Question about Gateway GT5464 Refurbished Intel Desktop PC - Intel Pentium Dual Core E2140 1.6GHz, 1GB DDR2, 320GB
Hooking up replacement mobo 946 GZT-AM V:1.0. Need cabling hookup info for audio, 3 USB cables, HD LED and pwr sw board has no pin notations HD LED is red/wh Pwr Sw is blue/wh
    Scholar:
  • 85 Answers
Try here http://support.acer-euro.com/drivers/index.html
Posted on Sep 13, 2009
I have an MS-7502VER:1.2 motherboard and i cannot find wher to plug the power switch into
Hi scouts692
The Front Panel Header Pin arrangement for this motherboard is unusual, in that the header only appears to have 8 pins in a single column rather 2 parallel columns of 6 Pins with 1 blank, as most conventional motherboards do.
Pin 1 is POWER SWITCH orange or red (PWR SW 1)
Pin 2 is POWER SWITCH white or black (PWR SW 2)
Pin 3 is POWER LAD + (PWR LED -)
Pin 4 is POWER LED - (PWR LED +)
Pin 5 is HARD DRIVE LED - (HD LED -)
Pin 6 is HARD DRIVE LED + (HD LED +)
Pin 7 is RESET SWITCH blue or green (RST SW/RST 1)
Pin 8 is RESET SWITCH white or black (RST SW/RST 2)
Please refer to a PDF of the Motherboard Manual for additional information about the setup of this motherboard (the relevant page for the Front Panel Header is page 17/Section 2-13)
hope this helps.
If this Answer goes some way towards helping to resolve your Query, Problem or Fault, please take the time to Rate it. Doing so helps Solution Providers, like me, better understand the needs and the point of view of Askers, like you, and guides us in exploring the best ways to provide the most comprehensive, useful and high quality Responses and Solutions we can. If you need further help, please do not hesitate to post another Question or add a Comment to this Question.
Thanks for using FixYa.
Sep 17, 2011 | Intel Motherboard
Installed mother to new tower case and pwr sw | hd led | reset | power led connecting to my board is the Intel dq67sw 155 matx motherboard need accurate dir to connect these please help
info found at http://downloadmirror.intel.com/19707/eng/DQ67SW_ProductGuide01_English.pdf
Front Panel Header Pin info for DQ67SW. They should be color coded too. 1 Hard disk LED + orange
2 Power LED+ green
3 Hard disk LED - orange
4 Power LED- green 5 Reset Switch - blue
6 Power switch + red
7 Reset switch + blue 8 Power switch - red
9 Power Out (do not use)
10 No pin
NOTE When connecting individual wires from your chassis front panel to the front panel header, be sure to observe the connection polarity. Positive wires are usually solid color and negative wires are usually white or striped.
There is also an alternative pin header if you have a power wire that uses a 3 pin connector instead of a 2 pin connector. It is the 3 pins just past pin 9, and it should be missing the pin in the middle of the 3 pin block. The pin closest to pin 9 is the power led + and the furthest from pin 9 is the power led -.
if you need clarification, check out page 50 of the manual posted above at intel.com
Aug 23, 2011 | Computers & Internet
I need help connecting the power on cable and led cable as well as the hard drive light cable. for my emachine w3644
These cables are attached in the lower right corner of the motherboard. There are two rows of pins there. Probably 10 pins in all. They should be marked with letters something like hdled (hard drive LED), pwr (power light) pwr sw (power switch) spk (speaker) etc. Anyway, if you can't find markings, hooking the little plugs up to sets of the pins one plug at a time will tell you which works.You can't hurt anything by trying various combinations
Feb 13, 2011 | E-Machines Computers & Internet
The 946 GZT-AM is also used in the Acer Aspire T690, Acer AcerPower FH and Acer AcerPower SK50.
Here is the link to the Service Manual that includes motherboard replacement information including jumper settings:
http://www.acersupport.com/acerpanam/manuals/acer/0000/servicemanuals/AspireT690_PowerFH_SG.pdf
Hope this helps,
Robert
Sep 11, 2009 | Gateway Computers & Internet
Front panel to motherboard, ASRock P4i65G, connections
the power switch is on the 3 and 4 pins....the 7 and 8 pin are the reset pins. Trying it on wrong pins just won't startup the board but won't short circuit anything.
Jul 28, 2009 | Computers & Internet
TRYING TO HOOK UP MU POWER BUTTON NEED TO KNOW
Hi there
The front panel connectors are mainly,
  • harddisk activity connector
  • power switch connector
  • reset switch connector
  • power LED connector
  • speakers connector
  • USB connector
Harddisk activity connector
This normally comes red in colour and is labeled as HDD-LED
Power switch connector
This comes green in colour and is labeled as POWER-SW
Reset switch connector
This usually comes grey in colour and is labeled as RST-SW
Power LED connector
This is usually green in colour and is labled as PWR-LED
Speakers connector
This speaker will give different beep sounds during boot to tell the user if there is any errors. It occupies 4 pins, however only 2 is important for the function. Be sure to connect the red coloured cable to the positive polarity and the black to the negative.
front_panel_connectors.jpg Front panel connectors pins on the motherboard
front_panel.jpg Front panel connectors from the casing
Good luck and thanks for using FixYa!!
May 13, 2009 | eMachines T6420 PC Desktop
MY COMPUTER WONT TURN ON !!!
for connecting these sw
just see on mother board there you see nearabout 16 pins on right hand bottem of mother board
there you have an integation of connectorfrom right hand corner i.e 1-3 for reset sw, 2-4 for power sw and last switches for front usb and audio
if you have p-3 then you dont attech audio and usb cables on *********** board
Apr 07, 2009 | Computers & Internet
Where to hookup front panel (PIII-3754LMR - AMPTRON)
check arrow hok up the procesor from where u see arrow after removing fan etc .
Sep 29, 2008 | Amptron PM-9100A Motherboard
Wiring info
Most Mobo's have printing next to the places that are jumpered or pluged into. The ones you need sould be close to the edge of the mobo, that is close to the front {power button} side.
May 30, 2008 | E-Machines (308714) Motherboard
Need help bigtime
are those all seperate connectors for the button? Or are they all together on one block? Should be something near bottom right hand corner of mobo saying pwr, hdd, sw, snd, led, that kind of thing
Mar 24, 2008 | E-Machines eMachines Desktop PC
Gateway GT5464 Refurbished Intel Desktop PC - Intel Pentium Dual Core E2140 1.6GHz, 1GB DDR2, 320GB Logo
328 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
