Question about Dell Latitude D600 Notebook
3 Lights on display panel Dell D505
My problem starts
1) When trying to turn on power to the laptop. I have to pull battery out & press power button as I place battery back inside for it to boot.
2) The 3 display light on the display panel next to the power button stays on, meaning the scroll lock, number lock & caps lock stays on.
3) I have to press very hard on the power button for the computer to turn on.
HELPPPPPPPPPPPPPPPPPPPPPPPPPPP
Now if anyone can help me please email me
troythompson70@gmail.com anytime of the day no problem.
Thanks in advance for the help...................LOL
  • 22 Answers
YOU HAVE A FAULTY BIOS.I HAD THE SAME PROBLEM WITH MY DELL INSPIRON 5150.REFLASHING THE BIOS SOLVED THE PROBLEM.GOOD LUCK.
Posted on Sep 11, 2009
Find the cmoss battery d505
Unplug the Dell Latitude D505 laptop from AC power. Turn over the so that the base of the computer faces upward. Locate the battery panel on the bottom of the computer and then press the latch on the battery panel in the direction of the arrow on the latch. Lift the battery from the battery compartment.
Press on the latch located toward the front of the computer inside the battery compartment. Pull the cover that is released out and down and remove the cover from the battery compartment.
Grasp the small battery in the slot uncovered when the cover was removed and pull the battery away from the slot to detach the battery from the laptop
Dec 12, 2011 | Dell Latitude D505 Notebook
It doesn't do anything. get nothing when i press the start button either with ac adaptor or without battery appears to be fine.
Please elaborate on your issue: If your PC does not turn on or give any lights with or without AC adapter, most likely the internal power supply/connector has gone bad, and with it being a Latitude D505 it probably is out of warranty. Only on eBay might you find an old part or two to replace it.
Please feel free to contact me with any questions.
May 04, 2011 | Dell Latitude D505 Notebook
Dell latitude d505 laptop power on & led glows but there is no display, no beed & also the cpu fan is not running , after few seconds thens it turns off automatically. help?
hello
i experience to repair one of those before!!! mostly the problem is in the board you need to bring it in service center for repair.
Thanks
Nov 13, 2010 | Dell Latitude D505 Notebook
My dell d505 latitude laptop has the dreaded
Sounds like your battery is dead. They go bad in laptops and need to be replaced in a couple years.
1) Unplug your battery and power laptop on with just AC adaptor. If laptop runs normal then you need to replace battery.
2) If it doesnt turn on at all then your motherboard may have a problem. The power supply is integrated on MB on most/all laptops.
2) if you need a motherboard replacement, try http://accessories.us.dell.com/sna/DellPartsFamily.aspx?c=us&cs=19&l=en&s=dhs
Nov 25, 2009 | Dell Latitude D505 Notebook
Latitude d505 won't display image through projector. Being used with Sanyo plc XU41 and Promethean board. Board is interactive but no help if there is no image to see! Other Dell laptops work with this...
Dell laptops normally have a 3-way toggle for the display destination: 1=screen 2= external display and 3=Both. To toggle from one mode to the next press hold the 'FN' key (lower left corner of the Key board), and the briefly press the 'F8' key. Wait a few seconds for the hardware to catch up and you should see a display through the projector. If not, repeat the 'Fn' + 'F8' combo again.
You could also try running diagnostics to verify that teh video card is working properly. To do that, sthar with the laptop off. Hold the 'Fn' key down while you press the power button. Release both as the machine begins to boot up. It should start in diagnostics mode. Run the quick test and watch for the color bars. If you see then, the video card so=huold be OK.
Good luck, And please let me know how it turns out for you.
~ Spoem
Oct 01, 2009 | Dell Latitude D505 Notebook
I Have Dell D505 LAPTOP and it just booted up
remove all drives, RAM, battery,cards and any external connections, and see if the Lock LED indication changes. If it does change, add 1 RAM module, and see if the system POSTs. If it posts, add items back till you ID the one preventing post and replace it. If no change, then replace the motherboard ($150 or so on EBay)
Sep 24, 2009 | Dell Latitude D505 Notebook
I have a Dell laptop D505. The laptop powers up but the screen display is very dim. I can't see the image on the monitor. I've tried to manually increase the color/brightness button and nothing changes. ...
Sounds like your inverter or your backlight is failing. The inverter is an easy repair, the backlight can be replaced but it involves taking the LCD panel apart, The backlight comes installed on new screens. I can include a service manual below and possibly a generic guide to backlight replacement....
http://support.dell.com/support/edocs/systems/latd505/sm/display.htm#1052500
http://www.laptoprepair101.com/laptop/2007/01/31/replace-screen-inverter-fix-backlight/
Sep 23, 2009 | Dell Latitude D505 Notebook
DELL Latitude D505
Have you tried the other fix? It often times works.
Remove the battery AND the power cord.
Hold the power button for 10 seconds.
Now plug in the power cord.
Magic should happen
Feb 27, 2009 | Dell Latitude D505 Notebook
D505 will not power up
for this problem
go to http://support.dell.com>techincal support> enter your service tag> then check for battery issue it will tell you the meaning of each code being displayed on the laptop and you can resolve the problem,
one thing you can do is
take out the battery, take out the ac adapter from the laptop
now press hold the power button for 15 seconds
now put in the battery and ac adapter and see if the battery is charging and laptop is starting if not call dell support,
further queries are welcome
Jan 15, 2009 | Dell Latitude D505 Notebook
Laptop getting power but not booting up!!!
Are you referring to the caps lock key,kindly check the memory of the laptop.
Oct 19, 2008 | Dell Latitude D505 Notebook
Dell Latitude D600 Notebook Logo
243 people viewed this question
Alun Cox
