Question about Samsung Digimax L730 Digital Camera
My Samsung Digital camera won't turn on. It just beeps a couple times and turns back off. When I locked the memory card the camera turned on but when I tried to take a photo it told me that the memory card was locked. Any suggestions?
  • 24 Answers
Check the switches and battery contacts for proper contacts.
Posted on Sep 11, 2009
Shuts off when connected to computer
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Aug 21, 2012 | Samsung Digimax L60 Digital Camera
Card locked error on samsung es80
Turn off the camera and remove the memory card.Most cards have a lock slider at the side.You have to slide that button downwards/upwards to unlock it.Slide the memory card back into the camera.
Turn on the camera.
Hope this helps.Thanks!
Please rate this answer.
Oct 28, 2011 | Samsung Cameras
I was taking photos and evertime i took a photo i turned it off,(i was on a plane) and then went to turn it on again, and it opened then lens opener (two black things) and then beeps 2 times and turns...
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success
Jan 20, 2011 | Samsung WB550 Digital Camera
When I turn on the camera it beeps three times and the lens doesn't go back.I removed the battery and put it back but it still doesn't work and charged it fully.what is the problem and what can I do please...
i hope it will gives you success.
Jan 15, 2011 | Samsung NV24 HD Digital Camera
Turn on the power and the camera beeps 3 times?
hmmm... accesses the card ok? 3 beeps on a computer is a memory thing... might try a differnt SD card... Otherwise, probably is trash, cameras are so cheap that having a shop repair them is just not worth it.
Peace,
Mar 28, 2010 | Samsung S85 Digital Camera
Insignia camera turns on beeps three times and turns back off
Three beeps indicates a low battery or other warning. It also indicates error messages, such as memory full or card error. You should try replacing the batteries, erasing files from the memory, or verifying that your memory card is in the correct format and/or not defective. Additional details can be found in the owner's manual.
Jan 30, 2010 | Insignia NSDSC10A Digital Camera
My Samsung i70 switches itself off after a couple of seconds
I had the same problem with my camera. It was due to the memory card Apparently not all memory cards are compatible with this camera Try to remove a memory card and turn your camera on without it.
Jan 20, 2010 | Samsung i70 Digital Camera
Samsung L730 wont extend lens and dosent turn on right
Try removing the batteries and memory card. Let the camera set for awhile. Put the batteries back in but not the memory card, restart the camera. Does it work know? If it does, turn the camera off put the memory card back in. Turn the camera on, does it work now? If it doesn't, replace the memory card.
Dec 27, 2008 | Samsung Digimax L730 Digital Camera
Samsung L100 Digital Camera Problem
right as the lens comes out very quickly remove the battery before the lens slides back inand beeps three times, wait a second put the battery back in and switch on obviously let the lens go back in and hay presto itshould work, it worked a treat for my L100, i hope this helps some of you but its obvious to us all our camera's are ****.
Oct 27, 2008 | Samsung L100 Digital Camera
Memory card
If the card is locked, you could the steps below:
- Turn off camera
- Remove memory card
- Take a look on the switch of the memory card itself
* If it's at the TOP = card is UNLOCKED
* If it's at the BOTTOM = card is LOCKED
- So, you just have to make sure that the switch is at the top
for the memory card to be UNLOCKED
After doing that, you just have to put back the memory card to your camera and turn on the camera. Try to check if this works.
Jan 01, 2008 | Samsung Digimax S630 Digital Camera
Samsung Digimax L730 Digital Camera Logo
323 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
