | Dynamic Arrow Fastener Co. T50PBN Staple &...
Stuck in folded position Phil and teds classic stroller
We have a new Phil & Teds Classic -- same problem. Solution #2 worked for us. Pushing down on the black bars while pressing the grey button was the solution. Not sure why this is necessary to make the silver button line up with the grey button, but it is. Engaging the brake did not seem to make any difference.
Aug 21, 2008 | Phil & Teds Explorer V2 Twin Stroller
Onkyo c707chx...
This is an easy fix if you are somewhat handy.... The belt for the door/tray is slipping. If you remove the enclosure and face plate, you will see two motors below the disc drive. Press eject while observing the pulley to the left. You should see the problem with the motor shaft spinning and the belt slipping. Replacing the belt is possible without any further dissassembly. Simply bend some light wire into an L shape and you should be able to hook both pulleys and lace the new belt on. As far as obtaining a new belt I decided to do the simple thing and use a slightly smaller rubber band. The repair has held now for almost three months and the player is used everyday. Good luck.
Jun 21, 2008 | Onkyo MC35Tech CD Shelf System
177 people viewed this question
 Grubhead
Grubhead
