Question about Frigidaire GLEQ2152ES Electric Dryer
Dryer doesn't heat
My Frigidaire GLEQ2152ESO doesn't heat and dry the clothes.
  • 986 Answers
The heating element have got old and brittle over time and finally gave up the ghost. But it is not always the element. It could be one of the safety Hi-limits have blown. All parts of the dryer will have continuity if its working properly. Test for continuity by using a meter set on Ohms,or use a poor man's meter. You can make your own poor man's meter by using an ordinary flashlight . Break the circuit in the flashlight and add a couple of wires to it so that you can make the light come on in the flashlight, that's right hot wire that flashlight. When the bulb lights up you have a circuit! You now have a poor man's meter. The next step is to check each little gizmo on the dryer that the wires attach to. All the limits attached to the side of the heat element, the door switch (when door is closed) etc.should have continuity (closed circuit)(the light should come on in the poor man's meter) If you come across an thing near the blower housing with 2 wires attached to it, that is a thermal limit, a safety or a control thermostat (So as not to get a false circuit you need to remove one of the wires to each thing you check) Look for lint buildup or blocked vent going out the house. If everything is good and you have paid the electric bill, then the timer could be bad.
Posted on Sep 12, 2009
Frigidaire Electrolux aeq6000es1 heats but sometimes doesn't heat when drying clothes why is this happening
Hello friend, thank you for your inquiry!
I understand that your Frigidaire dryer heats and will occasionally not heat when drying the cloths. This could be a possible issue with your thermostat or control board. I would recommend performing a reset on your dryer and you can do that by disconnecting the power cord from it for at least ten minutes. If that does not help resolve your issue you may need to have a professional technician out to perform a proper diagnosis and repair. This will help your avoid any unnecessary part purchases. -Matt
Dec 28, 2015 | Frigidaire Dryers
Why is the metal screen with round holes located in my dryer drum melting some clothes and leaving its impression on those clothes. My appliance is a Frigidaire gas dryer model # LAQG7011KBO.
The metal screen is the place where the heat from the dryer enters the drum. If the dryer is melting items, you have one of two possible issues:
  • The dryer thermostats are allowing the dryer to get too hot.
  • You are drying delicate clothes on too high of a heat setting.
Jan 14, 2015 | Frigidaire Dryers
What might be wrong with my gallery dryer #gleq2152eso it does not heat?
Hi friend, I appreciate your post!
Based off the information you have provided your Frigidaire dryer, GLEQ2152ES0, is no longer heating. I understand that you heard a noise like pennies hitting the drum and then it stopped heating. Some possible reasons to why your dryer is not heating could be that your vent is restricted, an issue with your thermostat, or heating element. I would recommend having a technician come out to diagnose and repair your appliance because with the noise you heard he may need to disassemble the dryer. I hope this is helpful. -Matt
Aug 12, 2014 | Frigidaire Dryers
It just doesn't seem like my frigidaire gas affinity dryer is drying as fast as it should
Hey Car Guy,.. there are two factors that determine how fast the clothes will dry:
1- air temperature, Is the gas burner is lighting and heating the air? Just stop the dryer mid-cycle and feel the clothes - if they are hot, then the burner/heating part of the dryer is working ok.
2 - adequate air going through the dryer. This is usually where the problem lies. There is a lint filter at the dryer somewhere, accessed either where the door opens, or on the top of the dryer....there may be an additional lint filter somewhere on the exhaust duct. Check for that, and check your air flow where it exhausts outslde. See that the flappers of the backdraft damper aren't stuck closed etc.
If you have good heat and good air flow, then it's doing all it can.
Mar 22, 2013 | Dryers
Frigidaire Galaxy Dryer tumbles but heats to dry seldomly
What is the model number of the unit?
Nov 13, 2012 | Dryers
Dryer will not turn
hello check to see if the long pin inside the door has not snaped off if thats ok .then check capacitor next to the motor inside the dryer may have blown
regards
shaun
Mar 01, 2010 | Frigidaire Electric Dryer
Take too long time to get cloth dried
how much are you putting in ? Is it a 220 volt dryer? May have a dead line (electris) to heating coils, or thermaostat is not functioning and letting the dryer coils get to operating temperature. Your heat setting control may be faulty. I wouls look at heat control first.
Jul 02, 2009 | Frigidaire GLER341A Electric Dryer
Frigidaire GLEQ2152ESO Dryer flashing AD
AD means "auto dry", which means the dryer is supposed to be detecting the moisture levels in your clothing and adjusting the drying time accordingly.
If your dryer is flashing "AD" and turning off shortly after the start, there is likely a problem with the mechanism designed to detecting the moisture levels. If it turns off after trying to use all various settings (including the no-heat feature), it is likely a wiring issue.
Mar 27, 2009 | Frigidaire Affinity ATF7000ES Front Load...
Frigidaire dryer heats but clothes not drying
A1 Pull the dryer out away from the wall. Unhook the vent from the dryer completely. Do not put anything over the dryer exhaust on the back of the dryer. Do a normal load with the vent unhooked. If it dries better or ok like this then the problem is in the dryer venting. Like a blocked vent pipe or a smashed or restricted vent hose.
Nov 23, 2008 | Frigidaire GLER642A Electric Dryer
Frigidaire GLEQ2152ES Electric Dryer Logo
379 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
