My Toshiba Projection Televison year 2000 Model TZ43V61 is not turning on. The red light is flashing off and on. Where would you look first?
  • 5,138 Answers
Firts CK your hori output Transistor make sure it is not shorted and Blue high voltage capacitor that feeds hori 2kv if tey are ok then Replace Both of your STK ICs they are big black Ics will have part number on them example STK392-110 Call Mats 1-800-628-1118
Posted on Dec 09, 2009
Will not power up. Red power light only blinks.
If you have sound and no picture, it's time for a new lamp.
In the manual check under LED indication, It explains the blinking lights, unless your outside at night looking up!
May 03, 2010 | Toshiba TZ43V61 43" Rear Projection...
My blank screen, red flashing light projection tv
Most likely the lamp has failed. The red light will blink with a pattern (number of flashes then a pause) You can refer to the users manual for information as to the nature of the problem by the aforementioned pattern.
Cheers
Jan 15, 2010 | Toshiba TZ43V61 43" Rear Projection...
Redslight blinking have no picture
Have you replaced the lamp before? If not, I recommend you do it, since it may be what's causing this. There is power on the TV since you get the blinking light, so it's most probable the lamp.
Jul 31, 2009 | Toshiba TZ43V61 43" Rear Projection...
Toshiba tz43v61 TV just died. No red light.
does it have a power strip on the tv stand? if so plug the tv into a wall socket.my power strip went bad and the reset button did not work
Jul 17, 2009 | Toshiba TZ43V61 43" Rear Projection...
Toshiba TZ43V61 43 in. Rear Projection... Problem
Try unplugging unit for 5 minutes, then plug in and turn on. If this works, your power supply may be going. However it is more likely that the bulb is gone, you can replace it yourself, but make sure you get the right bulb for that unit and take care in the installation of it.Go to the manufacturers website and look up your model and find out how to inspect and remove the bulb.
Bulbs can run for 140 to $300 and can be found on EBAY
Sep 28, 2008 | Toshiba TZ43V61 43" Rear Projection...
No picture
95% 0f the time when this happens to a toshiba projection or regular set, the power regulator IC is bad. It is a componet that should be replaced by a service technician as there are too many points inside this set that can zap you and hurt you. If thats the only problem your talking in the range of 175 to 250 to repair this set. Good Luck
Jul 31, 2006 | Toshiba TZ43V61 43" Rear Projection...
Televison & Video Logo
14 people viewed this question
Top Televison & Video Experts
Electro Med Services...
